IMG_20141207_180657763 by alxdgr8, on Flickr
IMG_20141207_192351291 by alxdgr8, on Flickr
IMG_20141207_193058938 by alxdgr8, on Flickr
IMG_20150103_124322818 by alxdgr8, on Flickr1 owner until May '14. Supposedly the car had been sitting from 2002 until then. Super clean! Minus the 'matching' dents on the lower part of each door...
Kirk got the car running, but was still fighting a 'brick wall' at 3k rpm's. I troubleshot some more and replaced more parts to no success. I'm pretty certain I have a CIS curse.
Soooo.... NO MORE CIS!
Road tripped from Seattle to L.A to pick up a full 7A swap (engine/wiring harness/ECU/etc) from Chris/varia. Did about 2600 miles in 4.5 days, but it was great. I love a good road trip.
IMG_20150209_223443269 by alxdgr8, on FlickrStarted cleaning the engine tonight. In case you didn't know, oven cleaner makes for a great degreaser for a first pass before I break out the pressure washer. Works better than purple power/simple green, just don't leave either on for very long. The oven cleaner foams and clings which gives it a better change to break down the grease.
Foamed up:
IMG_20150212_205615454 by alxdgr8, on FlickrAfter a quick scrup with a brass brush and rinse with a little hand pump water sprayer:
IMG_20150212_210443223 by alxdgr8, on FlickrAnother round of oven cleaner with the hose/pressure washer should get the block nice and spiffy.
Going to paint the block, powdercoat some stuff, ceramic coat the bag-o-snakes, do some seals/gaskets, and upgrade the injectors.
Also picked up some H1/H4's, Jamex strut bar, 2Bennet coilovers, and TSW Hockenheim wheels. Front struts of the coilovers need rebuilt so I'm going to buy some new ones. Also need to pickup some strut mounts and install some Mance mount savers into.
IMG_20150101_151816744 by alxdgr8, on Flickr
IMG_20150212_215404428 by alxdgr8, on FlickrEnd goal is to make this a fun and reliable DD so I can sell the Toureg. I'll DD this and the Merc (when I get that fixed soon) so I can save some money to get a Focus RS when it comes out in a year or so.
that's a pretty badass car!
