VEMS injector settings Siemens 630cc
Post by ChrisAudi80 »
Hi all,
Been searching a lot about this and cannot find the information. I have two spec sheets for the Siemens Deka 630cc injectors, but cannot make out how to use the information. What do I put here as indicated in the picture? Is it correct already?
Injector settings 630cc.jpg (60.62 KiB) Viewed 54271 times
UrSobsessed
Re: VEMS injector settings Siemens 630cc
Post by UrSobsessed »
This is what mine are. They are working well, but might need some tweaks on your car. HTH.
Req_fuel is: 4.6ms.
UrSobsessed wrote:This is what mine are. They are working well, but might need some tweaks on your car. HTH.
Req_fuel is: 4.6ms.
:ty:
I run req_fuel 5.9 due to E85. How did you get to these numbers? I used the simplified table in VEMS with the numbers sheet from Siemens but the motor ran junk.
I used the attached values for offset, but I guess I needed to multiply by some factor.
UrSobsessed
I got them from zeet on QW and then tweaked them a bit to my system.
UrSobsessed wrote:I got them from zeet on QW and then tweaked them a bit to my system.
Don't know who zeet is. How much tweaking did you do?
I have kept the settings that were in the ECU since I got it and that seems to work OK.
UrSobsessed
I didn't mess with them too much. Mostly the voltage cells that the car most commonly operates in. Even then, I didn't move the values more than maybe +/- 100us. It's been a long time since I messed with them. The traditional settings work pretty well, but I found I was able to get better results in fuel and idle tuning with the simplified settings.
You can try this method with deadtime calculation also: http://www.vemssupport.com/forum/index.php/topic,2240.msg24790.html#msg24790
UrSobsessed wrote:I didn't mess with them too much. Mostly the voltage cells that the car most commonly operates in. Even then, I didn't move the values more than maybe +/- 100us. It's been a long time since I messed with them. The traditional settings work pretty well, but I found I was able to get better results in fuel and idle tuning with the simplified settings.
Good information. :ty:
Changed my injector effective rampup to 240us, from 1008us. Big difference. Much better injector response that required a complete retune of the VE table had to go 10-20% up almost everywhere.
quattrobros
Post by quattrobros »
anyone have a known working traditional settings for these injectors?
I'm about to get some but cant find any reliable information.
quattrobros wrote:anyone have a known working traditional settings for these injectors?
Nah, just go simplified. I have the settings for that.
See attached.
Deka 630cc latency data 3bar.jpg (182.28 KiB) Viewed 42479 times
quattrobros
Yea looks like simplified is the way to go in this case.
Thanks for the settings!
