Time to clean out the garage.
Postby DE80q » Sat Oct 05, 2019 6:34 pm
Well I have amassed way too much crap, and a lot needs to go. So here is a short list to get things started. All prices are plus shipping.
-Vibrant vacuum manifold. Never used, and has 2 push lock connectors $40
-4k power steering pulley cover. Good shape, ready to install. $20
-Complete B3 80q tail light set. Both inner, outer, and license plate tub. Tub has a small piece chipped out. $150
-b3 2 piece rear CV shafts. Needs new boots $175
-B3 complete 2 piece suspension with rear CV shafts. Came from an 80q, so 75mm bearings all 4 corners. Will need boots replaced on shafts. $450
Added 10/21
-small chassis snub mount bracket. $30 each, $45 for the black powder coated one
-BOS upper heat shield, 2 mount holes not in great shape. $35
-Small chassis thermostat housing $25 each. I have at least 3, all should be JB welded at hose connection.
-Small chassis i5 mount arms. $50 for the pair
-Hyperboost diverter valve $35
-AAN fuel rail, injectors, FPR, and hose $50
-early 7A throttle body. TPS was good when pulled $60
-cruise control vacuum actuators. $15 each.
-early build 7A ISV's with hoses. $45 each. MAF sensor $35 each.
That's what I can think of for now. I will take pics in morning. Trying to put funds together to get the CQ on the road. Will post more as I find things.
Thanks for looking.
1991 Audi 80 quattro (10vt project)
Re: Time to clean out the garage.
Postby DE80q » Sat Oct 05, 2019 7:28 pm
Catch can, heater hoses, 42dd manifold, and density diff mounts sold.
Postby DE80q » Mon Oct 21, 2019 3:26 pm
More added
Postby DE80q » Tue Oct 22, 2019 1:51 am
Cam gear sold
Postby DE80q » Fri Nov 22, 2019 10:28 am
Bump, soon to be listing on eBay.
Postby Lucky » Sun Nov 24, 2019 6:18 pm
Could you send me a few pictures of the rear suspension and axles please. Also a shot of where the ball joint mounts.
Lucky
Return to Swap Meet
Who is online
Users browsing this forum: No registered users and 11 guests
