No real updates here which honestly is about the best thing possible because that means nothing has broken. Ive just been driving the car using it as a commuter for work.
I have a few things left to sort out. "Comforts" if you will...
I need to sort out some small wiring things. The oil pressure light , ABS light, and oil pressure warning are on , and I don't have a speedo.
So first I'm working on the speedo . The wiring and plug is integreated in to the beautiful harness I got. On the GBE trans however , the sensor didn’t exist.
Thankfully , Alex made a video that thoroughly explains and shows how he added the sensor to his 01E for his S8.
Link to Alex’s video
https://youtu.be/UbgPCww08-I
I have two GBE transmissions- both are supposed to be from 03 A4 3.0 V6 . One has a plastic dummy plug in the side cover and one has more of a tamper proof maybe pressed metal type deal.
I removed the side cover and sender from the 01A trans and the little magnetic impulse wheel thing from inside.
Drained the fluid and pulled off my existing side cover to find that even though its capped off with a tamper proof plug, it actually had the clip on magnetic wheel inside.
Re-assembled and filled with fluid and hopefully tomorrow I will find out that I have a speedo. Fingers crossed
Some pics .
Cover removed from 01A
Sensor swapped into 01E cover (top)
The tamper proof plug in the 01E cover
Draining the fluid and ready to swap covers
Installed and ready to test
Edit . It works !
In other news I got another identical but much nicer 90 and I'm debating swapping that as well.
Not sure exactly how i'd do it but better intake and exhaust manifold, possibly front radiator?
