Page 7 of 25
Re: Ed's 1991 CQ, H1C, SEMS, work work work!
Posted: Wed Aug 31, 2011 9:21 am
by jbrentd
Ed, what did you decide on for engine management and intercooler?
Posted: Wed Aug 31, 2011 6:31 pm
by Mcstiff
jbrentd wrote:Ed, what did you decide on for engine management and intercooler?
So after months of running the numbers and going back and fourth I settled on VEMS. I was happy with my 034 Ic in the last car and would have loved a IIc but right now, 3 kids & wife in school, the IIc price point was too high. I ended up with the Econoseal V3 from Marc with a VEMS harness and LS2 coils. In all this should be about the same work as an S2 harness but a HUGE savings by skipping the Bosch plug. If I ever go to a IIc it will be easy to adapt the harness. Big thanks to Marc for waiting around for me to make up my mind!
The intercooler will be a medium sized eBay job.
Posted: Wed Aug 31, 2011 6:53 pm
I don't think you'll want to switch back after you get used to the VEMS ;)
Posted: Wed Aug 31, 2011 6:59 pm
by Mcstiff
I'll never say never since updates are always around. For me, price was the main factor and the only way I could keep the project moving.
Posted: Wed Aug 31, 2011 7:14 pm
by PRA4WX
I love it when a plan comes together! ;-)
Posted: Wed Aug 31, 2011 7:28 pm
by Mcstiff
Still missing the together part! I need gaskets, TB, fluids, lines & fittings to connect the dots HAHAHA!
Posted: Tue Sep 06, 2011 6:03 am
by Audilard
17 Days!!! Get in the garage!!!!!
Posted: Tue Sep 06, 2011 7:21 am
by Mcstiff
Audilard wrote:17 Days!!! Get in the garage!!!!!
Really, 10 days if I want to tune before the drive down :rolleyes:
The good news is that I'll be able to drive down regardless. The bad news is that it may be NA :(
Posted: Tue Sep 06, 2011 9:34 am
by EDIGREG
Nice!!
loxxrider wrote:I don't think you'll want to switch back after you get used to the VEMS ;)
:stupid:
Posted: Tue Sep 06, 2011 10:02 pm
by Mcstiff
Labeled the universal VEMS harness tonight. Good use for the wife's label printer :D
Next step is to mock it up around my spare engine.
Still need to track down some of the more common parts (gaskets, SS lines, etc).
:tickTOCK:
Posted: Sun Sep 11, 2011 9:45 am
by Mcstiff
Ugh. Little accomplished this weekend :( Did a little work on FMIC mounting, looks like some L brackets on the stock crossmember will work. I have been plotting about installing the VEMS & harness but did not have everything for that until yesterday.
After tomorrow I'll have all the big parts but still need about $300 of stuff to do the install (MLS & gasket set, oil lines and fittings, TB et al, valve seals, intake pipes and fittings, fluids, etc). In the end, it is looking like I'll be in Vegas with a VEMS controlled 7a and a Holset in the trunk :lol:
I 'could' take some shortcuts, not pulling the head, but blowing a headgasket at BBQ2 sounds like less fun than driving a N/A 7a!
Posted: Sun Sep 11, 2011 9:49 am
by Audilard
Mcstiff wrote: In the end, it is looking like I'll be in Vegas with a VEMS controlled 7a and a Holset in the trunk :lol:
I'll be sad if I don't see my old red car again. :wink:
Posted: Sun Sep 11, 2011 10:02 am
by Mcstiff
It will be a lot like your old car :wink:
If I decide to refocus, concentrating on things that can be done at night without disabling the car, I may get my Porsche seats installed this week, VEMS running and maybe install my AL radiator. I could run the new manifold but risk stunting what little low end the 7a has.
Posted: Tue Sep 13, 2011 3:57 pm
by Mcstiff
:drool:
Having rods is a bad temptation }:- )
Posted: Tue Sep 13, 2011 4:34 pm
by VWAudi4Life
Must. see. the WG dump tube to frame rail. clearance...
Posted: Tue Sep 13, 2011 4:44 pm
by Mcstiff
VWAudi4Life wrote:Must. see. the WG dump tube to frame rail. clearance...
I wish I could put it in tonight!
If it helps the whole thing is <5" wide.
Posted: Tue Sep 13, 2011 5:42 pm
by PRA4WX
mmmmmm tasty! Is it in yet??
Posted: Tue Sep 13, 2011 5:55 pm
by Audilard
Hey, I've seen those parts! Very nice Ed now GET TO WORK!!!
Posted: Tue Sep 13, 2011 6:03 pm
by Mcstiff
Audilard wrote:Hey, I've seen those parts! Very nice Ed now GET TO WORK!!!
Work is the problem! Wish I could take the week off!
Posted: Tue Sep 13, 2011 8:57 pm
by Mcstiff
A little time spent...
I had a pic of the exhaust side but the iPhone ate it and everything is packed away now.
This pic is difficult to read but that is an 8 next to my thumb and the WG flex joint can be, just, made out above the stand wheel.
Daily motivation...
I need to pickup some wire (NAPA only had 50' spools) and lock down a whole list of gaskets and such to make it happen. Right now I think the worst case could be a VEMS 7a with Hank's intake and we all know the best case!
Posted: Tue Sep 13, 2011 9:38 pm
by Mcstiff
One thing that may speed things up, without being too foolish is ditching the A/C for the winter and installing something that fits and uses a modern coolant in the spring. Thoughts? I know the lines would need to be capped to try and keep what stays with the car dry.
Posted: Tue Sep 13, 2011 9:48 pm
I am kindof nervous about the frame rail. A few people have mentioned it. It fit in the urq just fine so hopefully it works. :).
Want me to bring my old 11mm head studs to Vegas with me? My stroker is using 12mm units. I'll give you a good deal :)
Posted: Tue Sep 13, 2011 9:51 pm
by Mcstiff
We'll find out!
Studs are tempting, lets see where this weekend puts me!
Posted: Wed Sep 14, 2011 10:12 pm
by Mcstiff
No AC comments eh?
Anyway, Thinking about compression numbers...
12psi+6psi=18*10.3=185.4psi
185.4psi/9.3=19.3-12=6.3psi
7a stock sea level cyl pressures are like 151psi and the stock 3b is about 244psi.
Would it really be dumb to bolt this to the stock 7a longblock? :bashtard:
If not, the worst thing to do would be the oil feed and return (the wiring is time consuming but fairly clean and quiet).
Re: Ed's 1991 CQ. Injection is nice but I'd rather be blown.
Posted: Thu Sep 15, 2011 5:46 am
by VWAudi4Life
Hmm.. Do stacked head gaskets and ARP head studs, then go for the rod limit :)
