Well, I dropped the oil pan and my heart dropped with it. Coolant.
I followed a small stream up the front of the block on the driver's side (cyl 5). If I had caught it before the swap, I'd have aborted and ditched the car, but now it's worthless to sell
and I've got time invested, so save it I must!
Working out the price of a head gasket kit, timing set, and associated machining and tool costs comes to a not insignificant $700 (or $1000 if I have the heads rebuilt with a 3 angle valve job)
That's actually better than I thought, but I dunno if it's worth it on this particular engine. The oil pressure hasn't always been great (shows slightly under 1 bar at idle when hot) and Audi made these blocks basically unrebuildable, so I think I might be better off finding another engine instead.
Here are the options I'm considering right now:
El cheapo rebuild. No timing, just head gaskets, mill heads, A8 water pump and new thermostat. $400. It should be mentioned that the timing belt looks brand spanking new on this thing. I just want to make sure it runs cooler, since the temps would creep up at idle and may have contributed to the problem in the first place
New ABH swap. Pros: Easy, cheap(ish), quick, and I can run the current ABH till it blows up and make a sweet table; Cons: Hard to find, unknown history
ABZ Swap. Pros: Easy, cheap, available everywhere, can easily swap to S8 motor if I find one. Cons: Not bolt-in, unknown history, long down time
Any thoughts?
