dubsmith
Re: Ben's AAN 4kq - Working on (rear) Swaybar, Weekend push
moar tail happyness
I think you are just gonna have to drive it and play around with different combinations of sway bar configurations to find what suits you best. Remember, you also have the option of not running a front sway bar at all, which will induce some oversteer.
Once you got it dialed in you can start making videos to rival ken block
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
1984 Ur quattro
HAHA! That would be freakin awesome xD
did youcut the steel ring out from the old rear dff mount
autoholic
Awesome R swaybar install. Must copy that! Look forward to hearing how it handles.
my2000apb wrote:did youcut the steel ring out from the old rear dff mount
Yup sure did! I ended up taking it to a shop today and they pressed it in for 10 bucks. :-)
autoholic wrote:Awesome R swaybar install. Must copy that! Look forward to hearing how it handles.
Thanks man! Ya I can't wait either!
I've been watching this from the start but haven't really had much input. so.. here it is.
keep up the good work! it's gettin there! everything looks awesome.
Thanks Phil!
Kliminati
Sweet Project
Im doing the same rear sway bar upgrade on my coupe right now. Just waiting on some links for up front and larger brackets for the rear. It should transform how both our cars handle
Keep up the good work!
Thank you Justin!
New diff bushing pressed in!
Now it's ready to go back under, hopefully I get time tomorrow!
Well, it's been a long couple days on the Audi, I managed to strip out 6 bolts and the threads on the CV shaft for the hub bolt. Needless to say a 30 minute job turned into a two day affair. :(
But... today after work was really nice to come home, paint up the calipers and end my day like this.
JT4k
Looking very, very good
:cheers: um, how about throwing a wheel on there too bud? it'll be the icing on the cake.
Dan
1984 Ur quattro
1984 Ur quattro
brianspillner
I was tired and planned on going to sleep, but damn I'm glad I spent the last 30 min. reading this thread. Keep up the great work!
Thanks guys!
Dan I will throw a wheel on it for ya tomorrow and take some pictures!
Dan I will throw a wheel on it for ya tomorrow and take some pictures!-Ben-
Here are some pictures of the brakes with the wheels.
that looks awesome.
Kliminati
That looks freakin sweet
so obviosly you giving up ebrake function?......or are you adding a master cylinder to the lever?
oh wow that's purdy...
wow, that is going to be filthy!
Thanks guys!!!
It's soooo nice to finally see some of the fruits of my labor!
Justin, my plan is to run a seperate mechanical E-brake, somthing like what an R8 does. I thought about running a hydro ebrake, but I don't think I have enough faith in it to simply depend on that for my parking needs. I posted the a couple pages back with a linky to the caliper I am going to use. I just can't afford to do this all at once.
It's soooo nice to finally see some of the fruits of my labor! Kliminati wrote:That looks freakin sweet
mrdeye
Nice sway bar set up. I don't think your gonna have any trouble stopping! :woowoo:
:jerk:
:thanks:
:thanks:Dan
1984 Ur quattro
1984 Ur quattro
@ Dan... Good times.-Ben-
