I took the BLUE Pill. Engine bay painted
Re: I took the BLUE Pill. 10v-ectomy, it's time.
Like say next month. Like maybe the week before Thanksgiving!
quattro v1.0
We need to have a black-friday-boys-night at the speedway
Iroz Motorsport Black Friday Sale 8)
I should be able to make something on fri.
"I love it when a plan comes together!"
quattro v1.0
I need the A-Team from Overhaulin' to come do my engine bay. Should only take them like 20minutes.
where did that come from?
aw, If I had a stab at the cause, I would say spinning to 9800 on a stock oil pump probably isn't going to happen forever
No failures here, we are just heat treating the big ends!
quattro v1.0
crank didn't break ;o]
Thats cuz it is forged. Can't tell if it is a 6 bolt or 8, but it is forged by the looks of it.
AudiSport4000
I like where this is going.....
1986 4kq Commemorative Design
2012 Jetta TDI
2012 Jetta TDI
HeartlessNomad12
looks awesome, will be running by the end of the weekend right??
Holy crap. Holy crap. Holy crap.
quattro v1.0
It's out!
Next up is the 20vt garage sale that opens tomorow ;o]
:woowoo: Looking great guys!!!!
84urq20v
Wow - very cool guys. Very. Wasn't the big issue with this motor figuring out a way to mount it longitudially? I guess that's been solved...
Keep it up
Keep it up
I believe it simply requires removing some material from the transmission. Then you get enough holes lines up to secure the engine.
Darin
1989 80 20vt
1989 80 20vt
There is that and I believe the driver's side is a challenge...
I've heard there are a few other tricky areas.
In for results... this is going to be beyond brilliant!
quattro v1.0
Hank has been hard at it, the header is essentially done.
It's getting closer, but still plenty of challenges ahead.
HeartlessNomad12
I dont understand why its not running already!!
for gosh sake hank put in that mcmaster nut and bolt order in already. I see two pics of backwards EM nuts just so you can get enough thread on the stock EM studs to hold the new turbo EM on
