anyone lightend a spec LWFW to make it light?
pkw
Post by pkw »
btdt?
this light flywheel ain't so light
viewtopic.php?f=11&t=1534
pkw
Re: anyone lightend a spec LWFW to make it light?
Post by pkw »
nobody?
123quattro
Post by 123quattro »
Mine weighs 8lbs. I wish it weighed more.
dana
Post by dana »
I have never been pleased with very light flywheels, but that is just me. I think the stock 7a flywheel is a good weight for a street car.
honestly hate my 13lb 3b flywheel. Wish it was a 7a
So the stocker is 13 lbs? I have a 9 lb 034 lwfw lol. BRB aka smh
I like it mostly though
A1QSHIP
Post by A1QSHIP »
88a5tq wrote:So the stocker is 13 lbs? I have a 9 lb 034 lwfw lol. BRB aka smh
What stocker flywheel weights 13 lbs?
My flywheel weight data:
Stock 7a- 25lbs 6oz
"Lightened" 7a flywheel- just knocked off the weight ring off the engine side. 22lbs 13.2oz. Definitely did not remove enough material.Before picture
Before
Before
After
After. Note this picture is not mine but shows what I had machine shop remove.
NG flywheel- 18lbs 3oz
NG. I was told this was from a 3b. Maybe a 200 with a 016 gearbox? Missing center spigot for mounting pilot bearing.
Fidanza- 10lbs 9.2 oz
AAN Dual-Mass- 26lbs 13.2oz (not pictured)
Note: The AAN clutch disc & pressure plate weighed 13lbs 4.2oz & the 7a clutch weighed 14lbs 11.6 oz
Next is a little something left over from snatching the 3.0 liter crankshaft out of an AVK motor swap we did.
AVK with automatic flywheel on a 7a engine. 22 windows between the -2 slot & the TDC timing pin on a standard flywheel. More suitable for a stand alone fuel system. Just add longer flywheel bolts & a small flywheel to attach a Tilton clutch.
Nulla tenaci invia est via
A1QSHIP
Post by A1QSHIP »
More pictures of the AVK flywheel on a 7a block. This better shows the relationship with #1cylinder @TDC & -2 window on flywheel.
Spacer used on AVK is needed for correct ring gear location on 7a crankshaft.
