WTB O1E reverse light switch electrical connector
The connector is a 2 pin connector on the passenger side of th transmission
oldsklaudidub
Re: WTB O1E reverse light switch electrical connector
Do you have a part number or picture of what you want?
kieron_32v
It's a standard 2 pin junior power timer plug. Same as injectors, isv, coolant temp etc.
Here is the female side or the reverse switch. I need the female side so I can splice in my reverse switch.
- image.jpg (1.55 MiB) Viewed 9895 times
- image.jpg (1.32 MiB) Viewed 9895 times
The plug is this part number 1J0973722
Update... Marc, with EFI Express hooked me up and I got one coming.
Ha, I made a bracket to use the old VR sensors just because I didn't have that plug and I was impatient. Marc to the rescue again!
