ok i tried burst mode and I guess I dont know how to use it. It didn't log anything.
Anyway, this time the car backfired pretty hard up around the same RPM range as I mentioned above. My roommate was in my apartment and heard it with all the windows closed. The main road is like 250 yards away.
The power goes away for a split second (you can feel the car miss) and then it pops a split second after.
nuugen
TheArchitect
loxxrider wrote:ok i tried burst mode and I guess I dont know how to use it. It didn't log anything.
I really dont think you are getting 20hz out of it, if you can log to a file and there is a time ref from the laptop then you can gauge the rate it is actually logging at.
Back when we were trying to find a difficult bug "the glitch" on the 034 ECU, I determined that somehow the ECU was resetting. Since it happened every other blue moon I had to add a "seconds since ECU reset" object to the GUI that allowed me to determine that a reset had occurred (since I couldnt be there for the many hours it took to manifest the problem).
This said, is there an item such as "powered seconds" or equiv that comes from the ECU (not from the laptops time) that will tell you that the ECU has reset in such an event?
In the case of the 034 ECU, that parameter and many other important diagnostic info is put into the log file. Stuff you wouldn't normally even what to know about, but allows someone a better window into the CPU after the fact.
TheArchitect wrote:loxxrider wrote:ok i tried burst mode and I guess I dont know how to use it. It didn't log anything.
Well keep in mind this is second gear pull, not third. Definitely not doubting you though. There is a seconds thing in the log. You can see it where the cursor is. The only thing I used to see when the ECU actually did reset was the time would jump a few ms.
TheArchitect
loxxrider wrote:TheArchitect wrote:loxxrider wrote:ok i tried burst mode and I guess I dont know how to use it. It didn't log anything.
Not sure of the relevance to what gear its in, if you have a file logged and it has a timestamp, just count the number on entrees in say 10 secs and divide by 10 for the avg samples per second.
You may read the data stored in the file to see if there is something that definitely indicates that the CPU reset.
Otherwise its either an HW issue, a FW issue your somehow related to your tune.
To narrow down if its spark related, you might set the WG for a lower boost level and try another wide open run across the same RPM range.
If it never does it, then probably your issue relates somehow to ignition.
btw when I move the cursor along, it moves about 8 ticks per second aka 8 hz I guess?
There is an option to bump it up. Like I said before, its at 50ms right now. I guess I could move it down to go faster. Maybe 25ms.
TheArchitect
loxxrider wrote:btw when I move the cursor along, it moves about 8 ticks per second aka 8 hz I guess?
Only if it can actually log at that rate.
Based on the graph at the top, I dont think you are logging even at 10hz regardless of what its telling you the sample rate is.
anyone ever try NGK BCP7ES plugs?
I'm going to try plugs first and maybe some dielectric grease.
Kevin did some fuel tuning and we also decided to bump dwell to 4ms just for the hell of it.
pitten
I tried curing my own misfire problem with a set of new NGK BKR7E plugs, yes the cheap ones. The F5DPOR I pulled out actually didn't look too bad, except for cylinder 1&2 being sooty, and the NGKs at least didn't make it worse. Misfire persists, but there are more than enough possible culprits left to be checked. I'm not sure how much slack in the distributor gear can be tolerated for proper triggering. You think it's an ignition juice issue?
TheArchitect
loxxrider wrote:anyone ever try NGK BCP7ES plugs?
Dielectric grease is always good, if its already started arcing down the plug, the boot will never be the same even with the grease.
No load based dwell control?
4ms running around for normal driving is probably going to kill your coils in the long run (GM LS right?).
For some really high boosted engines we sometimes go all the way to 9ms of dwell, but below ATM, 2.5ms to keep the coils alive for a long time.
Also it may merit mentioning that "smart" active ignitors will spark early if the dwell exceeds its design limit, meaning if its designed "self preserve" at 5 amps, spark will occur early (advanced) if the dwell is high enough to cause the current to exceed its limits.
This can cause one hell of a misfire and a sure way of getting unplanned pre-ignition.
It has dwell @14v which is at 4 right now and it also has a setting for dwell added at 6v which is .52 (ms)
I'll back the dwell down. I'm just trying this out to see if its an issue.
pitten wrote:I tried curing my own misfire problem with a set of new NGK BKR7E plugs, yes the cheap ones. The F5DPOR I pulled out actually didn't look too bad, except for cylinder 1&2 being sooty, and the NGKs at least didn't make it worse. Misfire persists, but there are more than enough possible culprits left to be checked. I'm not sure how much slack in the distributor gear can be tolerated for proper triggering. You think it's an ignition juice issue?
I used to love the BKR7's on my 1.8t with garrett turbo. Noone seems to like them on these. They are also highly used on high horsepower boosted hondas a lot.
These motors seem to only like the Bosch ones for some stupid reason. I would definitely love a more readily available alternative.
pitten
TheArchitect
loxxrider wrote:It has dwell @14v which is at 4 right now and it also has a setting for dwell added at 6v which is .52 (ms)
Thats voltage related dwell compensation, its what allows the coil to fire off the engine when the motor is cranking.
What you really need is a map that allows you to configure the manifold pressure and or RPM and have a dwell setpoint that allows you to increase the dwell time as a function of load, since its under load when ignition energy needs increased to prevent a spark out.
I'd try the 4ms dwell time to see if the problem goes away.
If it does, I'm not sure what you can do to be able to keep the coils cool at light load and still be able to run the higher dwell time under high load as needed. This would require a variable dwell time proportional to VE/load.
You can increase the dwell to prevent the misfire but like I said you will be hurting your coils in the long run.
jcarrick
TheArchitect wrote:loxxrider wrote:It has dwell @14v which is at 4 right now and it also has a setting for dwell added at 6v which is .52 (ms)
Understood, thanks. I want to get off of this shitty megatune and into the VEMStune which is much better. I dont know if they have a load based dwell map like you are talking about, but I'm sure its possible.
jcarrick wrote:I'm not an expert on reading those logs yet, but from the graph it looks like you may be running a bit lean
What you are seeing is the lean spike caused by the misfire. Everywhere other than that spike is just fine. A little fuel was added here and there, but leaving it as it was would have been just fine.
123quattro
Ugh its so weird that they do this. There has to be a reason!! I have a sneaking suspicion that this is all because of freakin plugs. I guess we'll see when I try some out.
jcarrick
I had a very similar problem with mine. Any more than about 15 psi and it would miss extremely bad! I had some NGK Iridium plugs in it and then switched back to my old FD5POR plugs and it took it completely away! So I went and bought a new set (100$ later!!!) and it runs awesome!
Another thing, that may seem just way to simple, is to take off and clean your throttle body. Mine was idling a bit funny and I cleaned it out and it completely smoothed out the idle and has noticably better throttle response
Just a few ideas :-)
123quattro
