Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Zaworek
Re: Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Post by Zaworek »
Thank you im working to get this post going got another couple thousand photos to go thru :)
- Sebastian -
Zaworek
Post by Zaworek »
Thank you, working to get this post up still have couple thousand photos to go thru and some vidoes
- Sebastian -
Zaworek
Post by Zaworek »
engine bay prep for engine install adding some heat shield
Sebastian's CQ91' engine bay heat shield.JPG (2.13 MiB) Viewed 41914 times
- Sebastian -
Looks great so far!
Zaworek
Post by Zaworek »
some more parts and work, custom bracket for the coil setup based on strut bar with welded mount for the coil rails
custom bracket for the rear bumper from Jack " Mayham project" ,
the fuel rail didnt fit on stock s2 intake manifold wih spacers so some grinding was needed to fit it perfectly
Sebastian's CQ91' coil conversion .jpg (2.75 MiB) Viewed 41897 times
Sebastian's CQ91' fuel rail fitment .jpg (2.74 MiB) Viewed 41897 times
Sebastian's CQ91' rear s2 bumper mount.jpg (2.36 MiB) Viewed 41897 times
- Sebastian -
dana
Post by dana »
sebastian! good to see you here man. I still have that 5x112 spare, im sure you found one already since I forgot about it months ago.
Looking awesome.
Zaworek
Post by Zaworek »
Oil housing has been rebuild and some an fittings added
Sebastian's CQ91' oil housing .jpg (2.36 MiB) Viewed 41892 times
Sebastian's CQ91' oil filter housing restored.jpg (2.4 MiB) Viewed 41892 times
- Sebastian -
Zaworek
Post by Zaworek »
distributor brass gear
Sebastian's CQ91' upgraded gear .jpg (3.19 MiB) Viewed 41892 times
- Sebastian -
Zaworek
Post by Zaworek »
engine drop with hand of a friend Pit
Sebastian's CQ91' Engine 10.jpg (2.29 MiB) Viewed 41887 times
Sebastian's CQ91' Engine 9.jpg (2.01 MiB) Viewed 41887 times
Sebastian's CQ91' Engine 9-1jpg.jpg (2.21 MiB) Viewed 41887 times
Sebastian's CQ91' Engine 8.jpg (1.93 MiB) Viewed 41887 times
Sebastian's CQ91' Engine 7.jpg (2.01 MiB) Viewed 41887 times
- Sebastian -
Zaworek
Post by Zaworek »
dropped
Sebastian's CQ91' Engine 4.JPG (2.69 MiB) Viewed 41884 times
Sebastian's CQ91' Engine 3.JPG (2.48 MiB) Viewed 41884 times
Sebastian's CQ91' Engine 5.JPG (2.67 MiB) Viewed 41884 times
Sebastian's CQ91' Engine 2-2.jpg (3.27 MiB) Viewed 41884 times
Sebastian's CQ91' Engine 1.jpg (3.11 MiB) Viewed 41884 times
- Sebastian -
Zaworek
Post by Zaworek »
some addition of spark and random photos
Sebastian's CQ91' coils 2.jpg (1.67 MiB) Viewed 41884 times
Sebastian's CQ91' coils 1.jpg (2.14 MiB) Viewed 41884 times
Sebastian's CQ91' turbo shoot .jpg (2 MiB) Viewed 41884 times
- Sebastian -
Keep em coming, awesome build!
Zaworek
Post by Zaworek »
down pipe and radiator
Sebastian's CQ91' down pipe no wrap.JPG (2.89 MiB) Viewed 41879 times
Sebastian's CQ91' downpipe wrapped.jpg (3.32 MiB) Viewed 41879 times
Sebastian's CQ91' downpipe 1.JPG (2.57 MiB) Viewed 41879 times
Sebastian's CQ91' work in progress.JPG (596.73 KiB) Viewed 41879 times
Sebastian's CQ91' aux radiator change.JPG (2.36 MiB) Viewed 41879 times
- Sebastian -
83urquattro
Post by 83urquattro »
Looks good seba.
Zaworek
Post by Zaworek »
here is one for you Adam Thanks or the paint job
Sebastian's CQ91' kido81 paint job.JPG (2.49 MiB) Viewed 41859 times
- Sebastian -
Zaworek
Post by Zaworek »
here some random shoots i found in my folders
coupe being pressure tested for any leaks from brake fuild, coolant, clutch etc,
catch can loction
Dear Peter cleaning the whole windshield from over spray with small razor
Sebastian's CQ91' gt 3071r.jpg (2.32 MiB) Viewed 41852 times
Sebastian's CQ91' PIt doing the windshield.jpg (2.09 MiB) Viewed 41852 times
Sebastian's CQ91' floor lift brake line check.jpg (1.97 MiB) Viewed 41852 times
- Sebastian -
Zaworek
Post by Zaworek »
random under shoots
Sebastian's CQ91' under chassis 1.JPG (2.91 MiB) Viewed 41849 times
Sebastian's CQ91'under chassis 2.jpg (2.51 MiB) Viewed 41849 times
Sebastian's CQ91' random under shoot.jpg (2.35 MiB) Viewed 41849 times
- Sebastian -
Zaworek
Post by Zaworek »
rear strut brace in place
oil cooler installed
front support installed along with upgraded hid head lights and s2 bumper covering an s2 IC
Sebastian's CQ91' oil cooler.JPG (2.11 MiB) Viewed 41846 times
Sebastian's CQ91' engine random shoot 3.JPG (2.7 MiB) Viewed 41846 times
Sebastian's CQ91' HID install.JPG (2.1 MiB) Viewed 41846 times
Sebastian's CQ91' rear strut brace.JPG (2.78 MiB) Viewed 41846 times
- Sebastian -
Zaworek
Post by Zaworek »
A person randomly started talking to me at local parking about my coupe, he said that he also owned a coupe while ago and he missed it so much since he sold it. The only thing left he had was his car magazine that kept his memories alive. He asked me for my information he wanted to give me somethink.
and here it is a bit of history
- Sebastian -
Zaworek
Post by Zaworek »
here is the personal note from him
- Sebastian -
Zaworek
Post by Zaworek »
coupe is ready for Marc
Sebastian's CQ91' garage storage.jpg (2.07 MiB) Viewed 41794 times
- Sebastian -
Zaworek
Post by Zaworek »
here are the videos of the first start up
http://youtu.be/A5AYlDH1rLk
http://youtu.be/Gve438Dnjt4
- Sebastian -
Zaworek
Post by Zaworek »
on the way to Marc at EFI Express after getting alignment done
here are some dyno pull and launch control videos
dyno pull 8200 rpm's
launch control
Sebastian's CQ91' alignment.jpg (81.65 KiB) Viewed 41768 times
Sebastian's CQ91' dyno tuning at Marc's EFI Express.jpg (112.75 KiB) Viewed 41768 times
Sebastian's CQ91' dyno tuning at Marc's EFI Express 3.jpg (2.67 MiB) Viewed 41768 times
Sebastian's CQ91' dyno EFI Express.jpeg (1.77 MiB) Viewed 41768 times
- Sebastian -
Zaworek
Post by Zaworek »
[youtube]http://youtu.be/Gve438Dnjt4[/youtube]
- Sebastian -
Zaworek
Post by Zaworek »
Finally i was able to find some time to take her out to see some snow
Sebastian's 91 Coupe Quattro Winter 1.jpg (362.88 KiB) Viewed 41310 times
Sebastian's 91 Coupe Quattro Winter 2.jpg (315.48 KiB) Viewed 41310 times
Sebastian's 91 Coupe Quattro Winter 3.jpg (325.26 KiB) Viewed 41310 times
Sebastian's 91 Coupe Quattro Winter 4.jpg (311.44 KiB) Viewed 41310 times
- Sebastian -
