Locked
justrack
Post by justrack »
Looks like today didn't go to well for you. Maybe through some logs up of it if you can.
I had bad day with car too :(. My fuel problems got a lot worse. It turns out my fuel return line inside the tank is plugged. tried unclogging it but no luck, so i need a new tank. I hooked up a fuel pressure gauge to the return (should be 0 psi) and it pegged the gauge at 100psi, so this is why i kept blowing regulators. i hope the injectors are ok. I've heard the fuel tank is a nightmare to drop since you have to drop the exhaust and driveshaft too. prolly just cut and weld it (the exhaust). Right now i've got the return hooked up through the vent line for the charcoal canister, kinda ghetto but it beats running a garden hose to the fill cap on the side of the car :tard: .
lol dam man, o well at least your problem is something you can fix and be done with
my problem NEVER ENDS
I started it up today and it just turned off by itself about 15 seconds later. Then I started it back up and it drove fine for 15 minutes. Then it drove back home later tonight for 15 minutes without a hiccup too.
I'm going to have to put it back to stock again to make the trip to Tampa (Wednesday) and Gainesville (Saturday) for peace of mind.
On the bright side of things, I attempted to teach my girlfriend how to drive a manual last night. She did quite well! We still aren't ready to take it to the streets yet tho. She was a little worried when the car stalled a few times (because of the ECU...not her :( :roll: :wtf: ), and also when the RPM's started going up without anyone touching the gas pedal (again wtf). That one hasn't even happened to ME yet while driving this car.
Regardless, she was able to start off in first gear relatively smoothly and shift to second alright a few times. Other times she had a really hard time figuring out where the RPMs needed to be in order to make the transition into second smoother. I'll just tell her to keep her foot off of the pedal next time and focus on making the clutch smooth.
trbo qtro
Post by trbo qtro »
haha well it will give you a good reason to put in that serious clutch after the gf burns up this one :bashtard:
Justin517
Post by Justin517 »
I need to teach the girlfriend manual too... my mom asked me to teach her too.
tried driving the car today and it stalled 3 times before I could get down my street.
dammit
please chime in if you can because I'm about a minute away from putting it all back to stock AGAIN.
See the config dump in this thread and read my last post
http://www.motorgeek.com/phpBB2/viewtopic.php?t=29275
yodasfro
Post by yodasfro »
I'm no expert but I'd put the stock ecu back in stop screwing around with the vems.
haha yes, I agree. I just want something to workkkkkkkkkkkk aghhh
yodasfro
Post by yodasfro »
Obviously the ecu you got isn't working and I would highly recommend trying to get a refund for it. And then I would contact Marc and get a real VEMS ecu and have him tune your car otherwise you are just wasting time and money IMHO. :horse:
Yes, the thing is I have TWO VEMS units and they both have problems with values changing, etc.
I just have a feeling its all in the configuration or something stupid like that.
Kevin has done his best to help out :/
If something doesnt get worked out then I would definitely like to talk to Marc, but VEMS sorta worries me a bit at this point.
Toxcheap
Post by Toxcheap »
After reading all this I leaned over and gave my IIC a kiss :lol:
hate you lol
yodasfro wrote:Obviously the ecu you got isn't working and I would highly recommend trying to get a refund for it. And then I would contact Marc and get a real VEMS ecu and have him tune your car otherwise you are just wasting time and money IMHO. :horse:
:stupid: :stupid:
mmmm 034 efi support
Toxcheap wrote:After reading all this I leaned over and gave my IIC a kiss :lol:
:lol: :lol:
Toxcheap
Post by Toxcheap »
loxxrider wrote:Yes, the thing is I have TWO VEMS units and they both have problems with values changing, etc.
Sorry
loxxrider wrote:Kevin has done his best to help out :/
It doesn't seem like it??
loxxrider wrote:If something doesnt get worked out then I would definitely like to talk to Marc, but VEMS sorta worries me a bit at this point.
So when you put your factory ecu in the car runs fine?
The 3B/AAN stuff can be pretty sensitive when it comes to trigger hardware configuration and config setup. Last I knew, Kevin builds all his ecus in house rather than having the company build them (which as far as I know is why he calls his systems "lugtronic", even though it still is VEMS hardware internally). I've got several projects going on right now that prevent me from just giving away free support time to help Chris out. Judging by the symptoms it sounds like a combination of dodgy stock wiring (the stalling in the rain problem) and some software compatibility problems, both of which are fixable given proper diagnostics.
Yes car runs fine when the factory ECU is in.
I thought it was running iffy in the rain...but now it seems that that was just a coincidence since it has been bright and sunny the past few days and i couldn't even make it off of my street today.
I'll check all the grounds that need to be checked, I just dont really know where to start. Most of the wiring in the car looks mint.
Toxcheap
Post by Toxcheap »
loxxrider wrote:Yes car runs fine when the factory ECU is in.
well if it runs fine with the factory ecu, its got to be the vems, hardware or software there is an issue
Agreed, but maybe the VEMS is less sensitive to a bad ground than the stock ecu or something?
When I think logically about it, that seems very unlikely, but I hate to blame EVERYTHING on the system.
I feel uneasy blaming VEMS too. You say that Kevin is not to blame, but I would be livid if I had a car that didnt work after 2 months..
Toxcheap
Post by Toxcheap »
ShavedQuattro wrote:I feel uneasy blaming VEMS too. You say that Kevin is not to blame, but I would be livid if I had a car that didnt work after 2 months..
The car runs fine with the stock ecu though
I'm not saying the box is definitely defective, I'm just saying the problem is definitely stemming for the ecu. Whether it be the tune, configuration or installation. This is a plug and play box right?
:stupid: so why are you running the VEMS already? have you do extensive mods? anythign wrong with a oem ecu w/chip for now?
I bought it in august and the first start attempt was in December...
Yeah, thats what my brain is telling me too.
my2000apb wrote::stupid: so why are you running the VEMS already? have you do extensive mods? anythign wrong with a oem ecu w/chip for now?
Because I knew there would be bugs to work through. Thats just how it is with standalones. I thought maybe a week or month of bugs though. That way when I went to a big turbo there would be nothing to do but tune.
After all of this, nothing is wrong with stock ecu and chip lol.
If I do end up getting money back, then I may very well just buy a chip and coils and call it a day for a while.
123quattro
Post by 123quattro »
Buy the IIc that's in the classifieds for $900. It would be money well spent.
I would, but I need money from this ECU before I can do that :(
**edit** ouch its sold
back to stock now...no fun
loxxrider wrote: I do end up getting money back, then I may very well just buy a chip and coils and call it a day for a while.
if? :slap:WHEN
yeah best thign ive heard in a while
yodasfro
Post by yodasfro »
:stupid:
Locked
