Aarons Drag CQ: 3-29 anodized and welded stuff. AN lines
are you glad to not have tossed in the towel? :hide:
i cant contain myself waiting to hear that "exhaust" system well haha dp/header make some serious noise :woowoo: :woowoo:
speeding-g60
Post by speeding-g60 »
haha. ya. it will all be good here in a day or two.
i cant wait for the first start video.... i have a cool plan there.... :o
damn looking awesome, i got all excited at the top of your post when you said you were driving all morning!! but i was pump faked header looks awesome all wrapped up. sooo badass cant wait, im sure youre more excited than anyone :woowoo: :woowoo:
Wizard-of-OD
Post by Wizard-of-OD »
speeding-g60 wrote:and the ADHD factor is on HIGH today. may have to go take a pill.... i will start something, then move to something else, then back, and on to yet another, and back.
fiddle sticks SON YOU AINT LIEING!!
I am so excited right now :woowoo: :woowoo:
Congrats Aaron!!
repomanpro
Post by repomanpro »
I love the step by step photos.
It's like watching a hot stripper....wow nice, Droollllll :jawdrop:
I am glad to see you got the engine back from Joey let me know
if you are going saturday Import challenge i will come film.
speeding-g60
wiring done except for starter wire. the main power to starter is done. just need the last wire there.
all block and valve cover venting is complete. changed a little on the block line. now it is perfect.
i plan on going to Import Challenge to shake it out. maybe a couple light pulls to check steering, braking, and AFR.
i do want to do a good hard launch, and i do want to see full boost in 3rd for the 1/8th mile time. can guess from there the final. but i do not want to PUSH IT until Waterlands....
speeding-g60 wrote:NEEDED FOR RACE DAY
driver side door bar needs made. DONE
fill trans. drain and fill rear diff. anytime
install sunroof panel after rear brace installed. DONE
final mount seat and seat back brace. DONE
install harness. DONE
cooling lines need finished. WORKING
run and terminate the sender units for engine monitoring stuff. DONE
finish plumbing oil cooler lines. DONE
figure out plumbing on the dual WG's. ADHD think while working LOL
gotta mount the radiator overflow can, and plumb it in. working
gotta take it to get aligned once i am done dicking with the suspension this week after it is running. and a weigh in will commence that same time WOOHOO!!!!
Needed, but not necessarily for the big first day :)
figure out brake lights maybe. thats low priority though.
wire in the driver window switch.
still have yet to think about limiting the front end.
remake the WG dump tubes with SS flex tube for that.
need to finish welding closed all the unused holes on the firewall.
:-D :-D :-D
speeding-g60
ok. so i am done for the night. its hot out, and i am a sweatin.... FONKY, i say....
here is what i gather that i have left.
i need to join a 3/4 and a 5/8 hose for cooling from reservoir to t-stat side inlet.
i need to grind down a 36mm socket and make it thin walled to tighten the axle nuts on the rear of the car.
i need to replace the LCA bolts on all 4 corners, IIRC. i used old ones just to put together...
i want to put locknuts on all the mounts. so trans and rear diff need done yet.
plumb wastegates and boost control solenoid.
wire boost control solenoid.
run line to vac/boost block.
wire in a relay for starter. not NEEDED, but will do as i put a spare on the board.
wire in shift light, after i steal it from the rabbit.
run the boost gauge line, and ECU boost signal line.
i ran out of hose clamps for the cooling lines. i have them somewhere, but i dunno where they be so i will just get new ones.
mount coolant bypass catch can.
make turbo drain line and catch can drain line.
mount coolant reservoir.
fill coolant and oil and RACE GAS!!!! C-16 baby, love the blue shit....
install the intake manifold after the coolant line is done.
mount throttle cable.
make a shield for the wastegate dump, or a coupler and route towards the rear.
mount cooling fan to radiator. wire is there, just needs connected and ground.
wire the fuel pump to relay, its at the panel. and ground pumps.
maybe make a shield for above the exhaust manifold.
close up one set of holes on the firewall, on driver side.
bleed clutch line. Motive Power bleeder and Speedi-bleed on slave will make this 5 minutes if that.
make a screen for the turbo compressor inlet.
make hard stops for gas pedal and clutch pedal.
plug in ECU, and align TPS.
fill trans, drain and fill rear diff before driving.
prime fuel system, checking for leaks.
fire the bitch up and watch things.....
spin the thing down the road.
4 wheel burnout in my street.
brake-boost (2-step) to hear turbo spool up.
speeding-g60
crankcase breather
radiator
boost charge piping. all one piece of it :)
and goodnight. we all know i will go back out and do SOMETHING, cuz its that close.
i will fire it up tomorrow for sure... video later on tomorrow.
zerb
Post by zerb »
jealous.
speeding-g60
you got PM, J
fasterthenrs2
Post by fasterthenrs2 »
Aaron is the big turbo mapped to pink engine or you will need to tune that
derrish_vulf
Post by derrish_vulf »
Christ you dont mess around!!
In for vids of burnouts up your street!
speeding-g60
Janis, it will need to be tuned for that. may try to do that this week. we will see....
NOTE TO SELF: next time, wait until you make the oil return lines before filling oil. (runs off to store to buy another gallon of oil ) :slap:
lucas13dourado
Post by lucas13dourado »
what a noob! :P
get er done!!! :bashtard:
fasterthenrs2
speeding-g60 wrote:Janis, it will need to be tuned for that. may try to do that this week. we will see....
:lol:
:lol: :lol:
Wizard-of-OD
:-D
speeding-g60
i should be wearing my shirt today....
http://www.bewild.com/adhdtshirt1.html
8 things on the "list" just to start it up.
fasterthenrs2
Hopefully
1. Get in a car
2. Flip the start switch
3. Make shore no fuel leaks
4. Crank car with out ecu plugged in till oil pressure comes up
5. Plug ecu to 12V
6. Get out of the car push record button on a camera
7.get back in in a car
8. Start car and scream like a new born
That be to easy do, I think. Please prove me wrong, god luck mate wroom wroom
death 4kqt
Post by death 4kqt »
fantastic! I sure hope you get it to start tonight, that coupe is so mean looking.
speeding-g60
soooooooo. it fires up, but i need to play with the idle.
i made a vid of priming the oil system, but thats boring.
it wont stay idling, but i will sort that out later.
i have ONE LEAK for the whole system. the lower radiator hose i used a spring clamp, ran out of hose clamps. i will swap it out later. its just a tiny dripper, dont matter for now.
video is uploading. will post it when its done.
maybe some dyno this week, definitely an alignment, and off i go.
it looks mean, yeah, but it sounds meaner. sounds pure race.
some pix to tide you'ns over for a bit.
OMG awesome!!!!!!!!!!! need vid argh!!!! :vids:
Belgarion115
Post by Belgarion115 »
:vids: :vids: :vids: :vids:
