It's well known that the intake manifold on an AAN has clearance issues with the radiator in these cars, and adding an A/C condenser to the radiator only makes things worse. What's less well-known is that if you want to keep the AANs serpentine belt setup, the bracket for the alternator and A/C compressor also creates issues. I was prepared to deal with those.
Next issue is the high-pressure line going from the condenser to the evaporator. It runs left-to-right across the firewall just under the steering rack. But guess what, the 016 shift linkage occupies the same space. So that line needs to be bent or something... I hadn't quite figured it out yet.
Today's task was to install the oil cooler, but I realized that if I wasn't careful, I could put the cooler in a place where it would interfere with the A/C accumulator or the line going from the accumulator to the evaporator. So in a rare moment of smartness, I figured I better install that accumulator and line so I don't intrude on the space they need.
The line is in 2 pieces with a joint in the middle. It appears the joint needs to be separated to install the line, plus the person I bought it from had loosened the joint a bit already but it was stuck so I needed to get it freed up. My strategy was to get it completely apart, clean up the threads, and reassemble it with anti-seize so it would come apart easily in the future. Well I got it apart all right, but it's never going back together:
The photo pretty much tells the story: there ain't no threads left to clean up!
I've dealt with joints like this on many other cars where the "nut" part of the joint was steel and they had horrible issues with corrosion (and resulting thread damage) due to the metals being dissimilar. But apparently Audi has some very talented engineers that can design a joint that corrodes even though it uses the same metal for both parts! :slap: :(
), and my hacking away at the AAN alternator/AC compressor bracket really didn't yield enough space. So rather than mess with weird mounting to make the condenser clear, along with all the other A/C-related issues, I'm just gonna put that on hold for now. And without it, the radiator fits beautifully in its correct position with the correct (almost, I'm using a 4KQ shroud) fan.
