Page 53 of 130
Re: Hanks 81 URQ Painter out fishing, O1e installed!!
Posted: Sat Sep 25, 2010 8:45 pm
nice, I can only hope my mounts look that sick when the time comes
Posted: Sat Sep 25, 2010 10:41 pm
by Quattro v1.0
Good work Hank.
I hope someone would be able to compile a comprehensive list of parts as well as instructions for the 01E swap. Hank, you took notes right? :slap:
Posted: Sat Sep 25, 2010 10:52 pm
by Twintowers
The O1E is that much skinnier at the waist flange to flange than a 016??? 25mm and 10mm respectively, strange Audi would make a change like that, but it would certainly help with the drive line angles a little not much though... :wtf:
Posted: Sat Sep 25, 2010 11:00 pm
by Twintowers
Do I see factory provisions for a oil cooler at top right of the trans just behind the final drive housing passenger side? :wtf:
Posted: Sun Sep 26, 2010 4:15 am
by Highlander
Looks amazing Hank.
Those mounts look brilliant.....man you sure can weld.
As for the linkage, brilliant........between you and Martin, you guys
have this 01E tpye 85 problem beaten. No more floor modifying!!!
Can't wait to see the finished product.
Cheers,
Craig
Posted: Sun Sep 26, 2010 4:46 am
by greasemonkey
Nice build, hope the 01e does the job. what trans code?
thinking of stealing your tranny mount design if you don't mind.;)
Posted: Sun Sep 26, 2010 5:33 am
by glibobbo21
lookin' good!
Posted: Sun Sep 26, 2010 5:39 am
by speeding-g60
Twintowers wrote:Do I see factory provisions for a oil cooler at top right of the trans just behind the final drive housing passenger side? :wtf:
if you are talking the things that look like AN caps, no those are shift detents....
Posted: Sun Sep 26, 2010 5:56 am
by quattro87
Hank, looks good. I tried to call you back last night, but got no answer. I guess with Katie back in town you were busy. Are you going to start sleeping at home again instead of at the shop? :wink: How are you going to get anything done if that is the case?
So you must have finely figured out reverse and the lockout? What is David's schedule as far as work and Audis this week? Are you guys going to be able to find some time to paint in the next couple of days? It's sad when you're project with all that you have taken on, is looking like more of a sure bet than mine. I'm getting a bit worried, but figure it will come together. Again nice work and like was mentioned above the mounts looks great. You don't mind if I copy your design also do you? I figure that when you make me a set they will be just like yours. :D
Posted: Sun Sep 26, 2010 6:03 am
by durq
This may be a moot question but does the mechanical speedo gear from the UrQ fit into the 01E?
Posted: Sun Sep 26, 2010 8:56 am
Thanks guys. I may or may not have made a dozen sets ofthe mounts :)
Aaron is right on the detent plugs that help the shifter go back to center. I know this because my shifter has a hard time returning from the left. Jhm sells up rated ones that help this out. By the looks of it? They have just drilled the rear out and put a stiffer sprng and cap on. I'll probably experiment with this a bit.
Also note that dropping the pivot point on the shifter arm is what kept the rod from hitting the tunnel. I originally put it on just like the urs4 has but that pivot is located further inboard then the stock 016 pickup for the arm. By dropping it and shifting it out, I was able to mimick the stock location and figment better.
The speedo for the urq can be used if one. Takes off the cover and has the threads machined in. I won't as I don't want anything t do with the cable drive. My approach will be using the electronic 5000 cluster with the 01e sensor that is identical to the o1e if they are both torsen units.
Also note that the slave I am using is the same as the 200 20vt
I hope this thread can help others with their swaps. Perhaps a some point I'll make a sticky.
Posted: Sun Sep 26, 2010 9:03 am
greasemonkey wrote:Nice build, hope the 01e does the job. what trans code?
this one is a cbl 5 speed from an s6. I have a edu in the wing should the narrow first not hold up to the lightweight car. It has a buggered hub but I should be able to make a good wide 6 speed out of the two
Re: Hanks 81 URQ is getting PAINT!!!
Posted: Sun Sep 26, 2010 9:10 am
by ralleyquattro
ShavedQuattro wrote:On the shifter box, I really wanted to retain the lockout with 1st so close to Reverse now. I took the base of hte URQ, shopped all but the base and about 3/8ths above that on, so I could raise the urS4 base by welding it on top.
Did you have to weld/cut anything? I didn't. Simply sandwitched the bottom of the 016 (where the bushing is) and top portion of the 01E. You end up with two pieces of sheetmetal on the four mounting bolts on the floor, but that effects nothing.
Posted: Sun Sep 26, 2010 9:19 am
Martin , is that the full s6 two piece portion? I had that bottom portion as well but did not. See how the front portion would bolt up. My solution did require a cut and weld bt it was minimal. I also cut those mounting ears off used for holding the trim on the s cars
Posted: Sun Sep 26, 2010 9:24 am
Also a personal plug for martin and his stash or parts. He has EVERYTHInG for these cars. He sent me a rear windscreen rubber seal that let me take out all the glass for the right way painting. Thanks again Martin
Posted: Sun Sep 26, 2010 9:28 am
by speeding-g60
ShavedQuattro wrote:Aaron is right on the detent plugs that help the shifter go back to center. I know this because my shifter has a hard time returning from the left. Jhm sells up rated ones that help this out. By the looks of it? They have just drilled the rear out and put a stiffer sprng and cap on. I'll probably experiment with this a bit.
ironically this is what i have been looking at the past week or two. imma grab one out of the spare tub of parts tomorrow (first one i disassembled) and figure it out, as this was exactly what i thought as well. looks like they took the back of the cap off and put a brass plug in its place to hold a tougher spring inside.
Posted: Sun Sep 26, 2010 9:37 am
by durq
re: speedo-
That is a great solution- I have been contemplating this while looking at my 200 cluster but keep thinking about the electronic odo. and how to work around that. Your solution would also help me with my planned switch from a 3b ECU to the AAN ECU and the speed sensor even though Craig figured out a solution for this (I want to keep the factory ECU because I live at 11,000 ft. and cold start is questionable here even when it's warm outside).
Thank you very much for all this fantastic info!!! (and Martin too!). Great thread-
Posted: Sun Sep 26, 2010 9:50 am
Rick from what I have seen, the torsen 016 and the o1e share the same speedo sensor. They probable both get 5vs andsend a squarewave signal out to the cluster. I only used the 5000 speedo because it is a smaller diameter gauge that will fit into the urq cluster area an still lol oem.
It I have time prior to Vegas, I'll dig into that, but I will probably leave the speed up to the gps for now. Paint seems more important for some reason:)
Posted: Sun Sep 26, 2010 11:52 am
by ralleyquattro
ShavedQuattro wrote:Martin , is that the full s6 two piece portion? I had that bottom portion as well but did not. See how the front portion would bolt up. My solution did require a cut and weld bt it was minimal. I also cut those mounting ears off used for holding the trim on the s cars
Here is what I did...
016 bushing portion with 01E shifter inserted waiting for lockout plate.
01E lockout plate ready to go with few items cut away (mounting for UrS centre console and the funky front loop).
Since the floor bolt pattern is the same just stack them up nicely... and all done
I may use the short shifter if it means lowering the rod, I have no clearance issues now but just incase that changes on the go.
Hope this hleps.
Posted: Sun Sep 26, 2010 11:55 am
by ralleyquattro
ShavedQuattro wrote:Also a personal plug for martin and his stash or parts. He has EVERYTHInG for these cars. He sent me a rear windscreen rubber seal that let me take out all the glass for the right way painting. Thanks again Martin
Thank you very much Hank! I try my best.
One of the Ur-q guys bought bunch of stuff from me and made a comment, "who needs Audi Tradition with you around"
You should see my basement! ;)
Cheers
Posted: Sun Sep 26, 2010 1:09 pm
And those are all urS parts Martin?
Posted: Sun Sep 26, 2010 1:37 pm
by ralleyquattro
ShavedQuattro wrote:And those are all urS parts Martin?
Yes, UrS4/S6
Cheers
Posted: Sun Sep 26, 2010 1:38 pm
by ralleyquattro
Yes, 01E are all UrS4/S6
016 portion is stock Ur-q.
Cheers
Posted: Sun Sep 26, 2010 3:58 pm
Cool. I have that bottom portion as well. Perhaps I will put it in and compare it with what I have. I found that having an extra gate is hard to get under the gater of the URQ without shortening the shifter. I'll check it out.
Nice carpet BTW :)
Posted: Sun Sep 26, 2010 4:37 pm
by glibobbo21
ShavedQuattro wrote:Nice carpet BTW :)
that carpet did come out nice for coming from NH :D Good thing the thing was only driven half of its life. I love how it drove for 13 years then was parked for 13 years haha.
