a_CQ wrote:Wouldn't it be cheaper to buy a block that has squirters already? I think machining for those = $$$
im not even going to do it anymore, ill let it blowup, not worried
itll only be ~250 hp anyway
Toxcheap wrote:Well in that pic you can see how the 5k shifter would bolt right in and just need the boot and rods. The b5 S4 uses a different style shifter all together. I have a picture uploaded here some where. I'll try to find it. Generally you use the b5 s4 linkage when you get a b5 01E and the urs4 linkage when you get the urs4 01E
my2000apb wrote:but i will def spin it by hand first no matter what
my2000apb wrote:~225whp
I purchased this 4kq from a member here, CooterIFY, and my friend, Toph, who will be registering here soon too, bought his 200 20vt as part of a package deal. He was being deployed and would be unable to store the cars, so we will be takign over where he left off, in the preservation and modification of the cars!!!
it has about 175k miles, there is a bit of surface rust, and several small dents and plenty of minor dings. although all my windows work, the sunroof works and closes/opens swiftly, Both power windows work! te interior is UBER clean, i may end up swapping the dash to my T-red car ahaha, it also has an almost fully functional trip computer.
the car was originally zermatt, but was sprayed over with some zermattish, but much lower quaility paint.
the gas gauge doesnt work, prob jsut the level sender
a/c doesnt work but all the parts are there
also cruise control doesnt work but the parts are all there aswell
as i already have a minty clean summer only 4kq, so this ones getting comissioned to year round duty, ill remove the a/c most likely, eventually itll be converted to a 16vT, as to lighten up the front of the car a lot, and maybe even a front mount radiator!!!
this car wil be primarily for all over beater use, and major winter use!!! i need to find a large packasport roofbox, and this thing with locked diff;s will be a truly unstoppable snow/ski trip mobile!!!
WOOOOOHOOOOOOOO!
yes and the color has changed, the oversprayed Zermatt is out, and a better color for a snowbound mega ski trip car is partially on the car and only getting better looking!!
Build Specs budget style
car 700
16v 9a head case of beer
ABA bottom end
urS4 O1E transmission 225 shipped
oem 4kq rear locker had it already
mod'd 3b exhaust manifold 50
custom intake manifold a few beers
oem ABA TB
oem 3b wastegate and flex pipe had it already
obd II ABA harness and ABA ecu 160
C2 ABA turbo chip 400
3b to custom downpipe 50
custom engine mount arms made by me
440's 200
aeb oil pan,sump,pickup, fuel rail, IM
windage tray, and oil filter housing
needs
ABA TB
efi 4 cyl fuel rail
fpr
440's
ABA oBD1 bottom end
b5 a4 aeb clutch and FW
audidub wrote:please remove mega update from your thread header...
my2000apb wrote:audidub wrote:please remove mega update from your thread header...
done,
audidub wrote:thanks, nah but i should be cleaning the welding bench soon since i'm quitting my job to try and work out of my garage and whore myself out to cool shops such as marc's. so i will be set up to do it in the next week or so, i thought you were working on this car anyway.
audifreakjim wrote:my2000apb wrote:audidub wrote:please remove mega update from your thread header...
done,
Still wasn't removed so I fixed it for ya 8)
vagrant_mugen wrote:was thinking the same thing for my 4000q. dont really want a turbo, or any counterflow POS really...
ither a 7A swap or make an 016 adapter for a 8v TDI 4cyl. i really want to swap one in but i need to keep the 016 locker in the car. center lock is the coolest thing ive ever drivin...
ralleyquattro wrote:FYI my swap took 3 days, but that's only because I had to take the assembly back out, I installed the clutch fork upside down... doh!
Otherwise it went way smoother than any turbo engine. No need to remove the battery tray either.
Wiring can be a pain if you have never done it before, but if you have a complete 7A harness to get the engine going it's 5 min tops, the black plug and fused parts are all you need to hook up to get it going.
http://www.quattro.ca/19874kq/87-4kq.htm
HTH
jcarrick wrote:And you can always go turbo down the road on the 7a if you feel so inclined
