b6 s4 motor swap with some goodies
tfried87
Post by tfried87 »
Picked up a really nice 04 s4 with a bad motor for a steal and a wrecked donor car with a good motor. While the motors out im installing a b7 Rs4 clutch, pressure plate and flywheel, alomg with a milltek stainless catback exhaust, and lltek patinum cold air intake. Im about 60% through the swap at the moment. Ill add pics and vids as I finish.
Milltek catback
Milltek catback
Good motor waiting on flywheel and clutch
And shes out!
And shes out!
About to pull the bad motor
Midnight
Re: b6 s4 motor swap with some goodies
Post by Midnight »
Are you doing any work on the timing chain system?
Oh, and welcome to the Pad :wave:
Jake
The Stable:
1999 Saab 9-3 5-door
2002 Saab 9-3 SE 5-door
Justin517
Post by Justin517 »
2nd on doing the chains guides and JHM mechanical tensioners while the engine is out. They all fail eventually.
tfried87
Post by tfried87 »
At minimum im replacing the cam adjusters, beyond that it just depends on how things look
Justin517
Post by Justin517 »
Most of the guides are mostly plastic, pulling the rear cover and not doing them just isn't smart.
