Some Trigger Errors
Grillage
Some Trigger Errors
Post by Grillage »
Hey all,
I have a thread on my V8 coupe but I thought I'd put this here instead.
I'm having some trigger errors only when I rev. Here's a screenshot...
The car doesn't really seem to miss or anything when I do this but obviously, I'd like to have no errors.
I'll attach my config and a triggerlog too...
config:
v3.3_u009476-A-2015.10.18-12.41.48.vemscfg
(13.28 KiB) Downloaded 1358 times
triggerlog:
v3.3_u009476-2015-10-24-12.29.57.triggerlog
(14 KiB) Downloaded 1323 times
CURRENT
PAST
Re: Some Trigger Errors
looks like your secondary trigger is going away as you rev.
you're running auditrigger, so your ecu relies on the combination of the reference pin and distributor to produce the pulse. that means one of two things (more likely the 1st)
1) your reference pin to distributor aligment isn't dead centered, so as you rev the distributor goes out-of-window relative to the reference pin. this happens as the t-belt flexes.
2) either your reference pin or cps signal physically goes away under revs. unlikely because the pin signal (VR) gets stronger the faster the engine revs and the hall sensor in the distributor is usually a pretty reliable signal. revs shouldn't really affect the relaibility of the signal. if its marginal it should be marginal everywhere.
The engine still runs because it already knows what TDC cylinder #1 is from seeing the cam pulse earlier at lower revs so it notes the problem but keeps going.
Grillage
Post by Grillage »
How would #1 be possible? The cam sensor only goes in one place and same for the flywheel.
And what's the way to fix this? Widen the window somehow?
CURRENT
PAST
Grillage wrote:How would #1 be possible? The cam sensor only goes in one place and same for the flywheel.
I mentioned it in the post. timing belt flex. As the engine revs the belt stretches and dynamically moves the position of the pin relative to the shutter wheel in the distributor. that and slop in the distributor rotor itself.
it should remain in-window as long as the two are perfectly aligned and there is minimal slop in the dizzy.
Grillage
Post by Grillage »
Sorry, missed that the first time
So what's the remedy? Should I find a sonsor setup with a larger window? The belt isn't overly loose or anything. I just did the timing belt service a couple months ago. If everything runs okay should I just ignore it?
CURRENT
PAST
remedy wise, first triple check that alignment is perfect. window in the distributor has to line up with the pin on the flywheel. perfectly. centered.
next, check slop in the distributor. if there is a lot of flop you can try replacing or rebuilding it, or simply widening the window.
its not the window that sets the timing, its the position of the reference pin anyway.
Grillage
Post by Grillage »
Thanks for the reply.
I know it was perfect once but now re-checking it would be a major undertaking. The only factor that could change the relationship between the two is the timing belt tensioner. I did do the TB job but I used the proper tools and was careful to tension the tensioner thing to the right length. Looking back at pics it appears to be the same length as the old one too.
ill try another distributor/cam sensor first. Happen to have one?
CURRENT
PAST
