Kennys UrS4 (SX-E 257 Big Turbo Build Complete...Tuning in )
Re: Kennys UrS4 (Volvo turbo to BW S257 SX-E Turbo Built eng
Postby morris400 » Fri Dec 18, 2020 6:35 pm
Afterthought wrote:this is gonna be awesome, taking this thing to the next level.
Thanks buddy, i sure am trying. 1 piece at a time.
2016 VW GTI DSG Daily Driver
2001 B5 S4 Stg 3- (Gone)
morris400
Postby morris400 » Thu Jan 14, 2021 12:18 am
New parts coming once again lol
- New serp belt tensioner (NOS)
- ARP crank bolt
- Fuel pressure gauge adapter
- VW Fox Steering damper ( NOS)
morris400
Postby morris400 » Tue Jan 19, 2021 12:29 am
Old engine is now out. Cleaning up brackets, and the engine bay. Goingvto por15 some more stuff, install a new steering damper and other small things.
Never had to raise the car up or shift it around. Put it on dollys and was able to pull the engine like that. Which ill say im proud of cause alot of people said id have to have it up on jacks.
morris400
Postby morris400 » Sat Jan 30, 2021 10:17 pm
Awaiting my new rear main seal. Went to get the oil pan.on the other day and the rear main stripped. Ordered a new billet one from Issam. Got the billet coolant T and new set of VC bolts to add to the bling factor.
Once the rear main is in, i can start the remaining assembly and install. The weather took a dive here so its to cold to work outside in the garage now.
morris400
Postby FFF » Sat Jan 30, 2021 11:39 pm
We are supposed to warm up a little here... hopefully it warms up there a little as well.
FFF
Postby PRY4SNO » Sun Jan 31, 2021 4:39 pm
Did you get a B6 A4 1.8t rear main seal?
Improved design and much easier to source.
Postby morris400 » Sun Jan 31, 2021 11:15 pm
FFF wrote:We are supposed to warm up a little here... hopefully it warms up there a little as well.
Im hoping, were looking at a high of -7 tomorrow, and dropping back to the -20s again.
morris400
Postby jbrentd » Mon Feb 01, 2021 7:48 am
:o ...and I was complaining about the 30-40 F temps the past couple of weekends.
jbrentd
Postby morris400 » Mon Feb 01, 2021 9:21 pm
Going down to -32c this Friday lol.
morris400
Postby varia » Mon Feb 01, 2021 10:21 pm
wow +21C tomorrow
¯\_(ツ)_/¯
project 2226
varia
Postby morris400 » Fri Feb 05, 2021 10:40 pm
varia wrote:wow +21C tomorrow
Only getting colder here. -36c tomorrow . I could use some +21c for sure.
morris400
Postby morris400 » Sun Mar 21, 2021 7:04 pm
Engine is in. Time to start getting everything else sorted. Anticipating Easter as a start date.
List of things to do,
Torque Bellhousing bolts
Install started
Install Alternator
Bleed clutch slave
Remove turbo, for DP install.
Install turbo
Clean air filter
Block off coolant lines
Install IM and fuel rail.
Heat wrap fuel filter
Firm up turbo oil lines
Torque crank Bolt.
Install Vems
Install Radiator
Fill with coolant
Double check everything 6 times
Fill with oil.
Panic, and drink beer
Debate selling it
Gain up the strength to turn it over
Realize the battery is disconnected
Reconnect battery
Start car
Pray
morris400
Postby jbrentd » Mon Mar 22, 2021 3:28 pm
Nice work Kenny! Don't forget the steps for connecting the starter trigger to wrong post, panic about having a dead starter, then swapping to the correct post.
jbrentd
Postby morris400 » Mon Mar 22, 2021 10:05 pm
Im preparing for vems to not work correctly and have trigger issues lol.
morris400
Postby morris400 » Sat Apr 03, 2021 4:05 am
Engine is all buttoned up.
Still left:
- fix intercooler piping
- mount bumper
- fill coolant
- final check of all clamps and bolts
- calibrate Vems WB and TPS
- load base tune on ECU
- drink beer
- sleep
- start car........
morris400
Postby Afterthought » Sun Apr 04, 2021 4:18 am
Beauty! Looks real good .
Gonna be able to fit any sort of intake in there ? Or maybe a mushroom filter ?
Postby jbrentd » Sun Apr 04, 2021 3:32 pm
Looking good! Getting close.
jbrentd
Postby morris400 » Mon Apr 05, 2021 1:38 am
Afterthought wrote:Beauty! Looks real good .
Hey, yes i have a 3.5" 90° boot that just fits in there with a 4in cone KN filter.
morris400
Postby morris400 » Mon Apr 05, 2021 1:44 am
jbrentd wrote:Looking good! Getting close.
Was really close...went to load the tune in Vems today but noticed a small pool of coolant under the car. No worries...figures it was a clamp loose or something... my bad luck turned out to be the water pump Oring that was pinched. Spent all day ripping the front end off and pulling the pump to replace the 50 cent ORing.
And this is how she sits for now, going to see if it leaks over night and try and load the Tune tomorrow.
morris400
Re: Kennys UrS4 (SX-E 257 Big Turbo Build Complete...Tuning
Postby morris400 » Mon Apr 05, 2021 9:34 pm
Good news...the leak has gone away. Looks like were set for start up tomorrow.
morris400
Postby Afterthought » Mon Apr 05, 2021 10:47 pm
Niiice .
I did actually that exact same thing with my engine .
Also forgot the seal under the cam gear once... that sucked .
Looking forward to see how it goes
Postby FFF » Fri Apr 09, 2021 11:28 pm
That sucks - looking forward to tuning updates.
Sent from my iPad using Tapatalk Pro
FFF
Postby morris400 » Sat Apr 10, 2021 1:24 pm
**UPDATE APR 10th**
The Car does start, which is good. The Tune I have is running a lot more rich then expected, so the car will Idle but not run well. Marc is working with me to get it all sorted out which is great. the car does have a small coolant leak off the nipple on the side of the block for the turbo coolant line, as I'm not using it ill have to figure out a better way of clamping it shut as my current method is not holding up.
other then that, the car starts well, and builds good oil pressure. no big big issues.
morris400
Postby jbrentd » Sat Apr 10, 2021 3:50 pm
Congrats on a great milestone. I’m sure Marc will get it sorted for you.
jbrentd
Postby PRY4SNO » Mon Apr 12, 2021 12:17 am
w00t
That's super cool that Marc is pitching in, you're in good hands.
Would be nice to go for a rip when I'm home on my next furlough, definitely be a kick in the ass (and motivating, to boot)!
PreviousNext
Return to Projects
Who is online
Users browsing this forum: No registered users and 21 guests
