Page 8 of 13
Re: Tim's '86 BLAZE 4kq,16v/ABA/o1E/turbo/VEMS UPDATE!!
Posted: Thu Jun 21, 2012 9:46 am
by my2000apb
vagrant_mugen wrote:no serpintine???
thats so like 1980's dude... wtf???
(looking good, remember when i was this close w/ mine....)
i had initially wanted a electric ps pump, once i started to have all the parts in front of me it looked alright to run the 4kq ps pump to tension the waterpump vbelt. the alternator and ps pump and ac all run off the serp.
i now have the bbm 16v/aba crank pulley and am going to use my 12v vr6 wp pulley to run the wp, alt and oem mk3 tensioner w/o ps at all
im prob jsut going to loop the resevoir through the rack and leave it for now til i go electric pump, that gets me even more clearance up front and a single belt with oem brackets and tension, seems like the way to go
Posted: Fri Jun 22, 2012 5:17 am
by glibobbo21
My 5 cyl is fine with manual rack, just find one...So much easier and less clutter in the bay...
Posted: Fri Jun 22, 2012 5:33 am
by death 4kqt
dude, the available torque output of your arms might be a bit above average jim, those of us scrawny basterds have a bit more trouble with manual steering
Posted: Fri Jun 22, 2012 5:53 am
by glibobbo21
HAHA
Posted: Fri Jun 22, 2012 7:42 am
by my2000apb
its harder to find a manual rack than to rig in an mr2 unit
Posted: Fri Jun 22, 2012 4:48 pm
by my2000apb
Posted: Fri Jun 22, 2012 5:19 pm
by my2000apb
Posted: Sun Jul 15, 2012 4:32 pm
by Rallyfreak202
Hell yeah! That exhaust is looking great.
Side question for a friend that wants to do this; will a VR6 bolt to a stock 4000 trans? I believe 034 sells an adapter plate.
Posted: Mon Jul 16, 2012 6:34 am
by my2000apb
Rallyfreak202 wrote:Hell yeah! That exhaust is looking great.
as far as i know the adapter would work with te 016 bell housing pattern but theres not a clutch thatll work,
the adapter works with o1a/o1e so hed have to make that change
a vrt will eat up an 016 quickly anyway so its a trans swap that has to happen sooner or later anyway
cq exhaust update to come, now thats a real exhaust
Posted: Mon Jul 16, 2012 7:57 am
I modify flywheels that make the 016 a bolt on, but yeah, over 450whp is asking for broken second gears in an 016 config
Posted: Mon Jul 16, 2012 10:50 am
by my2000apb
Ok update time, ive been slowly collecting interiors bits, and now that I have it all its time for some refreshing. I bought a set of red leather door panels from mike (audisport4000) and recently acquired the seats from ryan from mikes old car. I had also picked up a set of d11 v8 all red taillights with the intent to sell them but alas, im going to run them on this car. With neon orange on the outside and red leather throughout the interior we will be rolling redneck rich for sure!! Ahah
The door panels have some peeling that needs to be addressed. Ive gotten all the small black trim pieces off the panels now I need to condition the leather and try to get it to stretch back out a bit.
The map pockets I have were in pretty good shape but with the usual cracks. I glued the cracks and also adhered small washers to the inside of the mounting holes for some more strength.
Pics!!
Posted: Mon Jul 16, 2012 11:01 am
by my2000apb
Posted: Mon Jul 16, 2012 11:29 am
by my2000apb
Ok back to updatage!!!
So I got around to doing a bunch of smaller things, that were really just slowing down bigger and better stuff, so they are done
I got my aeb oil pan tapped for ½” npt, I have a 45 degree/10AN adapter that has been deanodized and will be snugged tight to the correct “clocked” position and be welded after to keep it from moving evar.
I “rebuilt” my driveshaft from the 4kq with the rear portion from a b3 cq d/s. my rear section got abused in towing/impacted and it was just easier to pop off the cq rear and it went right back together with a new carrier bearing, itll be fine.
I made up and had ryan weld on a pair of m6 bungs on the back of my intake manifold, ill use them to keep lines and wires etc tied down and in the right spot.
I cut apart a scrap hood that jim had lying around to use the raintray vents on my 4kq fenders. Im going to run a few of them horizontally on the front fenders just rearward of the turn signals, the passenger side to help the intake air and the driver side will give air to my oil cooler which is mounted closeby. Should be pretty clean when im done with it.
My bumper mount plastics slots were hardly there at all so I removed the rest and will be mounting the front bumper sides with 2 dzus fasteners on small pedestals.
Aeb oil filter housing is installed now I can run some more wiring and turbo oil feed line etc
I also installed my racepart solutions, tial knockoff bov. So I can start running vac lines off my IM
Posted: Mon Jul 16, 2012 1:52 pm
by my2000apb
Posted: Mon Jul 16, 2012 4:50 pm
by autoholic
Damn, nice work as usual. I'd love to have that exhaust.
Posted: Mon Jul 16, 2012 5:02 pm
by audidub
autoholic wrote:Damn, nice work as usual. I'd love to have that exhaust.
pm me maybe i could make you one just like it
Posted: Mon Jul 16, 2012 5:34 pm
by JonathanL
Blaze orange paint + red leather equals PIMPIN
Posted: Wed Jul 18, 2012 10:01 am
by my2000apb
EDIT: alt and tensioner setup has changed, skip two pages forward
my2000apb wrote:vagrant_mugen wrote:no serpintine???
Ok, I’ve been working on figuring out how I will run the belt setup and I think I’ve got a solution. I used a 12 vr6 ( I’m using an AFP pulley but all 12v vr6 pulleys should work fine) water pump pulley to convert it to serpentine only. The tensioner bracket is mk3 ABA. The alternator is b3 I think, and Is currently just hanging on one bolt. I will have to build a lower bracket for this, if this is how I will ultimately run it.
the alternator needs a bit more space to alight it perfect, but theres plenty of thread left to add a washer behind the alt. pulley
the new pulley on the ABA is a Dayco 89051, 76mm 6 rib serp idler pulley
http://www.summitracing.com/parts/DAC-89051The steering rack will be converted to manual. So I will be able to rid my engine bay of the pump, lines and reservoir. I drove jims car with the manual rack a while ago. The steering felt nice and responsive, it was a tad heavier than I wanted by just a bit, still nothing like the number power assisted rack. I do still want to go manual rack. I think the shorter, much lighter motor in combination with moving it back towards the firewall about an inch, should lighten the front of the car up as well. I think it’ll be right nice.
Here’s the pics of how I plan to route the belt, lmk what you think
Posted: Wed Jul 18, 2012 10:25 am
by Sciroccohp
who did the o1E shift linkage for you or did you do it?
Posted: Wed Jul 18, 2012 10:33 am
by my2000apb
i did it, its not bad, gotta question?
Posted: Wed Jul 18, 2012 10:43 am
by Sciroccohp
no wondering if you could do mine! I have a manual rack
viewtopic.php?f=4&t=38367&p=479817#p479817 from a vw fox I could trade you for it?
Posted: Thu Sep 20, 2012 6:25 am
by my2000apb
SHE HATH NOT BEEN FORGOTTEN!!!!!
so i took a 6 week break from this project to get a bunch of chassis fabrication done on the cq vrt and am finally getting back to this!
carpet has been pulled and cleaned/shampooed several times by Toph, thanks again
there isnt a wear hole in the entire carpet, no heel holes on the drivers side, nothing! it sooo clean and actually BLACK!!!haaha
i jsut need to make a hydro handbrake mounting bracket as well as an ecu/relay mounting area where the stock a/c stuff was under the glovebox
then the carpet can go back in
the built head and the bottom end (stock for now) will be bolted together shortly. i need to send Janis some moeny for the oem NEW ABF timign belt backing plates and covers, as well as some timign belts.
i have all the stuff for my vems wiring, so i will get the motor bolted together, plopped in the bay and get to wiring.
im 90% sure im on the final version of my serpentine belt setup.
i also got a third pair of hella 500's last night from a friend, so i figure 6, 500's on the bumper bar will work well until the rest come in, then ill be running 4, 5" 500's, and a pair of 7" 700's on the bumper as well. and on the roof rack bar a pair of the 500 floods and a pair of 500 pencil beams!
BRING ON THE NIGHT SUN!!!
Posted: Fri Nov 02, 2012 7:24 pm
by my2000apb
Posted: Fri Nov 02, 2012 7:30 pm
by my2000apb
I cut the pieces out of some spare sheet. Then I used a pair of extra wide sheet metal bending pliers and they worked pretty well, its only 22 gauge.
I got it all welded in, primed and seamsealed.
I also replaced the rear exhaust hangers with universals as the oems were getting crunchy.
I got some rugged rubber hangers and the muffler sits in there nice and cozy.
well i dont have a pic of the drivers side hanger, and i forgot to trim down the passenger side hanger ha its a bit long
Posted: Fri Nov 02, 2012 8:00 pm
by my2000apb
Ok some more,
Over the summer I got a pair of front cq hubs/knuckles and I already had a pair of 90q 20v for the rear. I got them pressed out by Jim, thanks again, and blasted up and ready for powdercoating at Ryan’s, thanks again. They came out great! Gloss black and ready to be put back together. Marc @ efiexpress got me a set of wheel bearings and we were in business! Once again, Jim came through and got them all pressed back together for me.
The car is mostly a rural thrasher mobile, so suspension need not be low. Im running all 90q 20v springs and struts as well as 26mm sways front and rear. Im also looking at getting a 21mm 4k fwd bar for the front.
the car should sit a good bit higher up with the 90q susp. and the 4cyl upfront vs the i5
A while ago I got around to making some trans mount arms. I took some pics at the beginning and here they are. They are finished and installed but ill snap some more pics tomorrow.
Tomorrow's update
-finished trans mount arms
-exhaust tip extension to rear bumper
-serpentine belt / accessory finalization!!
