Audi 200 20v Avant - Shed the 18 year old boy:)
AudiQuattros
Re: Audi 200 20v Avant - Shed the 18 year old boy:)
Post by AudiQuattros »
Thank Dmitriy Neman again for parts
bought back the right door in perfect condition. 500r .
took the ignition switch for adjustable speakers from a6 c4
tried on and bought the air filter housing from the AAN
P.s. My dad took a picture of me while I was recording hahaha :D :D
Dmitry
AudiQuattros
New rims r18
Dmitry
lol is that you making a post on this forum? What does the adjustable speaker ignition switch do?
AudiQuattros
loxxrider wrote:lol is that you making a post on this forum? What does the adjustable speaker ignition switch do?
do not quite understand .
adjustable steering column
Dmitry
AudiQuattros
Dmitry
AudiQuattros
Переварил вход и выход интеркуллера.
Разгреб проводку. Все подключил как надо . Скрутки в термоизоляцию одел.
Пропаял приборку.
Dmitry
AudiQuattros
Забрал стекла ...
If anyone is interested in these glasses can help buy and send
Dmitry
AudiQuattros
one headlight collected. distant staff did so adjusted in the right and left. and the lens on the lamp housing and adjust up and down.
in the second headlamp .. with Moscow over the weekend will come new snag, straight new !! :we: :P :hail:
Dmitry
Juizer
Post by Juizer »
Looks mean. :D
The only way to go xenon IMO. :)
Are those headlights glass or plastic?
AudiQuattros
Juizer wrote:Looks mean. :D
it's plastic ... until the machine is assembled weird kind
Dmitry
I think it will look great. I think you could sell those lenses to other 200 owners.
AudiQuattros
loxxrider wrote:I think it will look great. I think you could sell those lenses to other 200 owners.
I did not put the mask on the lens ! put later. is not before
I can help you buy these glasses !
Dmitry
AudiQuattros
Bought hood home
Digested crumpled part of the wing mounting cup . welded by V8 D11. it is more rigid . square, and not stupidly plate .... and have a place in the "+" terminal for lighting under the hood ) dreamed about it !
tried new wheels : nr:
recognized color code my car at fault code L7 Panthers . Now for breaking bar is LY9Z PANTHERO MET. Tomorrow at 2500r buy 1.5 liters of paint at a colorist in the official dealer MB.
Examples of plastic right wing . : rul:
digested mount adjustable steering column under 45 Body S6.
bought new trompe l'oeil . : super:
Well, the second headlamp collected.
Dmitry
AudiQuattros
Dmitry
AudiQuattros
actually if you do finally decided to do something good in the car ... so all its previous revision altered and so on. restored order with the wiring. Heat Shrink Tubing rule. spent with the main oblique extra wires on the coil.
gathered at the site dashboard. all checked everything works. Ian came to realize that I pulled the bell one and it fell off. it is necessary to solder .. therefore left rear door does not play. put on the new rear-wheel drive. 18245 \ 40 et35 15mm spacer. Wheels for perfect arch!
Made accurately Case for adjustable column.
Tomorrow I will work with the body: blush:
bought the film on the glass for light toning and of small lenses mask on staff found. decided to paint inside the headlamp mounting in black.
just went along with the hood insulation is very good
Dmitry
The lights look really good!
AudiQuattros
покрасил. кпп поставил на место CBL. Со сращиванием кпп видимо облом. будет готовая кпп дизель кваттра.. позже
[spoiler]Image
Image[/spoiler]
Dmitry
Shiny!
AudiQuattros
loxxrider wrote:Shiny!
:ty:
already want to put on the car and collect it :bangshead: :roll:
Dmitry
AudiQuattros
I like these my videos
https://www.youtube.com/watch?v=rRiHWeg1Oqg
https://www.youtube.com/watch?v=qZnE8sHVkCE
https://www.youtube.com/watch?v=hWUC2OE_tY8
Dmitry
AudiQuattros
поставил капот, поставил новое правое крыло. и тд. сегодня в планах сделать бампер . и левое крыло поменять
Dmitry
AudiQuattros
Поставил крыло. Сделал бампер. И нарезал резьбу м10 вместо м8 усилителя спереди между лонжеронами
Забрал головку блока цилиндров из ремонта.
Завтра буду собирать и заводить :)
Dmitry
AudiQuattros
Dmitry
Wow it looks great!
AudiQuattros
loxxrider wrote:Wow it looks great!
Thanks :beer:
Dmitry
