90q IMSA GTO (wanna-be) build
Re: 90q IMSA GTO (wanna-be) build
It's eurospec's IIRC 17k for a stripped chassis, partial side pods with molds.
OOOOGT
Post by OOOOGT »
http://cgi.ebay.com/ebaymotors/1993-Aud ... 887wt_1031
Crazy pricetag
DFrosty
Post by DFrosty »
Build update:
She's starting to look like a real car again....
Attachment ( 35630 ) : 90q_22APR2013 copy.jpg
Attachment ( 35631 ) : 90q_ic+xmember mock fit.jpg
Attachment ( 35632 ) : 90q_interior_APR2013.jpg
Attachment ( 35633 ) : 90q_dashcloseup.jpg
So many nice details going on with your build. Great work.
DFrosty
Post by DFrosty »
Been some time since last update....lots of puzzle solving
Attachment ( 36473 ) : Fuel line built_feed copy.jpg
Attachment ( 36474 ) : Fuel line_return ports copy.jpg
Attachment ( 36476 ) : new feed fitting.jpeg
Attachment ( 36477 ) : new return fitting.jpeg
Alloutofdonuts
Post by Alloutofdonuts »
Nice project. What wheels are those in the 2nd pic, OZs?
DFrosty
Post by DFrosty »
Alloutofdonuts wrote:Nice project. What wheels are those in the 2nd pic, OZs?
Compomotive MO1681 (16x8.0)
I forget what the offset is...can check the wheel if you'd like
VWAudi4Life
Post by VWAudi4Life »
DFrosty wrote:Been some time since last update....lots of puzzle solving
The engine bay is looking really nice! Could you provide some details on where the plug wire grommets came from?
Thanks.
-Pavel
DFrosty
Post by DFrosty »
Thanks.
-Pavel
Certainly...
They're MSD Pro-Clamp Wire Separators 8843. I bought from local speed shop and they're available online.
VWAudi4Life
DFrosty wrote:Certainly...
Sorry, I should've called them something more specific... I was interested in the round boots that cover the plug holes.
Thanks again!
Edit: I have a sneaky suspicion that they came as part of the Magnecor plug wire set and are not sold separately.
DFrosty
Post by DFrosty »
Thanks again!
No worries. And yes, your suspicions serve you well....they are built onto the 3B wire set. PM me your email address and I can send you their catalog pdf
Alloutofdonuts
16" eh? I thought they looked bigger. Look a lil bit like UrS4 wheels. Great looking on your car!
DFrosty
Post by DFrosty »
Finally figured out the Turbo outlet to IC + Diverter valve plumbing puzzle! Prettiest thing in the world? Maybe not, but looks like it will help me make that Kessel Run in less than 12 parsecs.
Thanks go to Sam, JT, Dan the Man and Jimmy for your help
Attachment ( 36488 ) : DV out_front copy.jpg
Attachment ( 36489 ) : Turbo out hose_side copy.jpg
Attachment ( 36491 ) : Turbo outlet+DV plumbing complete_top.jpeg
Attachment ( 36492 ) : Turbo outlet hose_front copy.jpg
DFrosty
Post by DFrosty »
3B oil filter housing mounting complete. Now another iggly, niggly problem after mounting :frustrated: There's 2 mounting provisions on the block (for a/c compressor mount I'm assuming) that are now preventing me from screwing on the larger capacity 068 115 561B oil filters. I'll need to either:
A) grind off the 3-4mm on those provisions so that filter will fit
or
B) just use the standard capacity 3B oil filter
Would it matter either way??
Attachment ( 36528 ) : 3B oil filter housing_front copy.jpg
Attachment ( 36529 ) : 3B oil filter housing_side copy.jpg
my2000apb DrBeastCar
Post by my2000apb DrBeastCar »
grind them off
have you tried the larger 1.8t Passat filter?
DFrosty
Post by DFrosty »
my2000apb wrote:grind them off
Have not...only for B6 A4 1.8T. They are not one and the same? If the overall diameter is smaller, then I'm picking up a few.
they are different, also if your down for some trimming the EV filter should be able to fit
theres an oilfilter thread around here somewhere, covers what fits in there between block bosses and oil pan relief, etc
DFrosty
Post by DFrosty »
:woowoo:
Attachment ( 36541 ) : 3B oil filter housing_block cleared copy.jpg
Attachment ( 36542 ) : oil filter_clerared copy.jpg
Attachment ( 36543 ) : 3B oil filter housing completed copy.jpg
padwalz
Post by padwalz »
omg 8)
DFrosty
Post by DFrosty »
Fuel Lines/Fittings done and done....Hope they don't leak!
Attachment ( 36583 ) : Fuel lines done_top copy.jpg
Attachment ( 36584 ) : FPR to firewall_side copy.jpg
Attachment ( 36585 ) : FPR to firewall_top copy.jpg
Attachment ( 36586 ) : Return line port_top copy.jpg
Attachment ( 36587 ) : Return line dizzy side copy.jpg
DFrosty
Post by DFrosty »
Nice little addition, install almost complete. Waiting for AN fittings to arrive and need to find better way to cut threaded rod....angle grinder wheel deforms threads too much
Attachment ( 36654 ) : 90q_oil cooler copy.jpg
Attachment ( 36655 ) : 90q_oil cooler_closeup copy.jpg
Whenever I cut ready-rod in the field I just use a grinder and a zip disc.
Then smooth the burrs with either the grinder (ought to switch to a grinding disc) or a sharp file. Never had an issue.
The first couple threads on a stud are always meant to be imperfect anyways, they don't hold anything... rather, just help get the nut started.
Twintowers
Post by Twintowers »
Oh shit that's me in the A's hat.... LOL :woowoo: Is the gearbox ready to go yet Dave? Looks like you have sorted things pretty good. I've been busy in the shop myself, they cut my hours at work few months back, so I've been toying away with the extra spare time, the bike is one of two here I just got done sorting out, and now onto the other one. The ur quattro is staring at me, at least the drive shaft is done, can't decide on which motor I'm going to install I have two 20v's here, bone stock, and a the breathed on one... KEEP GOING I want to hear that thing run! :-)
Attachment ( 36662 ) : 1069863_10200858062186719_1465653758_n.jpg
DFrosty
Post by DFrosty »
Twintowers wrote:Oh shit that's me in the A's hat.... LOL :woowoo: Is the gearbox ready to go yet Dave? Looks like you have sorted things pretty good. I've been busy in the shop myself, they cut my hours at work few months back, so I've been toying away with the extra spare time, the bike is one of two here I just got done sorting out, and now onto the other one. The ur quattro is staring at me, at least the drive shaft is done, can't decide on which motor I'm going to install I have two 20v's here, bone stock, and a the breathed on one... KEEP GOING I want to hear that thing run! :-)
Haha...yep, that be you man. Gearbox/Shift linkage is all set...was kind of a PITA. Now stuck on a few minor puzzles for WBo2 sensor/harness, TPS cable extension and RS2 fan install.
You have a project thread going for yours?
DFrosty wrote:Nice little addition, install almost complete. Waiting for AN fittings to arrive and need to find better way to cut threaded rod....angle grinder wheel deforms threads too much
run a die down over the threads, then cut them and back the die off, cleaning the threads
