Darin's 80q…Alive...
quattro87
Re: Darin's 80tq...255's...
Post by quattro87 »
Is it done yet?
Quit showing off the KWs already and get this back on the road! :wink: I gotta say, I will be a bit jealous of all that rubber when you are rolling again. Nice!!
RSCoupe
Re: Darin's 80tq...fuel line fittings...
Post by RSCoupe »
Audilard wrote:Image
You could gain another couple millimeters if you switch to heim joint tie rods.
Mark Siggelkow
'90 CQ-R - NASA GTS-4
'12 TT-RS (Wife's DD)
'00 A4 1.8TQ (My DD)
'62 356B (vintage racer)
'07 Toyota Tundra CrewMax (for towing/hauling)
PRA4WX
Post by PRA4WX »
Audilard wrote:More pointless pics of my car. I'm really liking these gunmetal wheels on the black car with the s4 skirt. It's really going to look good with the upper door trim removed, B4 rears and fresh paint....
RS2 mirrors would be sweet too..
....and 255's. Here are the fronts with the 235 track tires and a 10mm spacer:
Those 235/40's are more like a 245, so what's another 10mm? :wink: I can get the fronts to work...
I think I'll sell my other ABT's with the 235/40 Dunlop Star Specs. 17x8 25mm offset. Gotta buy some Azenis!!
They look aggressive and are cheap enough, but i dislike the 615's a fair amount. Poor performing tire for me.
Audilard
Post by Audilard »
The 245/40/17 tire is quickly becoming irrelevant in the tire market. There are fewer and fewer options out there for that size. The best tire in that size was the Dunlop Direzza Star Specs, which Dunlop is no longer making. Those are what I really want, but won't be able to find that tire anymore. I can't find anything really comparable. Here is that tire on my wheels in 245/40/17.
Darin
1989 80 20vt
Audilard
Post by Audilard »
245/40/17 options:
Toyo Proxes R1R
Ventus R-S3
Potenza RE-11
Opinions?
Darin
1989 80 20vt
Where did you get the info the direzza is discontinued? I am gonna keep my tirerack eyes peeled for when those go on clearance. There are still lots of 245-40-17 tires though, far more than 255-40-17s. I really liked the hankook v12s. Awesome budget tire, and 255-40-17s fit well on 8" wide wheels. The direzzas in 255s are too wide for a 8 wide imo.
those direzzas seem to run a size wide all arouynd
Audilard
Post by Audilard »
ShavedQuattro wrote:Where did you get the info the direzza is discontinued? I am gonna keep my tirerack eyes peeled for when those go on clearance. There are still lots of 245-40-17 tires though, far more than 255-40-17s. I really liked the hankook v12s. Awesome budget tire, and 255-40-17s fit well on 8" wide wheels. The direzzas in 255s are too wide for a 8 wide imo.
Tirerack already lists them as discontinued and you can't find that tire in 245 anymore.
Darin
1989 80 20vt
Audilard
Post by Audilard »
I just went to two EVCOs and they weren't any help. The only -6 fittings they had were brass with yellow caps. Guess I'll order from Summit.
Darin
1989 80 20vt
I like the HTRZIII, cheap, good treadwear.
http://www.tirerack.com/tires/tires.jsp ... &tab=Sizes
savagerocco
Post by savagerocco »
Is this thing running yet? :hide:
Mentosman42
Post by Mentosman42 »
I second the v12's. Got a set from tirerack with a $80 or $100 rebate a while back, great bang for your buck.
95.5 ur-S6
83 20vt urQ
nsimps
Post by nsimps »
savagerocco wrote:Is this thing running yet? :hide:
:stupid:
Audilard
Post by Audilard »
Nope
Darin
1989 80 20vt
mrmotorhead13
Post by mrmotorhead13 »
FWIW I have RS3's on the track Miata and they're great. Stick well and wear well both.
Audilard
Re: Darin's 80tq...no fuel...
Post by Audilard »
Got it all together and went to start it. It cranks over just fine, but the fuel lines aren't pressurizing. After some cranking I check the fuel rail lines and there is not fuel in the line.
Darin
1989 80 20vt
quattro87
Post by quattro87 »
Won't run without gas!!
Might wanna look at the pump. Going lean at WOT would explain a lot. Jump it with 12v and see if it runs
Audilard
Post by Audilard »
Good news. Got it fired up. Bad news. It's blowing white smoke like a locomotive.
Darin
1989 80 20vt
savagerocco
Re: Darin's 80tq...fired up, but...
Blown head gaskets always smoke until you get the coolant burned out of the exhaust
death 4kqt
Post by death 4kqt »
Darin, did it smoke right away after starting, or after running a bit and getting some heat in the exhaust? If the latter, then it its probably just coolant from you prior mishap burning off, as Brent said. I had the latter happen after a headgasket issue on my 3b 90.
Audilard
Post by Audilard »
It got more smoke as it warmed up and I let it run for a while at about 3k rpms. It has tapered off significantly so I hope it's just about all burnt off.
Darin
1989 80 20vt
Panic! Nevermind. Whew..
nsimps
Post by nsimps »
I'm sure it'll be fine :) glad you had some wrench time, especially this close to Christmas!
Speaking of white smoke behind cars, mine did that the other day... :(
quattro87
Post by quattro87 »
Did the smoke smell like rubber? :wink:
