AngryTaco
Re: Taco's 4KTQ 20vt Swap: Project Red Baron
Post by AngryTaco »
HOLY SHIT!!! So you're telling me I picked up a $1000 intercooler setup for $30?!
40v4kq
Post by 40v4kq »
Uh, well, thats what it looks like. Just yours has chrome piping instead of black. Thats a good score.
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
AngryTaco
Post by AngryTaco »
Damn! Now, I'm excited again. Most likely yanking the motor out on Sunday
40v4kq
Post by 40v4kq »
Dont get too excited, I dont want to see anymore parts removed by an axe. LOL.
Does your intercooler say "NEUSPEED" on it? I just went back and actually read the words under the pictures. I guess its made by neuspeed.
Dan
1984 Ur quattro
AngryTaco
Post by AngryTaco »
Yeah, I'll check tonight on the Intercooler when I get home. That HVAC box had it coming. It made me angry
AngryTaco
Post by AngryTaco »
Engine is on the ground. Pictures to follow!
WOOT! Pics!
AngryTaco
Post by AngryTaco »
Brought the trans and subframe to work and steam cleaned all that nasty shit off
AngryTaco
Post by AngryTaco »
I'm dropping the rear subframe this weekend and I'm going to fab up the sway bar next week. My FWD sway bar is getting mounted in the front and I'm relocating the front quattro sway bar to the rear.
AngryTaco wrote:I'm dropping the rear subframe this weekend and I'm going to fab up the sway bar next week. My FWD sway bar is getting mounted in the front and I'm relocating the front quattro sway bar to the rear.
Sounds like a familiar equation! Projects looking good!
AngryTaco
Post by AngryTaco »
Yep! I have a set of front A-arms with the sway bar mounts that I'm going to try and mount the bar into. That'll make the center mounts so much easier to fab up. I just hope the bar will clear what I'm going to do
AngryTaco
Post by AngryTaco »
Wanted list updated. Pictures of rear sway bar coming soon. Figuring out if I should buy the blau stuff or fab my own up
40v4kq
Post by 40v4kq »
Look up Ben's thread (extreme90path) and do what he did for the rear sway bar. I'm sure it's cheaper than the blau stuff and looks good. EDIT : Dont throw out the jt oil pan, you need it for the swap unless you have a 7A oil pan.
Dan
1984 Ur quattro
AngryTaco
Post by AngryTaco »
Yep already knew that about the oil pan 40v. So I did a mock installation today with the sway bar and it litterally slides right into place with the front a-arms in place of the original rears. Prolly going to fab up the cent mounts tomorrow or Mondy
40v4kq
Post by 40v4kq »
Awesome, and great progress so far. You work pretty fast. I badly want to hear this thing ripping around. That should be by the end of june, right? LOL. I've said it before and I'll say it again...I love 20vt 4kq's. Your is even the right color :wink:
Oh, dont forget that now is your chance to de-gunkify the engine bay. You alrady did good by not cutting the front support out, now go another extra mile and make that bay shine :-)
Dan
1984 Ur quattro
AngryTaco
Post by AngryTaco »
I plan to have this done at latest, end of May
mr_aj_johnson
Post by mr_aj_johnson »
Good work.
AngryTaco
Post by AngryTaco »
just need a set of rear HD Bilsteins for the 4k struts and the rear suspension is complete!
rs4tech
Post by rs4tech »
awesome project. I am helping a buddy of mine do a 20vt in his B3, so I am subscribed because I am sure some of my questions will be answered here.
AngryTaco
Post by AngryTaco »
I've found insufficient information on the wiring, so I'm going to be doing a full documentation on the wiring to help others doing the swap. I'll try to draw up some good wiring diagrams too
looks good. Hope my B3 20vt comes out as nice.
AngryTaco
Post by AngryTaco »
What color should I paint the engine???!!?
I'm thinking either red or black. The engine bay is red also. Add in the shiny aluminum head, a white valve cover, white timing cover, and the polished urq igloo and other intake stuff.
Thoughts?
Paint that engine semi-gloss black. It will look really sharp!
Rogviler
Post by Rogviler »
AngryTaco wrote:I've found insufficient information on the wiring, so I'm going to be doing a full documentation on the wiring to help others doing the swap.
Wait, so being told "It's been documented 1,000 times, search the forums" didn't make it magically appear?? :roll:
I'm aiming for 100% documentation with my build too. Wiring is next on the list. It'll be cool to compare notes. As far as I know there isn't a correct complete diagram out there, so respect for doing it.
Good luck! Don't fry anything. :)
-Rog
AngryTaco
Post by AngryTaco »
extreme90path wrote:Paint that engine semi-gloss black. It will look really sharp!
Was strongly considering that too
