Audilard wrote:The control arms are installed. Finished installation on Friday morning and made a few tie rod adjustments to eliminate some of the pigeon toe that both my rear wheels had to fit under the front part of the fender. I still have some negative camber, but not a lot. The wheels are nearly touching the rear bumper, which will be modified.
Now it's only a matter of waiting for the side skirts to get here, test fit and find a final resting spot for them and then start cutting and welding. Taking volunteers for welding.....
Darin, I happen to have a gas fed mig. I can give you a hand with that when you are ready. When will you be wanting to paint? I ask cause I just recieved an S2 rear bumper and will be painting it with the help of Kelly. I wasnt really planning to go for it untill closer to spring due to engine and turbo expenses. He has access to a high dollar gun and was going to shoot my bumper when I was ready. I was thinking we could go in on the paint and clear together if you wanted to save some money. Kelly does have some skills for sure and I am sure he would be glad to shoot your car at the same time. Not to mention he can show you a thing or two about bodywork and will have you do the bulk of the work yourself saving you some cash in the long run. What were your plans on that?
