Mcstiff wrote:I've been working too much! I'm sure it will run this weekend but probably not until Sunday (I work today and tomorrow) and I still need a mid pipe to really drive it.
Un needed. Get it on the road! 8)
PRA4WX wrote:Ak and you shall receive. Pretty sure i've got the line awaiting your CQ!
my2000apb wrote:just build new lines already
audifreakjim wrote:Good old Mance. If you don't have to worry about heat, I like to use the socketless hose on stuff like this because it clamps easier than stainless braided.
ShavedQuattro wrote:Just the 7a flywheel?
(edit:wiring checks out).
yodasfro wrote:You definitely don't need that tool to set timing marks. You should always use the flywheel mark not the crank pulley mark as it moves over do to the rubber in the harmonic balancer. The FW only bolts up one way so now worries there. Set the Cam pulley to TDC check for the line or 0 on the FW to be lined up on the edge of the window in the bellhousing. Once you have cam and crank set then loosen the 13mm nut o n the clamp for the dizzy and rotate the body till the | on the shutter wheel and the | in the body line up done.
http://www.quattro123.com/TB440A.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://www.quattro123.com/TB439TimingMarkViewA.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://www.quattro123.com/Audi200Distri ... st184A.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
