Derracuda's Project Alpine 4kq *Comatose*
AudiSport4000
I can honestly say Ive never curbed an aftermarket wheel, maybe my stock Ronals a few times when I first started driving it in 1999.
1986 4kq Commemorative Design
2012 Jetta TDI
2012 Jetta TDI
AudiSport4000
JShadzi wrote:If you're not curbing wheels, then you're not parking hard enough
True, but remember where I live. I live in hick heartland! I dont go downtown too often, and when I do I park in the parking garages.
When I was taking my driving test I thought it would be badass to totally ignore my instructor and try and parallel park without any advice from him. End result was I got inbetween the 2 cars but was about a foot and a half away from the curb, or more
.1986 4kq Commemorative Design
2012 Jetta TDI
2012 Jetta TDI
maarten
derracuda
according to martin pajak all the rear needs is to press a 5ktq hub in, the rear bearing ID is the right, and the larger dia. splines on the rear axles work in the 5ktq front hub as well. once i get everything put together, i'll post an exact list of what parts were used just so it's clear.
i'm going to be needing a set of rear 4kq shafts if anyone has some laying about, but they have to be the smaller inside CV's from 85 up.
LarryFlint
Highlander
Lt. Sarge
LarryFlint wrote:Do you have the motor in yet, all this talk about 5 lug, I thought the topic said "project 4kq *4.2 plans in the works now" are you just stalling?
Naw, Derek's just got 4 project Audis, is looking for another one, is helping me and my brother with our project Audis, plus has to meet a minimum quota of watching at least 2.5 hours of car videos and 1 hour of general humourous videos on youtube per day.
derracuda
derracuda
Highlander wrote:Happy Birthday Man,
here's a link to my 5 bolt conversion.
all the parts are listed here
[url]http://www.motorgeek.com/phpBB2/viewtopic.php?t=7269&highlight=bolt+conversionrl][/url]
link no good :(
http://ca.pg.photos.yahoo.com/ph/craigc ... DB0FTZdrls
derracuda
small update. i finally got two struts in a position that i could compare them side by side. this is for the five lug swap (that's for the search function
). i have a 5ktq front strut, and a 4kq strut. overall it looks to be about 10mm difference in how far the 5ktq strut will push the wheel outward. luckily, i think my B3 strut already has 5-10mm over the 4ktq strut, so i should be pretty close in the ball park with achieving my goals in tire fitment
measurements are as follows. (keep in mind these are as close as i can gather with a standard vernier measuring caliper)
-----------------------------------------4kq---------5ktq
hub face to strut tube centerline - 162mm 172mm
hub face to lower ball joint center- 70.5mm 75.5mm
strut tube centerline to bj center- 78mm 88mm
hub face to caliper mount face- 53mm 56mm
pics...
4ktq strut side profile
5ktq side profile
pics...
5ktq side profile
scottmandu
when I did hate 5 lug conversion on my 4the, I hacked the 5kqt tube off at the knuckle, then cut away the 4kq tube. the 4kq tube will press right into the 5kq tube, and then using the careful measurements you took before hacking correctly position the steering arm relative to the knuckle. (of course if you run really wide tires you can move the arm inward a bit to clear, you then have to take some slack out of the tie rod adjusters.
You just essentially made a urq strut, and you can use 4kq spring, shocks, and tie rods, with urq lower ball joints and any flavor of 5kqt brakes you want.
HT Motorsport
derracuda
HT Motorsport
derracuda wrote:i want the hub face inward as far as possible. ideally i'd have 5lug hubs in my 4kq struts
Gotchya - dont use V8 struts then
I played with the Idea of making custom machined 2 piece hub carriers AKA the IMSA cars. If you did that you could have your cake and eat it too
Basic Idea was to cut the old hub off, weld in a thick plate with some tapped holes in it, Then make up a 2 piece clamp part to go onto the strut tube which I would have externally threaded so I could adjust the height of the strut in the housing
derracuda
