Had a little progress on the car today. All of my toggle switches have a purpose now lol...
one is for shift cut, another is launch control, then ignition, then diff lock switch thing
The main thing we did was make the shift cut work. The problem was that the only way we could have it wired up before was inverted. Its hooked up to the clutch switch. The clutch switch gets ground when the pedal is OUT though. We need the switch to give ground to the ecu when its in.
The easy way to do that is to go into megatune and switch the channel to "inverted"...however, all of the channels EXCEPT channel 7 which the shift cut is wired to has that. So we had to take a relay and make it "inverted" that way.
Next up was wiring the diff lock thing. When the switch is on, it will allow the car to turn the diff lock off above 15mph. When its off, the diff lock will work at any speed
Finally, we wired the power for the coils to a relay. Before it wasn't on a switched source...so thats not very good. We also put it on a toggle switch just as a little anti-theft feature. (the switches aren't labeled
The only problem is that when we went to start it, when its cranking, it doesn't give power to the coils lol...so it will crank and not fire...then as soon as I let go of the key, it will fire. I have to find a wire to tap into that is on even when the car is cranking, but is also switched.
Anyone know of one thats in the general dash area?Im pretty happy because now everything is right with the exception of the ignition thing, and the fact that the chip for the launch control is burned out in the ecu.
also, I just realized that 2B's coil kit isn't a bad price...I would be all over it if I wasn't set on bags.
I would like to have a set of sport quattro seats
, too bad that will NEVER happen. I'd like to have a roll bar (at least) and a pair of Corbeau's in the car though. I honestly just feel safer with a 4-pt. If I did do that, I'd make it as unobtrusive as possible and get it powdercoated in pearl white 8)
