An Alpine URQ in Utah - Knee deep in Swarf
Re: An Alpinweiss URQ in Utah - Springing Into Action
WOW, that's really awesome head work! When I build my number two engine, I think I may have to have this done as well!
- ralleyquattro
Looks like red loctite applied to few threads.
Head looks great, can't wait to see the same on the block side.
Here is a shot of the works alloy block.
lol, Nick,...
Link to video
...and of course...
Link to video
Thanks for the pic, Martin. I don't have that one in my collection, but I've got many other views/angles of that motor and the magnesium block which also has the deck cooling. Do you happen to know what they were using as a head gasket on those motors?
One thing that's been important with this little tangent, is that a standard MLS gasket can still be used as I didn't want a whole cascading list of supporting mods to make it work. So this is why I've kept the material removal to a minimum...at least initially. The works motors are definitely opened up more than what I see being done by those currently doing this and using standard MLS gaskets.
Link to video
...and of course...
Link to video
any more pics of the sport block? or high res?
my2000apb wrote:any more pics of the sport block? or high res?
What are you looking for in particular, Tim? The pic Martin posted is about as hi res as I've seen and details the deck pretty well. There are also a lot of small variations in how the blocks were prepared--the sleeves in particular are different.
Here are some more from an SQ on James' site...
http://www.bufkinengineering.com/engine_open.htm
Twintowers
Re: An Alpine URQ in Utah - The Emperor's New Groove
I'm sending you my block, and 20v head for this modification LOL can you make me a copy of that Audi valve cover? I would use a copper head gasket or the MLS, at least with the copper gasket you can reuse it, not cheap by any standards on either option though! Oh yea can I have set of those custom "decked" valves installed :cheers:
Mcstiff wrote:IMSA 90 Head:
Woah, that is awesome!! Look at the exhaust valves at a more desired angle for less shroud at full lift, plus the squish zones compacted in! Super cool head!! Man it would be killer to have those heads reproduced.
ShavedQuattro wrote:Mcstiff wrote:IMSA 90 Head:
Yea Chris, could you get on that?
In all seriousness though, the test head looks great. I told you I should have waited on you putting your Urq together before doing mine. I may have to come up and ruin a day of yours again talking and letting the chips fly. Nice work!!Re: An Alpine URQ in Utah - The Emperor's New Groove
Whoa...lots of action today, and I don't even have any updates...
Yeah, that IMSA CC looks pretty nice...There's your deshrouded and angled ex. valves, Hank. Heck, you could even deck THAT head with the valves left in place...
John, you do have a stroker project still, right? All this 'I wish I waited' talk makes it sound like you've finished your build(s)...
I say let's get that stroker project back on the front burner.
And, regarding the head gasket...I have to be able to use a stock <$100 MLS gasket for this revision. Maybe later down the line, open it up more (like the works head/block) and possibly have to use something like a straight copper/copper composite gasket, but at $250+ for that, plus the head/block work, it becomes a harder 'pill' to swallow.
David, you can actually buy one of those valve covers. They are currently being reproduced. And I'll send you out a set of those custom decked valves once I get them back from my new favorite machine shop that I now have doing all my work.
Has anyone used a straight copper gasket without an o-ring? 034 doesn't recommend it. But I'm thinking AudiSport *may* have done it back in the day. I'm not looking to do a tear down after every race though either. Fact is, MLS gaskets work with the machining I've done, as a few folks on the S2forum have already done it with success.
I wonder what James is using for a gasket on his works motor with the massive cooling...Mr. Bufkin to the white courtesy phone...
I say let's get that stroker project back on the front burner.And, regarding the head gasket...I have to be able to use a stock <$100 MLS gasket for this revision. Maybe later down the line, open it up more (like the works head/block) and possibly have to use something like a straight copper/copper composite gasket, but at $250+ for that, plus the head/block work, it becomes a harder 'pill' to swallow.
I had some MLS gaskets bored out to 83.25mm in a fixture. A little north of 100$ but not much. I used the Copper with no oring, but it leaked bad. Jimmy uses it and claims good results.
Awesome stuff! Hank, when does the repro run of IMSA heads begin?!
Highlander
This thread is good shit!!!!!!!!!!!!!!!
:thanks: :cheers: :cheers:
Craig.
Craig.
I would make every effort to avoid using copper. I have been lucky, but my coolant does get a little dingy over time from oil mixing in somewhere. It's such a small amount I don't care, I just change it every 30k or so.
impretzle
Where are the valve covers being reproduced?
Thanks
Thanks
I've had some discussion and it looks like I should be fine with the MLS, even with the deck cooling opened up to something more along the lines of the AudiSport stuff. Also discussed some highly positive real world performance benefits from the mods.
So, I'm in the process of revising the design and I'll throw my test head back on the machine and remove some more material. Should have something in the next few weeks.
In the meantime, I was able to dry fit my Honey Badger (TM) coilovers made up of $300 worth of new and second hand parts. I think they turned out pretty damn nice. We'll see how these struts hold up. I've decided to try and bring my spring rates down a bit in hopes of not killing them, if they're not half gone already...
Sorry for the crappy Android photo...
impretzle wrote:Where are the valve covers being reproduced?
Thanks
I'm not exactly sure, but some creative googling got me to a seller in Germany...
http://www.quattromanufaktur.de/catalog ... 1d180a7180
and some more parts...
http://www.quattromanufaktur.de/catalog ... cPath=1_14
timmy needs badass block mods and for the zylindre head
Yep, I can see where my next motor build is headed
- ralleyquattro
cbrydon wrote:In the meantime, I was able to dry fit my Honey Badger (TM) coilovers made up of $300 worth of new and second hand parts. I think they turned out pretty damn nice. We'll see how these struts hold up. I've decided to try and bring my spring rates down a bit in hopes of not killing them, if they're not half gone already...
Did you end up extending the front tubes from 50 to 55mm?
Euro strut housings were 55mm to start with on the 150hp and up models.
Cheers
ralleyquattro wrote:cbrydon wrote:In the meantime, I was able to dry fit my Honey Badger (TM) coilovers made up of $300 worth of new and second hand parts. I think they turned out pretty damn nice. We'll see how these struts hold up. I've decided to try and bring my spring rates down a bit in hopes of not killing them, if they're not half gone already...
Cheers
No...the fronts are still small bore. It just made more sense with what I already had on hand to work with, despite the lower performance.
I would probably do something akin to the Mance BBSE in the future.
Hey Chris, don't follow Hank's lead and move out of state. Stay here and make cool stuff for the locals!!
<insert project update here>...
