Re: Derracudas zermatt 20vt,6spd, 351awhp - Battleborn Teste
Sounds great Derek!
Wiley Rankin Coffin
Mine
'87 Alpine White 4KQT e85 Xona - Toy
'16 Deep Black Pearl Golf R Manual - Stockish
Hers
'06 Deep Sea Blue 2.0T A4 APR Stage 1
derracuda wrote:Some 5cyl lovin'. 40v4kq and I went for a drive last night.
You forgot to mention that fact that you just couldn't seem to pass me the whole time.
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
1984 Ur quattro
Whats with the smoke on decel? You tryin to blow flames or somethin?
Also, why does it sound like its missing in boost?
40v4kq wrote:derracuda wrote:Some 5cyl lovin'. 40v4kq and I went for a drive last night.
What where you in my good sir?
>>> I still love your exhaust.
Sounds great Derek!! I liked it a bit better when sittin in the car, but then that's always better. You would think that for as far as you drove that you would have been able to find some blue sky somewhere, but I guess not. :(
extreme90path wrote:What where you in my good sir?
Technically speaking....the back seat. I had to make sure my camera didn't fall off. LOL
Dan
1984 Ur quattro
1984 Ur quattro
derracuda
loxxrider wrote:Whats with the smoke on decel? You tryin to blow flames or somethin?
yes, it does smoke on decel, it goes very rich. it needs some adjustments in that department. But I wouldn't mind some flamage
It is also missing. The spark is being blown out with the colder weather. I closed the gap down from .32 to .25 and the miss went from 12ish psi up to 22-25ish psi.
nice, just curious. Good work
Sounds good Derek. What coils are you using?
derracuda
ShavedQuattro wrote:Sounds good Derek. What coils are you using?
Just some 3.0L Toyota Camry coils. I can't remember what my dwell settings are, but I might need to make some adjustments in that department.
AH, I see. I freaking hate tracking ignition misses. Post up your ignition compensation table for dwell.
also be sure to check your plug wires... even swap some stock ones on if you have them. I had MAJOR problems with the ones that 034 and others sell.
derracuda
ShavedQuattro wrote:AH, I see. I freaking hate tracking ignition misses. Post up your ignition compensation table for dwell.
here's what I got.
Chris - They are Bosch plug wires with altered coil ends to fit my coils. they fit nice and tight, and I checked them for tracking/shorting, and didn't find anything.
Attachment ( 28872 ) : Dwell - Original.jpg
I need to know what your base dwell setting is at, and that is located in the configurations file under ignition...
KKquattro
Hi Derek!
I went through parts of your thread in order to find out whether or not the servotronic rack is more direct than the stock 4k unit, but I didn't quite manage to find a definite answer. Soooo, is it shorter?
Cheers
Cheers
derracuda
KKquattro wrote:Hi Derek!
Cheers
Unfortunately, the guy who sold me this rack (through a friend in Holland) said it was an S2 rack, which is supposed to be the shorter ratio. But whatever it is, is the normal 3 turns from lock to lock :( The servotronic portion I've found is not really all that useful since it doesn't consider the original pressure to be the "low effort' setting, and then reduce the pressure at driving speed. It's the other way around. The pressure is increased even more for slow speed driving so that you can't even really tell how the wheel it turning. It's like being lifted in the air, it's that easy. Quite amazing, but not what I was looking for.
I was thinking you didnt have servotronic. Ever get the misifire figured out? Or are you just gonna put a cummins in it and call it done
Dan
1984 Ur quattro
1984 Ur quattro
derracuda
I've got some new coils to put in, but haven't had time to mess with it. Hopefully here soon... I need moar boost again. I've been limited to the WG spring setting since the new year which is only 16psi or so.
Only 16 psi !!! You may as well have a squirrel under the hood. I sure with all the sitting the car has done there probably has been some squirrels under the hood
Once you get those coils in you should just swing by and take me for a ride.
Dan
1984 Ur quattro
1984 Ur quattro
derracuda
yeah, i'll just pop down
What coils are you considering? 2.0FSI?
Regarding critters under the hood. Watch out for rats. BTDT. Oh and toads.
derracuda
yeah, critters under the hood aren't a worry right now for me. The coils are some toyota 3.0L v6 units off a camry. They were cheap, but unknown mileage. they worked fine for a while, but I'm going go back to some MC/3B/7A coils which will take the stock plug ends, and should be strong enough to do the task.
derracuda
MC coils went in as of 30min ago, ignition miss is history. Man I wish I had done that months ago. 350whp is a freaking riot.
:stupid: Like maybe about 6 months ago? LOL. Glad to hear its back to making all that glorious horsepower.
Now go bolt on that gt35r and get 450whp :woowoo:
Dan
1984 Ur quattro
1984 Ur quattro
