Page 110 of 125
Re: Jim Green's 90q 20vt - 600whp 07k build
Posted: Fri Sep 25, 2015 10:25 am
Getting a new starter today, will be back at it this afternoon hopefully.
Posted: Fri Sep 25, 2015 11:53 am
by 90quattrocoupe
Good luck, Jim.
Posted: Sat Sep 26, 2015 12:00 am
Had to pop the valve cover to verify phase timing, I was on the wrong phase. With some shuffling in VEMS. And some rewiring I got it running! Now on to the cooling system. Fan controller took a shit so it's going back and I'll use the factory setup for now.
http://youtu.be/TauW8i2fx5U
Posted: Sat Sep 26, 2015 8:19 am
Woo woo! Hell yes! This makes me so excited!
Posted: Sat Sep 26, 2015 2:23 pm
by 90quattrocoupe
Very nice, Jim. Knew if anyone could do it, it would by you.
Greg W.
Posted: Thu Oct 01, 2015 11:48 am
by alxdgr8
Saw this in an email from Pegasus, looks pretty cool. Fan and waterpump controller in one. Not sure if it works with pumps other than their own though.
https://www.pegasusautoracing.com/produ ... ecID=24980
Posted: Sun Oct 04, 2015 12:50 am
by Mcstiff
We need a video in here!
Posted: Sun Oct 04, 2015 12:51 am
That's pretty slick. That definitely wasn't out when I was evaluating water pumps.
Been chasing gremlins on everything but the motor. Had to tweak the transmission linkage from pushing the motor and the trans back as much and possible. Also had a little smoke and flames from and exhaust fuck up so that's all fixed and ready to go in. Had to change up the surge tank return lines to get more fuel going back into the main tank.
Should be back on the ground tomorrow and out for tuning. Been playing with logs from Hank's TT-RS projects on pump gas so I should have a pretty good baseline when it comes time to romp on it.
Posted: Sun Oct 04, 2015 11:26 am
Ooohhh yaaay
Posted: Sun Oct 04, 2015 5:28 pm
by carl
Man, that intake is awesome :thumbsup: .
Posted: Mon Oct 05, 2015 6:29 am
by elaw
audifreakjim wrote:Had to pop the valve cover to verify phase timing, I was on the wrong phase. With some shuffling in VEMS. And some rewiring I got it running! Now on to the cooling system. Fan controller took a shit so it's going back and I'll use the factory setup for now.
Congratulations! You're giving us 07K wusses hope. :lol:
Posted: Mon Oct 05, 2015 9:20 am
by pkw
romp on it. romp on it. romp on it!
Posted: Sat Oct 10, 2015 12:28 am
We've got boost! 6 psi by 3100, 10 psi by 3500 in third. Had a bad connection to #5 injector causing me fits. It runs like a top now. Just need more tuning.
Posted: Sat Oct 10, 2015 1:17 am
by Aktapod
:guns: Can't wait to see this thing ripping it up! :thumbsup: :thumbsup:
Posted: Sat Oct 10, 2015 1:19 am
Ooohhhhhhh baby. This is great. I'm so excited. Woo woo!
Posted: Sat Oct 10, 2015 8:06 am
:popcorn:
Posted: Sat Oct 10, 2015 8:31 am
Damn fine!
Posted: Sun Oct 11, 2015 12:45 am
Tomorrow's to do list
-hook up the Accusump. Should take 11 quarts of oil at that point, lol
-test water injection
-swap in a heavier wastegate spring for minimum 15 psi base
-roughly tune spool valve
-make sure dump valve is working
Posted: Sun Oct 11, 2015 1:12 am
by mushasho
All very exciting things to setup... This is way too awesome
Posted: Sun Oct 11, 2015 7:06 am
The spool valve is pretty easy. You gonna do it on the street or with Hank? It only took dad and I about half an hour start to finish. Are you running it with an n75 or one of the fancy replacements from Marc/Hank etc
Posted: Sun Oct 11, 2015 8:47 am
Just an industrial solenoid. I've done this before so should only take 30 min or so like you said
Posted: Sun Oct 11, 2015 9:04 am
Oh yeah, I forgot it was on the old build. Very stoked for results with this turbo. Definitely post more VEMS pictures!
Posted: Sun Oct 11, 2015 1:14 pm
I can't wait to see this thing Jim! Very exciting stuff happening with it!
Posted: Sun Oct 11, 2015 3:58 pm
by vt10vt
:drool:
Posted: Mon Oct 12, 2015 1:10 am
by Mcstiff
Let the record state
[youtube]http://www.youtube.com/watch?v=ilgy2I5EUY8[/youtube]
:drool:
