EDIGREG wrote:Man, that is a pretty vague description...lol. Could be any number of things, but I'd check the inner sway bar and control arm bushings since they're in that area. Also subframe bushings.
When you say only when moving forward, it happens when cruising/not changing load? Or just when moving from a stop or braking/decelerating?
Sorry Ed, It's tricky to describe. I'll give you a ride this weekend.
Control arms are new and tight, sway bar bushings are all new and tight, sub-frame bushings are without a doubt, toast.
By moving forward, I mean moving (any direction). As soon as you're stopped, nothing can be felt even while revving the engine. Varying the load seems to make no difference though it may actually go away when under heavier load. It's most noticeable when normal cruising and stopping. Speed doesn't seem to affect it either though. That kind of rules out my CV theory.
