Urs4 Build plans
Speedyurs4
Urs4 Build plans
Post by Speedyurs4 »
Hello everyone this is my first time posting so to start off Im Neil and I currently own a brown 1983 Audi 4000s and a Emerald green 1994 Urs4. Im Planning on doing a build in the near future with the Urs4.
Im aiming for around 400whp.
Heres My list of parts so far i Plan on using:
Scat H-beam rods
Arp Head studs
Gt3076r a/r 63
630cc injector
FMIC 30inx9.25in
V.E.M.S
044 fuel pump
Arp main studs
Any input and ideas are welcomed and appreciated Thanks and happy holidays!
-1994 Emerald Green Urs4: O1E 6spd swap, Stomung 3" catback, Rs2 tune, and some 034motorsport goodies :D
-1983 Brown Metallic 4Ks: plain jaine
Re: Urs4 Build plans
That list is a nice start. Sounds solid. You'll need a clutch eventually. Welcome!
Welcome!
Apparently you should probably pick up an Iroz efr turbo and manifold kit. No external wastegate makes it cheap and simple and the power numbers are crazy!
Speedyurs4
chaloux wrote:Welcome!
Okay ima check thats out when i get a chance thanks
Speedyurs4
loxxrider wrote:That list is a nice start. Sounds solid. You'll need a clutch eventually. Welcome!
Clutch i have and some other parts ill post some pics of the parts i have acquired so far
UrSobsessed
Post by UrSobsessed »
This.^^^
But if you stay the GT3076 route, I recommend going with a .82 a/r hotside instead of the .63. The .82 is more efficient and the .63 will likely surge on you more than you will like. BTDT with the .63.
Speedyurs4
What about holset hx35?
Which SB clutch did you go with? Stage 2 endurance seems too little but looks like what you got there at least by the color of the pressure plate
Speedyurs4
Its a stage 3
Speedyurs4 wrote:What about holset hx35?
HX35 is a great turbo for the URS4. It's just like a 30r, but spools 200 rpm slower (approximate).
:drive:
