Cory's Lifted / Rallyx CQ - Winch Installed
audiPete
Re: Frosty's Faux Rally CQ - exhaust vid and rs2 rear instal
those are the stock wheel bolts, I think when you convert to studs you go to an M16 nut....someone will either confirm or correct me ;-)
a_CQ
Thread size remains as-is, M14, you can't change that. Only thing that changes is the socket size you need to use for OE bolts vs. lug nuts. With OE bolt syou use Hex 17, with lug nuts you need Hex 19, but in either case the stud/bolt are M14x1.5 pitch.
a_CQ
p.s. Why can't you use the hubs with your brakes?
frostyflax17
- Contact:
the lugs i had laying around are m12's but are still a 19mm socket, they are what match up on the TT's studs. maybe the adapters i have decrease the bolt size? i'll have to look into that. I know that I could take off the nuts i have on the porsche and use them with your studs, but the TT ones won't work sadly. Hence why i asked if you still had yours lol
anyways, the urs4 machined hubs put the rotors at a 3mm offset (avg depending on how much was machined) compared to the s2 hubs. my caliper carriers are machined to work with s2 hubs, they would need about 3mm shaved off for them to work with my big reds. otherwise the rotors are too close to one side vs the other.
I'll have my carriers machined and re-anodized (steel), and then i'll use your hubs and brakes on the nicer pearl car that's getting the stronger motor
Cory
11 Touareg TDI - Daily
91 CQ - Lifted Rallyx Mudder
90 CQ - 3.0T Rombotis
90 CQ - Wannabe S2
91 200 3b - restore and sell
86 Yamaha Fazer - Cafe Conversion
90 CQ - Wannabe S2
frostyflax17
- Contact:
picked up some winter wheels, going to keep the 4x108 for a lil bit and put the hubs on the other coupe
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
frostyflax17
- Contact:
more presents
going to get painted i think before i get them mounted
plugs and wires are odd, i'm going to have to do some weatherproofing and figure out how to wire the suckers up better.
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
Glad to see they showed up in one piece. The wireing shouldnt be too bad. Looks like a standard single bulb to 2 bulb split. It does look like they could use a good rewire though. Have fun. Any thoughts about selling the B4 euro's?
audiPete
put some 3m or stongard-like protection on those lenses...you don't want to know how difficult it is to replace the sealed lens/reflector in the headlight assembly, basically the bracket must be carefully cut off and re-glued if you can even find a replacement valeo unit.
Wiring? you will need to find power and ground for the relays, and then an H4 pigtail if you still have the stock headlight wiring.
frostyflax17
- Contact:
actually from the previous owner he said they're wired for b3 plugs... i'll dive into it next time i'm home. looking forward to having a different front end
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
audiPete
thats an H3 blade connector in the picture with your hand...not a B4 headlight connector (round connectors)
frostyflax17
- Contact:
^^sorry, edited after you posted that. meant to say b3. now i have to switch it back. good thing i kept those connectors. i wish these headlights were a bit more sealed. there's no back to it at all.
p.s. that's my sisters hand... notice the nails. lol
i haven't even seen these in person yet as i had them sent to my parents where my garage is
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
audiPete
frostyflax17 wrote:^^sorry, edited after you posted that. meant to say b3. now i have to switch it back. good thing i kept those connectors. i wish these headlights were a bit more sealed. there's no back to it at all.
I'ven seen longer nails on guys, <ducking> but I digress...
I have a the original Votex assembly instructions, I'll scan them and send them to you...
frostyflax17
- Contact:
well... 225/55/17 tires really don't work too well with a 20mm offset. the tires sit right below the fender.
lotsa rubbing with any bump or turn. but damn do they look beefy.
popping the coilovers on tomorrow and raising the car to fix the problem.
rally car status soon to be achieved.
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
frostyflax17
- Contact:
Alright, Pictures.
i installed the 2bennet coilovers, covered the threads with antiseize then wrapped them in vinyl tape to protect them. I have them set as high as they can go in the front, and the rears are just a few threads down. This achieves an overall ground to fender of about 27.5" compared to the 24.5" on most front coupes stock.
Tires are 225/55/17, they're a bit big... i wouldn't recommend going this big as i go have some rubbing issues when turning tightly. but in a straight line and around corners at speed there's no problem.
I have a slight issue with one of the rear tires hitting the front of the fender wall corner. Not sure why my wheel is so off centered? How do you fix this?
compared to front
roof rack and votex headlights are installed as well, i think it looks pretty good from the front. lights not as good as the b3 euro's or b4 euro's though.
more pictures.
compared to front
more pictures.
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
a_CQ
Re: Frosty's Faux Rally CQ - Lifted With Beefy tires and Lig
Nice. The LR wheel is not off center, just appears like that. Because you lifted the car it essentially pushes the wheel forward - see how your strut is angled. I can't tell how the RR sits from your pics, but you may try correting this by moving the subframe, and ball joints, but you won't have too much wiggle room. Go with proper AR tires.
frostyflax17
- Contact:
the rear right has more room then the rear left (possibly because i'm missing the trim piece). it really only needs about 1/4 of clearance. It's just rubbing against the trim piece, and only under hard turns/acceleration.
I wanted to go with a taller tire for winter, but i just went a tad too high.
a 225/50/17 series woulda been better. the tires i believe are 26.9" tall. a 26.5 would of been just fine. I also believe that because my offset is so far out that is an issue as well. I was a guinea pig, and i can now tell people what NOT to do. And that's how we learn.
Still love the look of this though. hah
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
Dan McBoost
rally car status achieved (since the car was rally crossing yesterday!). Pics soon.
frostyflax17 wrote:Tires are 225/55/17, they're a bit big... i wouldn't recommend going this big as i go have some rubbing issues when turning tightly. but in a straight line and around corners at speed there's no problem.
Probably you can put the right size tires on those rims. That size is OEM for A8 and Allroad. I had them on my S6 avant and they were goofy and also rubbing. Wait for the right dip in the road and You will destroy your fender liners, tires and probably more.
That size is equal to 255/35/19, think about it.
frostyflax17
- Contact:
^^just did a rallyx with said tires and only rubbed a little. I'm only rubbing the front flexible part of the fender liner, i'll trim that up or bend it forward soon. In the rear the rubbing stopped. just needed to put a lil groove in the plastic trim.
plus, i do plan on lifting the car some more in the future. i need to trade the springs, these are short and stiff. i need taller and softer.
Dan McBoost wrote:[/quote]
rally car status achieved (since the car was rally crossing yesterday!). Pics soon.[/quote]
i had so much fun dan it was ridiculous. can't wait to see some of these pictures.
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
outonthetiles
Great job yesterday man! It was neat to have 2 coupes at the same event. What a difference your tires vs. my all seasons made!
frostyflax17
- Contact:
Couple pictures thanks to some of our local talent!
me driving my car
IMG_5138 by TheKeyMaster, on Flickr
rafe driving his car
IMG_5106 by TheKeyMaster, on Flickr
rafe driving my car
IMG_5632 by TheKeyMaster, on Flickr
me driving rafes car
IMG_5641 by TheKeyMaster, on Flickr
oh, and Joe driving his 4000
IMG_5558 by TheKeyMaster, on Flickr
once again, thanks to Jim with his photography!
me driving my car
rafe driving my car
Cory
90 CQ - Wannabe S2
90 CQ - Wannabe S2
Looks awesome Cory! Nice to see some people out beating their quattros like they were meant to be driven.
Tonks4x4
Frosty's Faux Rally CQ - Lifted With Beefy tires and Lights
Just read this through from the start....
Nice work, glad the bumper arrived safely and all fitted as it should
I really like the all red coupe rear lights I have got to get me a set of them and a US licence plate holder to match.
You can keep the US front end styling!!!! Man, are those bumpers ugly
Dan McBoost
Two of my old cars being what I wanted them to be:)
My pics shortly:)
My pics shortly:)
