Re: Jims 07K 84 Super HX40 4kq 25psi soon?
dana wrote:sounds great, how much boost in these vids?
16.5 psi
Thing rips, must be a riot.
dana
Post by dana »
16.5 psi
Nice! That thing is going to scoot RIGHT along when it gets up over 25psi!!
When are you turning up the wick jimmy?
glibobbo21
Post by glibobbo21 »
The car has run like a top today, and the days before since its been back together. You know...the normal rattles and diff thuds and clunks. haha. The rear rear diff mount decided to kill itself in the time it was apart for some reason. I haven't serviced the mount because its an early diff(4:11) so you need to remove the diff whole to do the mount. ugh. so i deal with whirring and clunks and aggressive hop in reverse til now i think. shes run well and deserves a reward and a few revisions also. Its also on its first synthetic oil change. I went with 5w40 Rotella t6. Cheaper than Mobil 1 at Tractor supply and miles better. Its quieted it down a bit but the injectors are still a racket. lol
I need to address a few things before the boost goes up.
Rear diff is noisy as all hell and the diff mount is hosed. Realistically I should just take a late 4k diff that I should have a few of and swap in the 100mm CV's. Also after a fairly long trip I got to my hometown at a friends. Funny enough, the end of my street, and had some magic smoke, no big deal a wire just was tangled just it chaffed and grounded. Shouldn't be a big deal, hopefully. I parked it when it happened so I could make a new wire and come back in the AM. something to do with the injector 12v from the fuse-box. So i need to check grounds other stuff and bla bla too. Who knows, but it ran amazing all day and no problems til i got to town!!
Speedometer. I either need to swap in a 5k speedo or just use bluetooth and vems. If I mount a tablet I wont have a visible gas gauge. I havent looked into if I can add a fuel level into vems?
glibobbo21
I was also driving without full throttle cuz i was being a pussy cuz i saw people haha... in the vids before the last one. The last one was full bore.
40v4kq
Re: Jim's 07K 84 Super HX40 4kq. On the road again?
Post by 40v4kq »
Glad to see it back together and driving. Sounds Fantastic. And nothing wrong with slowing down because you see people, that's a pretty smart thing to do.
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
glibobbo21
Finally got a chance to look at the wiring it seems that there are wires wrapped around the steering column. Guess that explains why the wideband gauge stopped working randomly.the wire ties had broken and were still barely attached to the few wires. Pull my flyback wire for injectors and wideband 12v/ground wires from im not sure where yet...hopefully not right out of the back of the gauge. Maybe tonight after my hand gets iced for the day had a lil accident monday night with a hand crank winch. Released tension with my.hand in the path of.the crank. 4 whacks later. I blacked out a min. No breaks but wow.
ugh that sounds like it hurts
Yeow! Not cool, that would suck man. Glad nothing's broken though, that would suck more. Heal quick and get on the dyno soon ;)
glibobbo21
Fixed. Now back to your regularly scheduled programming...
Re: Jim's 07K 84 Super HX40 4kq. Back in business
Soo.... dyno sheet?
glibobbo21
Also in case I didnt mention I DID weigh the car recently. This car has no PS no A/C, front mount rad and good size FMIC. Fairly heavy turbo manifold and turbo too... Stock manuyal rear windows. Full interior, 1/4 tank of gas and my 270 lb ass. 3020lbs. Impressive if you ask me :-)
no "more" boost yet. FW ring gear needs to be....fixed. Mine hasnt come apart but Seans ring gear has exploded on his car.....
glibobbo21
PRY4SNO wrote:Soo.... dyno sheet?
or did you mean just in general?
The masses want validation of output lol... gimme dat curve.
Tunnel or on-ramp videos will suffice in the meantime ;)
glibobbo21
Its at Marcs. I dont have one atm. Ill post it tomorrow unless Marc does first.
jim 07k 380hp 16psi.png (68.43 KiB) Viewed 33128 times
why does it still say 16 psi and not 25+ ??!?!?!!?!?!?!?!?
Wow, 380 at the wheels... and "only" 16psi. Can't wait to see that HX40 really open up with more boost.
:metoo:
glibobbo21
PRY4SNO wrote:Wow, 380 at the wheels... and "only" 16psi. Can't wait to see that HX40 really open up with more boost.
Yes yes i know. Maybe ill be the guy that turns up the boost in moderation and doesnt have a project update title with a sad face in it!
AudiSport4000
Post by AudiSport4000 »
Nice work. Really loving everything you have done with the car so far, and you have taken your time.
Kudos!
1986 4kq Commemorative Design
2012 Jetta TDI
dana
Post by dana »
whats up with all the self restraint? Impressive.
I'm usually like...hmm 15 psi is good, 30 must be twice as good. I was right. :drive:
glibobbo21
Haha Dana. Good thing you dont live closer. Probably just not enough "devil on my shouler" in my town. Lol
Do it. Doooo iiiiit.
glibobbo21 wrote:Haha Dana. Good thing you dont live closer. Probably just not enough "devil on my shouler" in my town. Lol
I can visit your town and be that lil devil
