I forget/just looked through the thread quickly and didn't see anything - are you going to go full boost on this engine? Did you do rods?
pilihp2 wrote:God that thing sounds amazing....
loxxrider wrote:What do you mean it wont control the boost up that high? It just wont go higher than a certain amount or what?
a4kquattro wrote:amd is the best wrote:
try open loop boost control.
set P/I/D all to 0. then go into the boost control->ref DC vs RPM table. the left hand column is for RPM, the right hand column is the duty cycle number that will be sent to the valve. Start with around 50, increase in increments of 5-10 and watch the resulting boost.[/quote]
Thanks Marc, I'll give that a shot tonight.loxxrider wrote:I bet your integral limit is stopping it from going higher (which I think is what Marc is getting at by having you try open loop). If you increase integral limit, you should be able to get more boost.
Here are my current settings:
So I should try setting the 60 a bit higher?
What is yours set at?
Thanks guys![/quote]paradox11235 wrote:Great project. I'm kind of afraid i'm going to forget about my coupe and pour all my money into the 200...
Lol, I hear ya! Thanks!
loxxrider wrote:Yeah, try upping that integral limit. It won't hurt anything. The reason its there is to stop what they call "integral windup" from happening. Its basically when you have too much integral and the system goes unstable (aka oscillates out of control). Mine is set higher than 60 and is still fine. Try 80 or 100 and it should let you up the boost more. If not, then something else is the problem.
loxxrider wrote:ohh how high?
a4kquattro wrote:loxxrider wrote:ohh how high?
heh. a fun variation on a "stripes" quote.
when I tell you to boost, you're gonna say: how high?
http://www.imdb.com/title/tt0083131/quotes
but I guess I'll have to do it, lol. Should I log it?
I still need to give you a call about getting the launch control pulled up, should have some free time this week.
