-VEMS stand-alone engine management with interior LCD display
-Siemens 60# injectors
-Bosch wideband o2 sensor
-7A Exhaust cam
-EFI Express LS2 high output coils
-Magnecore spark plug wires
-TiAl 50mm BOV
-Dave Stone (PMW) 24x12x3.5 FMIC
-1.9BAR Wastegate spring
-Samco silicone boost hoses
-034 silicone inlet hose
-034 silicone coolant hoses
-Walbro 255 fuel pump
EXHAUST:
-Stromung stainless 3" turbo-back exhaust (NO CAT)
-RS2 Exhaust manifold
BRAKES:
-993t (Big Red) Front calipers, 314mm rotors.
DRIVETRAIN:
-Real-deal RS2 six-speed transmission (CRB), rebuilt by Hans Kluge with .67 sixth gear and custom center section to accomodate ProConTen.
-034 poly snub mount and bracket
SUSPENSION:
-Bilstein Sport shocks
-H&R 29800 springs
-Rear sway bar (1992 only)
-2Bennett camber/castor plates
EXTERIOR:
-BRAND NEW OEM lower door trims
-Euro Rear center taillight section. Center plate surround is painted white, needs to be pearl paint matched (or painted black if you prefer)
-Clear corners (OE Hella)
-Euro lenses
INTERIOR:
-S6 sport steering wheel, in excellent condition
-S6+ 6-speed shift knob
-Full carbon fiber trim set, includes single-piece dash section. Everything is in perfect condition with zero cracks.
-Steel sunroof replaced with glass moon roof
WHEELS/TIRES:
-BBS CH w/255-35-18
Currently on the bench, installed sometime soon:
-FIC 2150's
-Scat rods
-JE 10:1 pistons
-92.8mm crank shaft
-Kolbenschmidt bearings
-Hanks header and downpipe
-3b valve cover
-Carbon fiber F/I, wire/ timing belt cover
-Sachs 707, Audi RS4 Stage 3+ disk
-034 7A Aluminum Flywheel
-Tial MVS-R wastegate
-ARP hardware (head/main)
-Hella Black tail lights
-Wavetrac lockable diff
-Audi S8 full aluminum mirrors
-Euro Bumpers
-Apikol rear sway bar
-Thuppu brackets, 312mm rotors
-Cat Cams 1002305
-Hanks 70 mm TB
-Hanks High Volume intake
-Hanks fuel rail
-Tommi's adjustable cam gear
-Coated Valves and Head , FRP
34mm intake valves
29.5 exhaust valves
5 angle intake, 3 angle exhaut cut
Stage 6 porting and flowbenching /equalize flow for each port
In process of acquiring:
-FP HTA3586R
-Bigger injectors
-416 lph Walbro
-bigger fuel lines
