Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Re: Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Thank you im working to get this post going got another couple thousand photos to go thru
- Sebastian -
Thank you, working to get this post up still have couple thousand photos to go thru and some vidoes
- Sebastian -
engine bay prep for engine install adding some heat shield
- Sebastian's CQ91' engine bay heat shield.JPG (2.13 MiB) Viewed 41921 times
- Sebastian -
Looks great so far!
some more parts and work, custom bracket for the coil setup based on strut bar with welded mount for the coil rails
custom bracket for the rear bumper from Jack " Mayham project" ,
the fuel rail didnt fit on stock s2 intake manifold wih spacers so some grinding was needed to fit it perfectly
- Sebastian's CQ91' coil conversion .jpg (2.75 MiB) Viewed 41904 times
- Sebastian's CQ91' fuel rail fitment .jpg (2.74 MiB) Viewed 41904 times
- Sebastian's CQ91' rear s2 bumper mount.jpg (2.36 MiB) Viewed 41904 times
- Sebastian -
sebastian! good to see you here man. I still have that 5x112 spare, im sure you found one already since I forgot about it months ago.
Looking awesome.
Looking awesome.
Oil housing has been rebuild and some an fittings added
- Sebastian's CQ91' oil housing .jpg (2.36 MiB) Viewed 41899 times
- Sebastian's CQ91' oil filter housing restored.jpg (2.4 MiB) Viewed 41899 times
- Sebastian -
distributor brass gear
- Sebastian's CQ91' upgraded gear .jpg (3.19 MiB) Viewed 41899 times
- Sebastian -
engine drop with hand of a friend Pit
- Sebastian's CQ91' Engine 10.jpg (2.29 MiB) Viewed 41894 times
- Sebastian's CQ91' Engine 9.jpg (2.01 MiB) Viewed 41894 times
- Sebastian's CQ91' Engine 9-1jpg.jpg (2.21 MiB) Viewed 41894 times
- Sebastian's CQ91' Engine 8.jpg (1.93 MiB) Viewed 41894 times
- Sebastian's CQ91' Engine 7.jpg (2.01 MiB) Viewed 41894 times
- Sebastian -
dropped
- Sebastian's CQ91' Engine 4.JPG (2.69 MiB) Viewed 41891 times
- Sebastian's CQ91' Engine 3.JPG (2.48 MiB) Viewed 41891 times
- Sebastian's CQ91' Engine 5.JPG (2.67 MiB) Viewed 41891 times
- Sebastian's CQ91' Engine 2-2.jpg (3.27 MiB) Viewed 41891 times
- Sebastian's CQ91' Engine 1.jpg (3.11 MiB) Viewed 41891 times
- Sebastian -
some addition of spark and random photos
- Sebastian's CQ91' coils 2.jpg (1.67 MiB) Viewed 41891 times
- Sebastian's CQ91' coils 1.jpg (2.14 MiB) Viewed 41891 times
- Sebastian's CQ91' turbo shoot .jpg (2 MiB) Viewed 41891 times
- Sebastian -
Keep em coming, awesome build!
down pipe and radiator
- Sebastian's CQ91' down pipe no wrap.JPG (2.89 MiB) Viewed 41886 times
- Sebastian's CQ91' downpipe wrapped.jpg (3.32 MiB) Viewed 41886 times
- Sebastian's CQ91' downpipe 1.JPG (2.57 MiB) Viewed 41886 times
- Sebastian's CQ91' work in progress.JPG (596.73 KiB) Viewed 41886 times
- Sebastian's CQ91' aux radiator change.JPG (2.36 MiB) Viewed 41886 times
- Sebastian -
83urquattro
Looks good seba.
here is one for you Adam Thanks or the paint job
- Sebastian's CQ91' kido81 paint job.JPG (2.49 MiB) Viewed 41866 times
- Sebastian -
here some random shoots i found in my folders
coupe being pressure tested for any leaks from brake fuild, coolant, clutch etc,
catch can loction
Dear Peter cleaning the whole windshield from over spray with small razor
catch can loction
- Sebastian's CQ91' gt 3071r.jpg (2.32 MiB) Viewed 41859 times
- Sebastian's CQ91' PIt doing the windshield.jpg (2.09 MiB) Viewed 41859 times
- Sebastian's CQ91' floor lift brake line check.jpg (1.97 MiB) Viewed 41859 times
- Sebastian -
random under shoots
- Sebastian's CQ91' under chassis 1.JPG (2.91 MiB) Viewed 41856 times
- Sebastian's CQ91'under chassis 2.jpg (2.51 MiB) Viewed 41856 times
- Sebastian's CQ91' random under shoot.jpg (2.35 MiB) Viewed 41856 times
- Sebastian -
rear strut brace in place
oil cooler installed
front support installed along with upgraded hid head lights and s2 bumper covering an s2 IC
- Sebastian's CQ91' oil cooler.JPG (2.11 MiB) Viewed 41853 times
- Sebastian's CQ91' engine random shoot 3.JPG (2.7 MiB) Viewed 41853 times
- Sebastian's CQ91' HID install.JPG (2.1 MiB) Viewed 41853 times
- Sebastian's CQ91' rear strut brace.JPG (2.78 MiB) Viewed 41853 times
- Sebastian -
A person randomly started talking to me at local parking about my coupe, he said that he also owned a coupe while ago and he missed it so much since he sold it. The only thing left he had was his car magazine that kept his memories alive. He asked me for my information he wanted to give me somethink.
and here it is a bit of history
- IMG_9618.jpg (2.78 MiB) Viewed 41805 times
- IMG_9614.jpg (3.03 MiB) Viewed 41805 times
- IMG_9615.jpg (2.76 MiB) Viewed 41805 times
- IMG_9616.jpg (3.09 MiB) Viewed 41805 times
- IMG_9617.jpg (3.32 MiB) Viewed 41805 times
- Sebastian -
here is the personal note from him
- IMG_9619.jpg (1.89 MiB) Viewed 41803 times
- Sebastian -
coupe is ready for Marc
- Sebastian's CQ91' garage storage.jpg (2.07 MiB) Viewed 41801 times
- Sebastian -
- Sebastian -
on the way to Marc at EFI Express after getting alignment done
here are some dyno pull and launch control videos
dyno pull 8200 rpm's
http://youtu.be/Gve438Dnjt4
launch control
launch control
- Sebastian's CQ91' alignment.jpg (81.65 KiB) Viewed 41775 times
- Sebastian's CQ91' dyno tuning at Marc's EFI Express.jpg (112.75 KiB) Viewed 41775 times
- Sebastian's CQ91' dyno tuning at Marc's EFI Express 3.jpg (2.67 MiB) Viewed 41775 times
- Sebastian's CQ91' dyno EFI Express.jpeg (1.77 MiB) Viewed 41775 times
- Sebastian -
[youtube]http://youtu.be/Gve438Dnjt4[/youtube]
- Sebastian -
Finally i was able to find some time to take her out to see some snow
- Sebastian's 91 Coupe Quattro Winter 1.jpg (362.88 KiB) Viewed 41317 times
- Sebastian's 91 Coupe Quattro Winter 2.jpg (315.48 KiB) Viewed 41317 times
- Sebastian's 91 Coupe Quattro Winter 3.jpg (325.26 KiB) Viewed 41317 times
- Sebastian's 91 Coupe Quattro Winter 4.jpg (311.44 KiB) Viewed 41317 times
- Sebastian -
