Hanks URQ 2.6L Autopsy
Re: Hanks 81 URQ, O1e installed, paint squirted... Assembly
Blasted linkage. 4 hours of adjustment, and I am still in the same boat. I am stumped.
a_CQ
I wish I could help you...I think you need a helper there to shift as you watch what linkage does.
WOMBAT
Hank needs backup!! someone!!! I'm too far away!
- speeding-g60
- ralleyquattro
ShavedQuattro wrote:I am having some transmission issues with the linkage. I torqued down the motor and trans mounts, and now I dont have reverse and a stuborn 5th.. I think I may be rubbing somewhere..
More tomarrow.
Did you lower your tranny mounts like I did? I had couple of washers between rubber mounts and the subframes to lower the transmission a bit. No issues with shifting here, everything is buttoned down.
Cheers
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
91 Coupe Quattro
Get it done Hank!!! Your so close man!!! :woowoo:
glibobbo21
ShavedQuattro wrote:I still have 10 hours. I am going to sleep for 2, as my productivity has gone down a bit in the last 2 hours. The interior lacks very little, and really the only things are doors and the front grill. When you go home and take a shower, and you put shampoo in your hair then conditioner, and then body wash in your hair, It is a bad sign of your mental state.
More tomarrow.
Did you try driving it or just engaging gears sitting still? We had a similar problem with the last cq 6spd 01e install then we gave up and pushed the car out(not having reverse..then he tried after it was running at it went right in..? Been fine since, I believe.
Car looks great Hank.....
Sorry I won't be there to check it out in person.... :(
Small update to lots of progress.. The lack of gates other then the 3-4 gate ended up being the updated detent I used. I was stumped because I have the jig setup with measurements to the tunnel but theoem detent. Seven hours later I got it but it cost me putting on the trim handles and some of the interior. I figured the vegas meet would rather have another urn VS a sob story..
We hit the road. I just realized that I forgot my camera so post up pictures if you take them in Vegas
80qtdi
Dang, I wish I had a quarter of the motivation that you have. Good work!!! Did you build the linkage yourself for the 01e? or did you have some of the 01e linkages?
Jon
Jon
i cant wait for the pics!
Pictures will come soon. I am currently "grounded" from going down to the shop for a week, or until the baby's room is done...
- ralleyquattro
Wow... Congratulations!
Life as you know it is over!
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
ralleyquattro wrote:Wow... Congratulations!
X2 :cheers:
ShavedQuattro wrote:Pictures will come soon. I am currently "grounded" from going down to the shop for a week, or until the baby's room is done...
My Audi gets me into trouble all the time hahaha.... Can't wait to see some pics! :woowoo:-Ben-
WRC
Congrats Hank.
Amazing work on short order.
Re: Hanks 81 URQ, Daily Driving.. a few pictures..
So I have put about 750 miles on the car since Las Vegas. Slowly inbetween classes and before class, I have been putting things back together at a snails pace. It is starting to shape up though. I gave her a washing today, and discovered my first door ding... The hood had contact with the engine in vegas. The Density Track mounts are nice, but they dont like clutch drops from the light.
Anyway, here are some pictures
Turns out, axles dont like those 500WHP drops either.. I need to figure out how to beef those up. I chopped a 5kq one up the other day to find them to be drawn, and then friction welded. This is good as it give me confidence to reweld them after shortening them and putting a chromoly tube on the inside with weld pins and then heat treated. I may try this soon..
All the overspray on the under side of the car washes off too.. I just have not cleaned the shop up enough to put it on the lift and pressure wash.
Car looks great Hank!!!
I'm still amazed that kate actually was willing to ride in it with you!
a_CQ
Car looks great, Hank!
You twisted those axles, alright.
Mine are bent though, and that's not from any launches or mad whp. Go figure.
Re: Hanks 81 URQ, Daily Driver status!!! Pictures
Looks awesome Hank!
And I have all of your in progress painting pics...
The car looks awesome man..... I love it...... gives me hope for mine one day. Although I doubt I will be doing the paint-work since it is 3-stage pearl. Sucks about the axles but I am sure you will find a solution. Good luck!!! :-) :-)
Looks good Hank. How did you get that much time to work on it. Have you already accumulated some brownie points?
