Re: Jims 07K 84 Super HX40 4kq "breakin'"?
i assume that 3.5 thou is a typo.
I think he means .0035"
i was gonna say, that would explain the catch can filling with oil quickly and it being a bit loud on startup,
glibobbo21
Correct. ;-) ill change it. In recent other news...those threaded flat sections should be dead flat....
- 1404147281845.jpg (2.98 MiB) Viewed 28679 times
well, not that i need to say it...but that sucks.
maybe the valves are still ok, and you just need a re-time !
you have a bore-o-scope?
glibobbo21
Bore o scope Tonight. Its my fault for using tensioners from a used motor with 28k miles...oh well. Hopefully the heads ok. Not worried about a nick in the piston but i hope the heads ok. Id be tempted to build a head now if its hit...
you have more just put a head on it for now!
glibobbo21
The heads just as easy in the car. Either way yea i do have at least one spare head.
kieron_32v
Zerb wrote:i assume that 3.5 thou is a typo.
chaloux wrote:I think he means .0035"
Sounds like the same to me...
kieron_32v wrote:Zerb wrote:i assume that 3.5 thou is a typo.chaloux wrote:I think he means .0035"
tomato tomatoe
lmao
glibobbo21
So long story short i ran all late tensioners and chains on all late stuff except the crank. The crank is 06 and that runs a different style lower chain(all pre 08). So the relay cog to relay lower chain to upper had to be changed along with the gear on the oil pump. As a result of the chain not seating properly on thr crank cog it had slipped at some point making both cams "advance". Not sure if theres valve damage yet but ill know later tonight via a snap-on boroscope. The rear cover, front cover and pan are back on and the cam gears need to be tightened for timing to be finalized. Should be back on the road this weekend and hopefully i wont be swapping a head any time soon. :-/
glibobbo21
Progress and here you can see the difference in the two sprockets. This pan and rear timing cover better not leak now damnit!!!
- 20140630_175947.jpg (1.42 MiB) Viewed 28603 times
- 20140702_173440.jpg (2.03 MiB) Viewed 28603 times
- 20140702_154128.jpg (2.81 MiB) Viewed 28603 times
end result is?
my2000apb wrote:end result is?
Don't mix timing parts.
glibobbo21
Mcstiff wrote:my2000apb wrote:end result is?
If you change to an early crank you run all early timing components. Eating dinner then some boroscope. I was hoping i could USB it for a vid but im told the cables not with it. Well see when i look at the unit when Im back.
Hmm. This is good to know. Hope the scope results are positive.
I dunno what I am more shocked about, the fact that you managed to not notice the gear width/type, or that it actually ran for 3 weeks to 7500rpm. lol
Good lucky save
Good lucky save
glibobbo21
Me too hank. No contact. Confirmed this morning.
- themagellan
Awesome news, glad to hear it.
good news dude
well.....
Eeeehhhh?
- themagellan
Heard this was going to be on a dyno sometime this week
themagellan wrote:Heard this was going to be on a dyno sometime this week![]()
news to me? but we can probably get it on the dyno if he brings it down.
