Page 42 of 45
Re: I took the BLUE Pill. Engine bay painted
Posted: Sun Jan 12, 2014 11:23 pm
by vt10vt
So much awesome in this thread!
Posted: Sat Feb 15, 2014 11:50 pm
by glibobbo21
COUGH COUGH COUGH. Was that subtle enough?
Posted: Sat Feb 15, 2014 11:58 pm
by Mcstiff
[youtube]http://www.youtube.com/watch?v=fbwZRrEsSQQ[/youtube]
Posted: Sun Feb 16, 2014 12:00 am
by glibobbo21
ahhhh so much better on my PC.
Posted: Sun Feb 16, 2014 12:33 am
579whp/513wtq @25psi. Had to hunt to find that! Instagram.... pff
Posted: Sun Feb 16, 2014 12:37 am
by Mcstiff
We'll have this update wrapped up before Sean chimes in
Posted: Sun Feb 16, 2014 2:34 am
Hey guys,
Yeah, we have had a trying January/Febuary with the 07k swap. Tons of little issues that are involved when trying to mount a transverse motor longitude. Most of the big issues were with oiling. We ended up going through a couple of engines learning the painful lessons of oil demands, oil filter demands, line demands, oil capacities and how VVT really works on these motors. Frustrating probably isn't the best word to describe the long days and nights getting this car wrapped up so that folks in line for pans and motors are taken care of with something I can sleep at night with.
That time is now. I think this last revision of parts and concepts has solved most of the issues. We have clean filtering with no bypass caused by pressure differential across the filter housing, we have outstanding oil pressure monitored in 3 different locations in the engine, we have bearing clearances set for 750whp engine output, and the engine is responding nicely. We actually tore the current motor down after break in procedures to check bearing life and cylinder wear. All was good, so onto the power pulls
I talked Sean into the meaty MagnaFuel 750 pump that is really a nice piece. It is a bit loud, but it is the part. Very good fuel delivery so far and very simple hook up. I am really happy with it. We have 1000cc injectors in there now at 85psi base pressure for an effective 1350cc injector. We could stand to lean out a tad, but I feel more comfortable at that .79 lambda level at over 200whp/L. We are pretty much out of fuel. I think I'll try and talk Sean into either 1200s over pressured to be closer to 1600s, or maybe just run my 1600s in there. Regardless, we hvae an important magazine opportunity with the car coming up that has put a tremendous amount of effort and long nights into getting the car feature material
So yeah, pretty darn cool. Loaded up on our dyno, we are seeing almost identical spool to our billet k26's on a 2.2L AAN.
The Billet k26 is the dotted lines at 31psi on a built VEMS 20vt, and the solid is a 07k on HTA3582r at around 17.5psi. VVT really woke the bottom end up on this car. Here is a cool apples to apples comparo of 034's 2.9L 24v VR6 with a worked r32 head(best of both worlds in vr6 world). The turbo they are using is a PTE billet 3582r with a slightly larger compressor inducer, but more or less the same turbo.
Yep, that is pretty much the same graph and boost for both motors, just the 07k is doing it with .4L less displacement, 100lbs less weight and far less cost. This is a bone stock 90k mile head with the carbon still on teh exhaust valves/chambers.
Stock cams are looking a little lethargic above 7000rpm at the 600whp level, but we will confirm that later next week. I am going to do a better job of making ProjectPad my dump for projects we are doing, and leaving the scraps for Instagram and FB.
Posted: Sun Feb 16, 2014 7:59 am
Hank. Awesome work. To get to this point (35r spool = k26 spool) and have everything ELSE work out must feel magnificent and gratifying after all that. Very happy you didn't just start shipping out motors as doing this from Ontario wouldn't be fun lol.
The dip is the cam switchover? Looks a lot like our qsv switchover before we dialed it in with VEMS and an N75.
Congrats guys, can't wait to become a part of the 07k club (vicariously through dad, haha)
Oh, and just do it with the injectors. Come on!
Posted: Sun Feb 16, 2014 11:42 am
by Marc
I've already offered up loaner ID2200's for science. I wanna see this thing over 700whp. Do it.
Posted: Sun Feb 16, 2014 12:00 pm
by Mcstiff
Hank wrote:So yeah, pretty darn cool. Loaded up on our dyno, we are seeing almost identical spool to our billet k26's on a 2.2L AAN.
Knowing this is going to make it really hard to use this AAN shortblock I have
Now I just need to convince my wife that spending money on an 07k is better than leasing a DD.
Posted: Sun Feb 16, 2014 2:00 pm
Hank awesome work man, I think it's your attention to R&D that has set you apart in the community here. Awesome stuff, it's just done too damn well.
Can't wait to read the magazine
Posted: Sun Feb 16, 2014 5:09 pm
Seriously awesome stuff here Hank. You guy's have put loads of work into this car and swap. A+
Posted: Mon Feb 17, 2014 10:08 am
by highlander69
Truly amazing work Hank!!
I can truly appreciate what it takes to even come close to what have been accomplished here. I like the fact that you've been open, and honest about the problems that you guys have been troubled with. It really says a lot about your character. The quality of your work is second to none. It takes so much effort to take something, and make it look like it belongs there. I do believe that when things go wrong we learn so much more in the end. You have a great product here, and I know I've been seriously considering the 07k swap for my sport.
Keep up the great work.
Craig.
Posted: Mon Feb 17, 2014 10:36 am
I'm sure once you go for a rip in dad's S6 your mind will be made up
Posted: Mon Feb 17, 2014 10:44 am
by All_Euro
Aagh... this is the kind of stuff that keeps tempting me to build an 07k rather than my 06A... nice work guys
Posted: Mon Feb 17, 2014 11:03 am
by highlander69
chaloux wrote:I'm sure once you go for a rip in dad's S6 your mind will be made up
Matt I can't wait.
As soon as that engine lands please let me know. I'm really busy with college at the moment, but I'll be right up :-)
I'm sure your dad's car will be awesome. For me, I couldn't imagine that kind of power in a sport quattro. That engine in a 2500lb car that would be crazy for sure
Cheers.
Craig.
Posted: Mon Feb 17, 2014 11:13 am
well you can use a smaller turbo! lol. GTX3071 on a tube mani with the VVT and QSV... sounds like a nice 3krpm spool and 400whp capable turbo to me!
Posted: Mon Feb 17, 2014 11:27 am
by WOMBAT
This is phenomenal, congrats Hank! Incredible work!
Posted: Mon Feb 17, 2014 1:37 pm
Really digging on the updates guys... Now I can't wait to hop on the bandwagon after all your trailblazin' work has the bumps smoothed out of the road.
Posted: Mon Feb 17, 2014 2:59 pm
by Justin517
I need 07K+01E.
This kind of settles it, not going to throw any hardware at the 3B, enjoy it chipped then swap to 07K when the time comes for big power. the 3B will go into a small chassis or something...
Now I just need some moolah.
Posted: Mon Feb 17, 2014 4:05 pm
by All_Euro
Justin517 wrote:...new shop project in the works!
Fixed that for you
Posted: Tue Feb 18, 2014 1:29 am
Thanks guys for the kind words. Been pretty MIA these last couple of months sorting the various revisions of parts, but the end of hte tunnel is near. There are some really cool projects coming out of our shop right now I can't wait to share more on.
Posted: Tue Feb 18, 2014 1:42 am
by scubadave
great work hank. I personally have a nice grin on my face with the performance of the billet K26. I had Kelly take my car for a spin a couple weeks ago, and the look on his face was pretty significant. I wish I could be involved but my job keeps that from happening. (hands in pocket and kicks rock)
Posted: Tue Feb 18, 2014 2:25 am
by Quattro v1.0
*rubbing eyes*
I all but forgot to check in here for like a month or two...
Anyway, all of the above. ;o]
Darin will elaborate on the ride he got today Im sure.
Posted: Tue Feb 18, 2014 8:23 am
DARIN TELL US ABOUT IT JEEPERS!
