Reed's 95 //S6: Compressor Stall: Fixed
urs6ville
Post by urs6ville »
Current State of the car:
Engine
RS2 Turbo w/Billet Compressor wheel
VEMS
Wagner RS2 Manifold
Apikol FMIC
60# injectors
034 High Output Coils
044 Fuel Pump
RS2 MAF
Stromung Gen 5 Turbo Back Exhaust
Drivetrain
01E 6 speed with B5S4 gear set, hardened 1st/2nd, WPC'd 1st/2nd
Southbend Stage IV SS-X Clutch
Suspension
H&R 29800 Springs
Bilstein Sports
Weldon/Apikol RSB
2B Adj. Camber Plates
Binders
993TT Big Reds
d.b.a 5000 two-piece rotors
custom brackets
Wheels
Summer: 18" BBS CH 235/40 Hancook Ventus Rubber
Winter: 16" Fuchs 225/50 Artic X-Ice Rubber
Exterior
Clear Corners
OEM Euro Tails
S6+ grill
Interior
Boost Gauge in da' vent
OEM Carbon Fiber Trim
Re: Reed's 95 //S6
Welcome Reed! I can't wait to see this car back on the road with a built motor.
Re: Reed's 95 //S6
Such a "cool kid" now... ;)
urs6ville
Re: Reed's 95 //S6
Post by urs6ville »
Hank wrote:Welcome Reed! I can't wait to see this car back on the road with a built motor.
Thanks Hank, you and me both! Haven't been able to realize the solid potential of that billet RS2 yet.. can't wait.
Re: Reed's 95 //S6
Welcome Dan... glad you found us. If you want your entire project thread ported over to this forum, send Marc a PM.
Re: Reed's 95 //S6
Hey update here too, ya bum! :)
S4Pirate
Re: Reed's 95 //S6
Post by S4Pirate »
:metoo:
Re: Reed's 95 //S6
Super clean looking car, would be nice to see from another few angles :)
Re: Reed's 95 //S6
Unfortunately this has been the angle that both Dan & I have been seeing of our cars lately....
S4Pirate
Re: Reed's 95 //S6
Post by S4Pirate »
Any updates with you OB?
urs6ville
Engine swap complete!
Post by urs6ville »
The engine is finally installed. I will be putting up a bigger write up about the process, but in the end we swapped out the old engine, took off the important bits and installed on fresh engine, and re-installed in to the engine bay.
There were a few hiccups but for our first time, I think it went well.
This was a process that started last August when I sourced an engine with a blown head gasket.... here are pics through the process:
Picked up the engine and brought it home in Dad's trusty econoline van
Tear down progress, gasket was blown around cylinder 4
Quite the collection of parts
Crank from blown engine
Close up of timing marks on cams while installed (before taking it apart)
Taking apart the head, tedious work
Stock rods to be replaced with SCAT rods
Cleaning the pistons (reused the stock forged pistons)
Pistons clean, SCAT rods installed
Crank installed in fresh block (block was cleaned, fluxed, decked and honed), ARP main studs
Refreshed head. Left it pretty stock, plan to take the head off engine that is currently in my car and building a head. No in the cards right now
Rods/Pistons installed
Bottom end all closed up
ARP head studs in
Head installed
Tommis Billet crank cog
Reference PIC of N75 before puling the engine
Front end off, disconnecting things
Engine out
Tired Engine (head off)
Ready to pull EM and Turbo off old head
Fresh
Installed in engine bay, left intake off so we can connect everything with ease
Everything back together (my brother approves)
Bent valves that caught us in the middle (more on this later)
Ready for Bumper and lights
urs6ville
Re: Reed's 95 //S6: First Tuning Session
Post by urs6ville »
Finally got a tune on Sat up at EFI Express on Sat with all the E85 boyz.
As has been discussed there is a limit on the -6 hot side of these turbos. I was able to top out with an uber safe tune at 300awhp/300awtq @ ~25psi. Marc created a really smooooooth tune. Still waiting on the graph which I will post. My old ECU was an Uncle Bob version and pinged like crazy. No pinging here despite the ~100 degrees temps in the shop.. and damn near 100% humidity. While I expected more, I am very happy with the power delivery and the smoothness.
One of the E85 boyz had the same setup (Except for a port/polish'd head) and hit 405awtq on the corn, so I guess if I ever want to go that route I know approx what I would get.
Re: Reed's 95 //S6: RS2 Billet Pump Gas Tune
Nice. 100% humidity and temps is not too friendly to any turbo, especially one that is on pump gas. If you are really feeling down on the power output, as Marc to overlap a 3071r at 25psi in similar conditions with your billet rs2, an you will start to feel better. On pump gas, the rs2 is not giving much, if any up to a 3071r.
urs6ville
Post by urs6ville »
aforementioned dyno graph
urs6ville
Post by urs6ville »
Hank wrote:Nice. 100% humidity and temps is not too friendly to any turbo, especially one that is on pump gas. If you are really feeling down on the power output, as Marc to overlap a 3071r at 25psi in similar conditions with your billet rs2, an you will start to feel better. On pump gas, the rs2 is not giving much, if any up to a 3071r.
It's not that I am feeling down per-say, just been a long road to feel like I got back to where I started from. the results are pretty much around others with RS2 and MRC/Pastore and other RS2 tunes, albeit the power in my case is delivered quicker, which is nice, and the tune is safe and obtaining the power at a lower PSI.
That said, this tune is much much smoother that my ECU was before... doesn't feel as powerful because it doesn't have the crazy "shot out of a cannon" feel of my previous but the power is smooth and pulls longer.
urs6ville wrote:It's not that I am feeling down per-say, just been a long road to feel like I got back to where I started from.
The e85 station I plan to use is closer to you than it is for me... A simple fuel change and a tune & you're good...
Getting nice VP gas tanks and getting a full tank plus 15-20 more gallons works reasonably well. I have done it, as I am 10-15 miles out of the way to get e85 where I am at.
S4Pirate
Post by S4Pirate »
I R Lucky
urs6ville
Post by urs6ville »
Hank wrote:Getting nice VP gas tanks and getting a full tank plus 15-20 more gallons works reasonably well. I have done it, as I am 10-15 miles out of the way to get e85 where I am at.
Yes, E85 really isn't inconvenient for me either.. I don't daily drive, there are ~4 E85 stations within 10 miles. I'll probably take a look at an E85 tune at some point so I can swap over with the VEMS when I need to.
dat e85 is nuts
DuBistS4
Post by DuBistS4 »
I can send you my e85 base tune....it worked for shebs car...
'94 UrS4 Red/Black
Vems
Lightly modded head
-Will
You don't happen to have a graph of the old tune do you? It'd be nice to see a comparison.
on my stinking phone!
urs6ville
Post by urs6ville »
DuBistS4 wrote:I can send you my e85 base tune....it worked for shebs car...
that would be be cool, i'll keep that in my pocket until I decide to switch over and go up to Marc's again for a second tune... just started reading through some e85 material... I see the different AFR so pump gas tune wouldn't work, makes sense.
Right now just enjoying having a proper RS2 car back :)
urs6ville
Post by urs6ville »
chaloux wrote:You don't happen to have a graph of the old tune do you? It'd be nice to see a comparison.
nope, my engine never made it through that tuning session
Marc is working on some map switch stuff which may turn out to be the ticket for the gassers :)
