Those of you who have done this (not sure how many) using a urs wiring harness - how much of the harness in the footwell did you remove? I haven't figured it all out yet for my 4k, haven't really thought about it actually... but anyway I'll need switched power, I'll have to integrate the fuel system... and what else? Is there a separate power for the coils? I need to look at Dave/urs4boy's wiring harness diagrams on Quattroworld to get a better sense of how things are run.
Mike, the PO of my car had IIc wired using the relay board to give fuel pump, coils and injectors power. I took all that out, so how much of it is integrated with the harness? Essentially I've got an AAN, stock harness, and PNP VEMS - shouldn't be too bad, right?
Oh, and I'm using the 60-2 crank pulley trigger - can I just plug into it using the stock harness? Any other settings in VEMS?
GONE :( 87 4ktq -
4 FOX SNAKES
