Re: Rubi Beta v3.0 - The Assemble Phase...
Slowwwwwww proooogressssss....
PSA. My front bumper is wrecked underneath... Looking for a bumper now too...
[youtube]http://www.youtube.com/watch?v=GNybyOPdMlY[/youtube]
If you're keen on a new bumper, there's one available on Audifans.
http://audifans.com/afmktplc/index.php? ... em&id=2288
Thought I'd share a quick rundown of where and how the car stands as of today... 12/13/15
Engine:
- DM Forged I-beam Rods
-ARP Head Studs
-ARP Rod Bolts
-Balanced/Blueprinted Rotating Assembly to.5 gram
-Stock 81mm Bores & Stock Forged Pistons
-MLS Head Gasket
-Billet Hardened Timing Belt Cog by Tommis
Head:
-Stock AAN Ports (unpolished)
-Ferrea Valvetrain +.5mm
-SuperTech Heavy Duty Valve Springs
-Fresh Stems/Seals
-OEM Lifter Buckets
-N/A 7A Camshaft Set
-Tommi’s Adjustable Billet Aluminum Cam Gear
Exhaust Path:
-Iroz MotorSports Custom Equal Length Long Tubular Header
-Gasketless V-Band Connection w/Egt provisions at Collector & 5th Runner
-Iroz 3” Downpipe with Merged Waste Gate Path on V-Bands
-Tial MVR-44 Billet Aluminum Water-Cooled Wastegate
-Stromung Gen4 Exhaust with Cat Delete
- DEI Titanium Wrap on Header and Downpipe
Intake Path:
-Precision Turbo GEN2 6062, V-band in/out .82 a/r housing
-K&N 4” GREEN Mushroom Filter
-Tial 50mm “Q” Blow-Off Valve
-Custom Aluminum 2.5” Piping
-Garrett 18”x 10.5”x 3” Intercooler
-Stock AAN Intake Manifold
Fuel Delivery:
-Walbro In-Tank F90000267 aka 450/416 (not sure if 85psi or 110psi relief)
-PTFE e85 resistant -8an SS Fuel Line from Tank to Stock Fuel Rail
-FID 1200cc @3bar Fuel Injectors
-PTFE e85 resistant -6an SS Fuel Return Line
-Stock 4bar Fuel Pressure Regulator
-GM Ethanol Content Sensor on Return Line aka “flex fuel” sensor
-Fuel Pressure Monitoring Unit in Feed Line
Engine Management:
-Versatile Engine Management Systems ECU V3.3
-Integrated Wideband
-4bar MAP
-EGT Monitoring
-Bluetooth Connectivity Add-On
-In Cabin LCD Readout
-Tune Auto Calibrates from Pump to E85 for Maximum Versatility (currently not fully implemented)
-Fuel Pressure Monitoring/Logging (currently not fully implemented)
-Oil Pressure Monitoring/Logging (currently not fully implemented)
Drivetrain:
-01e EDU with Updated OEM Syncros
-7A Flywheel
-SouthBend HD 7A Pressure Plate
-SouthBend Extreme Dual Ferramic Full Face Friction Disc
-Poly Snub Mount
-Homemade Magellan Transmission Mounts
-Mustang Foxbody Poly Transmission Mounts Retrofitted for Motor Mount Use
-Stock Open Diff
Suspension:
-H&R 29971
-Bilstein Sports
-Hap Rear Sway Bar
-Custom Coilovers (Currently uninstalled)
Brakes:
-Audi S8 44/40 Brembo 4-Piston Calipers
-323x30 A8 Front Rotors
-RS2 Brackets
-Mintex Pads
-Stainless Steel Braided Lines
-310x25 Phaeton/w12 A8 Rear Discs(Currently Uninstalled)
Wheels & Tires:
-BBS RX-501 18x8.5 2-Piece Forged Wheels
-BBS CH 18x8 Cast Wheels
-Michelin Pilot Sports 255/35/18
-Pirelli P7 245/40/18
Re: Rubi Beta v3.0 - Finally Assembled
Dyno! Vids! Kills!
:metoo:
Best I can do is show that is makes a paltry 20psi at 4300rpm, 4th gear... on pump 93, no spool valve, v-Band open scroll .82 housing, stock port head, laggy PTE turbo...
I'll verify in VEMS later on...
I bet it's pulling hard right there
ringbearer wrote:I bet it's pulling hard right there
I like that I have the other half of the tach to work with. :D
dana
Post by dana »
i love this car......that is all.
dana wrote:i love this car......that is all.
Thanks bud...
I'm just stepping in real quick to let everyone know that with the tax season over & spring in full effect, we should be seeing posts and updates more regularly... Stopped in this morning to bring Marc some fuel for some much anticipated final tweaking in the next days... She's alive and well, though very dirty....
Re: Rubi Beta v3.0 - 310mm RBBK
Did a few things this week...
Needed rear pads, so why not take the opportunity to upgrade...
Went with a 310mm x 22mm disc from a D3 A8, using the stock caliper, but with B5S4 pads to accomodate the 2mm thicker disc.
Re: Rubi Beta v3.0 - Rear BBK
I like the extra 10mm but those holes in the rotor bother me, ocd always wins. What adapter bracket did you use? Looks good for sure, stock are soooo tiny.
ringbearer wrote:I like the extra 10mm but those holes in the rotor bother me, ocd always wins. What adapter bracket did you use? Looks good for sure, stock are soooo tiny.
Lol, The front discs have holes in them too through, it's not that bad in person...
I used Thuppu made brackets
(Not my picture)
Sent from my SM-N900V using Tapatalk
Mystified
Post by Mystified »
Looking gooD El... :thumbsup:
Mystified wrote:Looking gooD El... :thumbsup:
Thanks!
Might be dusting her off today in prep for this weekends sFestivities...
S-Fest 2016
s-Fest was Fun...
[youtube]http://www.youtube.com/watch?v=RiWvXlR2RgU[/youtube]
[youtube]http://www.youtube.com/watch?v=MlhTPguuQBI[/youtube]
Google Photos did a Re-Cap...
[youtube]http://www.youtube.com/watch?v=pwZvA4M4xOI[/youtube]
Re: Couple s-Fest 2016 Pics
Got the kids out to a show, nice! Rubi looks good as ever. Can't wait to see the videos when I get a chance.
loxxrider wrote:Got the kids out to a show, nice! Rubi looks good as ever. Can't wait to see the videos when I get a chance.
Of course I brought them out on daddy weekend, sponsored by EFI to boot...
Thanks on the compliment, I need to really get crackin on the interior part of the car...
Car looks sick Ob! Don't be so taciturn! NUMBERRRRRRRS
Kids look great in those EFIexpress shirts. I need a box. I'd wear them every day lol
Good to see you using it!
Re: Rubi PTE6062 Build - Phase 3
Just posting some rear suspension stuff I've come across lately...
So this is the washer I chose to weld on ... it's the stock OEM part that goes on top of strut mount. You just need to weld that underneath the mount as a mean to provide a solid place to mount the stud kit.
Stock Top Washer
Spacers
Inner Sleeve
Nice
Awesome, thanks. What part number QA1 did you use?
ringbearer wrote:Awesome, thanks. What part number QA1 did you use?
Proma Star DS601 with Bearing option...
Sent from my HTC 10 using Tapatalk
My local summit racing has one of these qa1 shocks on the clearance shelf for like $75...
If there was two of them, I'd definitely grab them.
