1984 Ur-quattro 20vt, 336whp 380 torques, 6-speed
glibobbo21
Re: 1984 Ur-q with 20vt and 6-speed aka Shannon, she drove!!
Call marc about the display..You cant space much more than 10-13 mm then you start getting towards the end of the threads on the motor mount studs. Unless youve replaced with a standard bolt. BTDT
- ralleyquattro
Highlander wrote:Does that mean she's getting washed, striped, and door rings ?
Cheers,
Craig
Yep, got to giver her a bit of a polish and wax beforehand though.
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
91 Coupe Quattro
- ralleyquattro
glibobbo21 wrote:Call marc about the display..You cant space much more than 10-13 mm then you start getting towards the end of the threads on the motor mount studs. Unless youve replaced with a standard bolt. BTDT
I'll call him next week, I think he's busy with Phil's car and the whole event.
I know, 5mm will do, that's all that's needed.
If it wasn't for that intake spacer she would have fit just fine.
I already massaged the hood a bit, Craig will be appauled
if he sees it, need to get some paint on it asap Cheers
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
glibobbo21
phils car is a no go, think hes driving the crow. he should answer :-)
- ralleyquattro
What happened?
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
wooot so this car is making journey to mt washington?
84urq20v
Martin-
Di you calibrate battery voltage in VEMS? I'm assuming not Motronic, right? My car has idled rich (but runs fine) for years - if not since the day I did the motor swap (8 yrs ago!). Per my ProDiag it say O2 Adaptation is out of spec. Still a head scratcher for me...
Glad to hear you are making progress.
- ralleyquattro
Yes, it was VEMS that allows that calibration, I have no idea that you can even adjust that on a Motronic without too much hassle.
I am happy with this VEMS, at least almost every variable is adjustable, just a steep learning curve, but for long. You might want to consider going this way.
Cheers
Cheers
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
- ralleyquattro
audiurq wrote:cooooool :woowoo:
a lot of hard work, well done!
Thanks, so... when do we start the same on your '83?
Valencia GP Sun morning?
Cheers
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
- ralleyquattro
Great weekend, calibrated few more things, including EGT.. works great.
Still need to massage the hood, but took a nice 1 hour drive yesterday with the family.
Kids love the horse snorting sounds the wastegate makes on overrun!
Still hate the VEMS LCD... every fraction of a second keeps switching between views, not long enough to catch details you really need, and that's while its standing, while driving it's hopeless not to mention dangerous.
Anyone knows how to make it stay in one view, sort of like this?
Much appricaite it.
Cheers
Much appricaite it.
Cheers
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
under outputs->display settings, set "lcd page step analog input channel" to 0.
I didn't finish Phil's car in time, I left myself with too much to do and not enough time to do it in. trans is in, as are all of the spacers (which I finished turning on my lathe around 1am Friday morning) but the final nail in the coffin was realizing I didn't have the correct metric adapters to bypass his transmission diff cooler pump. so no way I was going to be able to finish.
- ralleyquattro
Thanks for the tip, I'll try this this evening, it's driving me mental.
Sorry to hear that, did you trailer the car there anyway?
I've seen couple of pics on quattroworld and it looked like a big success.
Hope to be there next year.
Cheers
Cheers
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
Highlander
Glad to hear your driving it Martin.
Fun times ahead !!
Cheers,
Craig
Fun times ahead !!
Cheers,
Craig
- ralleyquattro
a4kquattro wrote:under outputs->display settings, set "lcd page step analog input channel" to 0.
Marc,
Tried your tip and it worked well.
I just have a question about what two of the numbers mean.
The one in the bottom left corner (right before egt), and the number after T (top row).
I have all the other firelds figured out.
Thank you!
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
Warner
Shannon looked really good today. the 80 also. Thanx for the motor.
- ralleyquattro
You are welcome! Glad I you can use it.
Off to John's tomorrow for a day trip with Craig, need to give he a wee wash, don't want her to look scruffy next to Phoenix
Hope to see you at the next meeting and thanks for painting that RS2 bumper for me... maybe this winter you can do the Euro bumpers for Shannon as well? 8)
Cheers
Cheers
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
- ralleyquattro
Took the boys to soccer in the quattro, they ask for a ride every day...
Field was empty so I took the occasion and shot a few snaps.
Still have to install the full stripe kit, but for now the rings will do, thanks to Mike Sylvester.
Cheers
Cheers
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
Quattro Krant
Is it wrong to think about Shannon the next time I'm about to climax?
- ralleyquattro
It was OK untill you told us about it.. :slap:
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
Quattro Krant
In all seriousness, it looks AMAZING, sounded great when you left the pub as well. The last 2 pictures are my favorite. Maybe we can take some of the extra paint from Shannon and put it on my pink lady.
Katman
ralleyquattro wrote:Still have to install the full stripe kit, but for now the rings will do, thanks to Mike Sylvester.
And how did that 'Tolberone box' make it to your hands? :tard:\
Looks just *beautiful* !
- ralleyquattro
The WWW.QUATTRO.CA sticker will be put on thanks to Mike and Frank for delivery... thank you Frank!
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
Quattro v1.0
Cheers
I kinda like it without the stripes, looks newer. Im surprised you kept the flat grill and the quads though.
- ralleyquattro
quattro v1.0 wrote:[/quote]
I kinda like it without the stripes, looks newer. Im surprised you kept the flat grill and the quads though.[/quote]
I used to prefer the new sloping look long time ago, but now that I got older my taste changed and prefer the classic look, not to mention that's the way it looked originally.
I have a set of Euro bumpers that I may install at later date, already have the Euro harness in there for the lights so it will be a plug and play affair.
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
redur1983
She looks fantastic Martin...excellent job !!
Hope to park mine next to yours soon..
Cheers,
Mark
Cheers,
Mark
