Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Zaworek
Re: Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Post by Zaworek »
few more
Sebastian's 91 Coupe Quattro Winter 5.jpg (331.38 KiB) Viewed 19976 times
Sebastian's 91 Coupe Quattro Winter 6.jpg (293.26 KiB) Viewed 19976 times
Sebastian's 91 Coupe Quattro Winter 7.jpg (292.76 KiB) Viewed 19976 times
Sebastian's 91 Coupe Quattro Winter 8.jpg (277.97 KiB) Viewed 19976 times
- Sebastian -
Zaworek
Post by Zaworek »
Sebastian's 91 Coupe Quattro Winter 9.jpg (274.04 KiB) Viewed 19976 times
- Sebastian -
dalspaugh
Post by dalspaugh »
Looks like a great build! Finally found my way over here to look at what you did for the fuel fittings.
Looks like you didn't have to make any modifications to the 034 supplied adapter for the supply line?
Although I must say I'm not crazy about how the return was done, from stainless braided hose directly to barb fitting. Seems to me a rubber piece would offer more compliance for a better seal. Any leaks so far?
'95 Audi 90Q
'91 Audi CQ Project: Davescq.wordpress.com
'00 Buell X1 Racing Stripe
Zaworek
Post by Zaworek »
So far no leaks I made sure I used good quality clamp and made sure it's tight. There are not many options to go from the barb fitting. If not braided SS line then i would just use regular rubber hose.
- Sebastian -
dalspaugh
Post by dalspaugh »
Zaworek wrote:So far no leaks I made sure I used good quality clamp and made sure it's tight. There are not many options to go from the barb fitting. If not braided SS line then i would just use regular rubber hose.
Yeah, a barb is really not ideal... I understand you made do with what Audi gave you (us). I'll likely go the rubber hose route but glad to see there is that option.
'95 Audi 90Q
lorge1989
Post by lorge1989 »
Can you give some more detail on what you did with the strut towers? Did you make the parts welded on, or were they a purchased part?
1988 Audi 90Q 1.8T swap
2003 VW Jetta TDI
1978 GMC High Sierra
2015 Touareg Lux
http://dubsinthebuff.com
Zaworek
Post by Zaworek »
i did use the audi 90 strut brace top caps and made custom bar with custom bracket to hold the coils on it. i did use two set of these for the front and rear.
- Sebastian -
lorge1989
Post by lorge1989 »
What 90s came with the brace? I'm going to guess and say B4s only? And did you cut out more metal underneath where you welded the strut tower bracket? Looks almost like you raised up where the strut mount would sit, slightly lowering the car.
2003 VW Jetta TDI
2015 Touareg Lux
varia
Post by varia »
lorge1989:
B4 90 and cabriolet came with the brace. Around $80 new from the dealer (8A0805635B; 8A0805636B)
You clean the tower to bare metal, put these on, veld it, seam seal it, and you are done.
Sebastian:
ive just read your whole build again, i found few nice things that i can "copy" :)
¯\_(ツ)_/¯
project 2226
Zaworek
Post by Zaworek »
its good to hear :) if you have any question hope i can help
- Sebastian -
