Where does this go? AAN
So I effed up, didn't label everything in a motor swap (tried to rush things) and need some help with the nitty gritty. More to come, these are a few of what is hanging me up presently.
Any help explaining where this junk goes would be greatly appreciated.
The one pin, black wire spade
The 2-pin black/brown wire one, not the 2-pin blue one off the ISV
Bracket goes where?
ads
Re: Where does this go? AAN
Post by ads »
http://12v.org/urs/AANEngineBaySideAnnotatedVer1.jpg
Black single pin is for 02 sensor and the black 3 pin is wss on drivers side of trans just above and behind output flange.
Not 100% on the bracket. Its on a power steering line correct?
83 Urq
yodasfro
Post by yodasfro »
Great link Austin, I never think of AW anymore.
Huge props to Adam for the help out today. Your familiarity with the AAN really saved my bacon.
Project is progressing.
Will post follow up questions as required.
Two more, both driver side. One down by the AC compressor and the other in the throttle body area.
The flat one by the AC compressor should be the fan switch in the bottom corner of the radiator
Cool, thanks. That's what I figured, wanted to double check.
One down, one to go.
ads
Post by ads »
Did you forget about the wss? Pretty sure the black 3 pin is your wss same as in the first post, the only non shielded 3-pin in that area of the engine bay from what I remember
83 Urq
Hmmm
Ill track that down first thing after work.
The unshielded one is directly from the engine harness.
Vss is plugged directly at the firewall.
