Page 2 of 8
Re: Toph's 1990 3b, 01e, scope-creep Coupe Quattro
Posted: Thu Jul 26, 2012 4:47 pm
by Toph
Posted: Fri Jul 27, 2012 8:31 am
by Toph
Posted: Fri Jul 27, 2012 8:45 am
by quattro87
Nice!!
Posted: Fri Jul 27, 2012 9:01 am
by audidub
Down pipe is welded, intake should be finished up tomorrow morning
Posted: Fri Jul 27, 2012 9:10 am
by Toph
WooHoo! Maybe a little DP TIG teaser shot?
Thanks John, I'm really pretty happy with the path that this build is on right now, just have to keep up the good progress. You 'cruising' down the strip yet?
Many many thanks to you, Ryan, at Higbee Performance Fabrication. Really quality work at a very reasonable rate has allowed this project to happen.
Posted: Fri Jul 27, 2012 11:10 am
by quattro87
Toph...no cruising the strip, no cruise control installed, and no rearend under the car. I did however get the actuator all cleaned up and painted only to find that the rod and my custom fuel rail want to share the same location. :( I will have to figure out a different bracket or something. It looks good though.
Posted: Fri Jul 27, 2012 11:18 am
by Toph
Maybe just a new rod section that has a hump in it to clear the rail? Looks great though!
Posted: Fri Jul 27, 2012 11:22 am
by quattro87
Yea, that is what I was thinking also. It's on the back burner for now though.
Posted: Mon Jul 30, 2012 7:32 pm
by audidub
Here's a teaser while we wait for some good ones. Water manifold will be done this week
Attachment ( 31962 ) : IMAG0223.jpg
Attachment ( 31964 ) : IMAG0218.jpg
Posted: Mon Jul 30, 2012 7:46 pm
by glibobbo21
oh u fancy
Posted: Fri Aug 03, 2012 7:31 pm
by my2000apb
and i came home to find more parts for tophs car had been dropped off!!
Attachment ( 31995 ) : tophs stuff welded.jpg
Attachment ( 31996 ) : tophs stuff welded2.jpg
Posted: Tue Sep 04, 2012 6:30 am
by Toph
A little update:
Haven't worked on the girl in a bit, but I have been gathering parts. I have nearly everything I need to finish up my oil cooler plumbing, breather/catch can setup, and fueling. I need a few AN parts here or there, but no big deal. My main issue right now is my radiator - or lack thereof. There are a few mockup OE copper deals here, but they all leak. Here's where I'd appreciate some
input:
I only have 2 real options that I'd be happy with, with a very lightly used B2 radiator being a third/last resort.
(1) I'd love to buy an aluminum radiator core and have endtanks made (or have a whole radiator custom built). I know the easy answer involves a certain forum sponsor link, but I'll pass on that due to fitment issues (16" will be too wide for my application at 2.75" thick...I can get about 14.5" and still have it sit perpendicular to airflow). The aluminum core will be thicker than stock, so a custom fan and shroud setup will be in order. I'll be looking at about $650 or more to go this route. Maybe something like this mounted vertically with a different endtank setup obviously (13"x22"x2"):
(2) I can have the copper(or brass?) B2 radiator rebuilt with a 4 row core for about $325 and reuse the stock shroud/fan combo. I have been mocking everything up according to this route. It will sit at a bit of an angle, but that doesn't concern me since it will be properly ducted. I am leaning towards this option at the moment.
Posted: Tue Sep 04, 2012 12:49 pm
by my2000apb
get it rebuilt !!!
Posted: Tue Sep 04, 2012 1:19 pm
by Toph
I'm ready to give Dale a call back and set the wheels in motion, figured I'd see if anyone could convince me otherwise. I also emailed a fellow in the UK about new B2 units which I doubt will cost anything near reasonalbe....nevermind the cost to ship.
I think 325$ is reasonable considering stock replacements can be found for ~$160+ for an aluminum core with plastic endtanks.
Posted: Tue Sep 04, 2012 1:21 pm
by my2000apb
less grunk more execute
Posted: Tue Sep 04, 2012 3:33 pm
by glibobbo21
My radiator works fine...plastic. Youre crazy to spend 325 on a rad just to keep it copper, thats madness.
Posted: Tue Sep 04, 2012 4:24 pm
by my2000apb
glibobbo21 wrote:My radiator works fine...plastic. Youre crazy to spend 325 on a rad just to keep it copper, thats madness.
youre car runs too hot
Posted: Tue Sep 04, 2012 4:30 pm
by glibobbo21
Below 3/4 is not too hot, you guys are being pansies. My fan outputs are reversed, only comes on the second speed(later) just haven't swapped the pins yet. and idling 20v doesnt make more heat then an idling 20v. The only cooling increase youll see is running the aux radiator, which he obviously has no room for, along with anything else he wants to put in there now.
Posted: Tue Sep 04, 2012 4:47 pm
by audidub
My 4ktq ran aat 3/4 almost all the time and never over heated
Posted: Tue Sep 04, 2012 4:48 pm
by my2000apb
ok so its below 3/4
but above 5/8 is too hot
Posted: Tue Sep 04, 2012 4:55 pm
by Toph
But does any of that really matter if I have to replace the plastic units twice as often?
Posted: Tue Sep 04, 2012 4:58 pm
by glibobbo21
Splitting hairs about a car that doesnt run! Could be my lack of ducting on the block side of the rad too! Idling I'm pretty positive is just my fan outputs being backwards, because I have the cq fan and MK2 golf/jetta harness controlling it.
Thats bullshit that rad(your plastic one) is probly the original factory piece, and its lasted this long. Ill eat my hat if my plastic one blows in my lifetime.
by glibobbo21
and i dont own a hat, ill go buy one and eat it.
Posted: Tue Sep 04, 2012 5:03 pm
by Toph
glibobbo21 wrote:which he obviously has no room for, along with anything else he wants to put in there now.
And when it's all said and done it'll look like there couldn't possibly be a 20vt in there. That 20v euro bumper is a pain in the ass sometimes though...
Posted: Tue Sep 04, 2012 5:06 pm
by Toph
Well, you do have a point. How long have you run your current radiator?
