death 4kqt wrote:[/quote]
a_CQ wrote:I don't remember what the volvo kids did or what I said...but at that point I already had few beers.
they existed....possibly with too much hair gel and too much love for volvos. You made comments regarding queerness of fwd volvos and something about mothers needing cars returned before morning....
[/quote]
Re: Hanks 81 URQ, Daily Driver status!!! Pictures
Posted: Thu Nov 18, 2010 5:11 pm
by EDIGREG
a_CQ wrote:That shifter was horrible. I don't remember what the volvo kids did or what I said...but at that point I already had few beers.
hahaha i don't remember what was said, but i do remember laughing at them
Hope you decide to make it out to carlisle again this year despite the long drive.
Posted: Fri Nov 19, 2010 8:43 am
More info. I went to put the head back on, and noticed a contact on the head..
Pulled the pan and the rod caps.. The #1 offending cylinder, with the contact, also has a chewed up bearing. It isn't spun, but it is the only one without the coating on it..
thoughts?
Piston spot, left hand #1 bearing cap and #2 good cap... in photo
Posted: Fri Nov 19, 2010 8:46 am
by Dave
I'm still struggling to see how that little of material being worn off would allow the piston to hit the head. now with the head decked that will bring it even closer...
Posted: Fri Nov 19, 2010 9:00 am
by death 4kqt
is that a 3b piston?? I thought you had JE's
Posted: Fri Nov 19, 2010 9:07 am
doesn't look like 3b to me
Posted: Fri Nov 19, 2010 9:08 am
That's what it takes to beat the banana :( That is really strange, it seems as though it was hitting quite regularly and forced wear on the conrod side shell? I wonder if your block has been decked before.
Posted: Fri Nov 19, 2010 9:40 am
by quattro87
The hit is on the squish portion of the piston, which by the way are Wisecos, so decking shouldn't change that dimension as the squish on the head is level with the deck. If there wasn't enough clearance for squish, then is seems like the other cylinders should show some signs of contact also. At 8500rpm things stretch a bit and that area needs to have enough tolorance to accomodate that stretch, but again the other hole look fine.
Posted: Fri Nov 19, 2010 4:08 pm
Well, I spent the morning measuring crap. Pistons all sit the same amount proud with new bearing shells it all looks good. I really just think I had a bearing that either had a shaving get in it, or was bum. Seeing how I ran over 25K miles on that shell and beat on it, I think it had the right.
The old bearing had about .019" worth of slop, and that is probably why it contacted the head. I really wished I Had the drive to plastigauge the squish zone with the gasket on. I may put my old headgasket back on, and just see what kind of clearance there is..
It all looks good though. The sky looks threatening, and I plan on doing the half track at Millers in the morning with the projected 6" of freshies!! Tonight is shot, but I plan on waking up at 3am to ensure a 9am departure.
I'll keep you updated..
Posted: Fri Nov 19, 2010 4:18 pm
:woowoo:
Posted: Fri Nov 19, 2010 4:24 pm
by quattro87
I still have a hard time with the notion that you couldn't hear that kind of slop in the rod. I think that it is time that you quiet that exhaust down a tad. :wink: Are you just going to throw the one bearing in there? You ought to measure the old compressed gasket and piston proud to at least calculate your squish spec.
I think if I were you and you did get it together before 9:00am that you might want to turn down that boost a bit so you don't come home with banged up body parts. Nothing worse than fresh painted dents!!
Posted: Fri Nov 19, 2010 4:26 pm
by Dave
Animal. that's what you are.
Posted: Fri Nov 19, 2010 6:05 pm
by savagerocco
hank...... you have the sickness i lost some time back......
Posted: Fri Nov 19, 2010 7:11 pm
by Wheeljack
Forecast for 30-40 mph winds and rain tomorrow...not gonna snow in the valleys until tomorrow night...sounds like fun for working the corners!
Posted: Fri Nov 19, 2010 7:59 pm
by a_CQ
Hank, I don't know what type of an event is happening at the track but I'd be very careful about your plan there...you don't need to be tired at all when trying to drive that car around the track. It won't be the first nor last track event that was missed due to broken car. Don't feel bad or pressured to be there...my $.02
With that said, best of luck putting it back together. I am surprised you have 25k miles on that engine?! It's probably combo of high revs and even higher boost levels that did that bearing. Surprising it's #1, as I thought it's usually #5 that goes on these cars.
Posted: Fri Nov 19, 2010 9:47 pm
I think Hank actually functions better on lack of sleep...
Posted: Fri Nov 19, 2010 10:22 pm
Good advice there Peter.
I may have the cylinder naming wrong. The bad bearing is the bearing closest to the front bumper of the car. Sorry, I am a newb. Is that cylinder 5 or 1?
Jim, it was good seeing you in Vegas where I had showered or slept in the last 24 hours.... Well, after I caught up on sleep
Posted: Sat Nov 20, 2010 8:32 am
by cuatrokoop
1 is closest to the bumper, 5 is closest to the firewall...
Posted: Sat Nov 20, 2010 10:01 pm
by quattro87
Is it running yet?
Posted: Sun Nov 21, 2010 8:05 pm
by Audilard
quattro87 wrote:Is it running yet?
Yep...but there is about a pound of drool that he needs to clean off from me. I went down Saturday to uh....pick up a few items for my car....and couldn't stop complimenting the beast. I love that car Hank!
Posted: Fri Dec 03, 2010 9:39 am
by Hapster
Hey Hank, you've got PM...
Posted: Sun Dec 05, 2010 11:47 am
by pkw
hank you are (at least did have) having a lack of snub mount issue and would hate to add one back in right where all of the the front end go fast goodness happens at the front end of your car, so have you ever looked into adding a snub cradle design to the other "lever arm" ie the transmission area?...may be worth thinking about...just my .02
Posted: Tue Dec 07, 2010 4:14 pm
by Hapster
Calling Hank on the PM stand...
Posted: Tue Dec 07, 2010 4:40 pm
replied
